Question about The Toys
Our gyro S107G helicopter drops to the ground periodically without any of the controls being changed...why is that
4 Suggested Answers
SOURCE: we have two gyros S107G remote control
Had the exact same problem. Found the solution on an Amazon posting:
1. To enable this function make sure both remotes and both helicopters are off.
2. Set the first remote's channel switch to the leftmost position (it says A, B, and C, but the s107 only supports 2 channels). Turn the remote on.?
3. Turn the helicopter that you would like to bind to the remote on and set the helicopter down on a flat stable surface for about 5 seconds. Try the throttle and the helicopter should respond to this remote.?
4. Next, to enable the second helicopter, set the second remote's channel switch to the rightmost position (it says A, B, and C, but the S107 only supports 2 channels). Turn the remote on.?
5. Turn the second helicopter on and set the helicopter down on a flat stable surface for about 5 seconds. Try the throttle and the second helicopter should respond to this remote.?
This worked for us.
Posted on Dec 26, 2010
Testimonial: "excellent help. thanks a ton. now we'll just hope for no mid-air collisions. appreciate it!"
bigtruk
  • 29 Answers
SOURCE: My Gyro s107g helicopter won't connect to the remote. It just sits there not moving or any lights turning on.
It sounds like the two are not compatable. In other words the freakwinsy of the plane is not the same as the controller. THEY MUST MATCH. You may find the numbers on the back of the controller and where the batteries go in the chopper. If the numbers do not match, take it back to the store, and get one that does. Sorry for the spelling
Posted on Jan 13, 2015
mike0862
  • 5428 Answers
SOURCE: I have a rc helicopter with gyro and can't get it off the ground. Any suggestions?
You need to adjust the trim controls........look through the instructions!
Posted on May 29, 2016
Spins to left, will not take off/lift?
GYRO Nano Hercules Unbreakable 3.5CH Electric RTF RC ...
www.amazon.com/Hercules-Unbreakable.../B00AAOJ...
Amazon.com, Inc.GYRO Nano Hercules Unbreakable 3.5CH Electric RTF RC Helicopter (Color ... you can remove the 8 or so screws that allow you to pull the fairing off, remove .... Also we purchased our helicopter from HobbyTron.com through Amazon and .... won't spin, so the entire helicopter spins, and doesn't generate enough lift to fly.
GYRO Nano Hercules Unbreakable 3.5 CH Electric RTF RC
Amazon.com, Inc.Nano Hercules Unbreakable Glow in the Dark 3.5CH RC Helicopter ... It can go forward, backward, up, down, left, right and hover. .... It worked for a few flights and now the copter will not fly off the ground. ... and ive had it for a year now and everytime I start it up and it takes lift off it starts to fly backwards but otherwise ok toy.
Hercules Unbreakable 3.5CH RC Helicopter - HobbyTron.com
Dec 26, 2015 | HobbyTron Nano Hercules Unbreakable 3.5CH...
Jan 13, 2015 | Syma S107G 3CH RC Helicopter RTF w/ Gyro...
Remote not working
I would suspect a fault but check the batteries in the remote are fitted
correctly.
Jan 28, 2014 | Syma GIFT SET 2 S107G R/C Helicopters Blue...
My gyro s107g helicopter will not levitate
press the left button(LB(like on xbox controller spot))
Apr 28, 2013 | Syma New Green S107g 3 Channel Rc Radio...
Helicopter not stable
Hi, I had a toilet bowl effect after changing the blades on my s107g. After making sure the shaft was seated properly, I simply adjusted the tension on the screws holding the blades in position and after a bit of trial and error tightening and loosening: it's as good as new!
Jan 21, 2013 | SYMA Toys industrial New Syma S107 Radio...
Will not levitate in air
FIrst read manual for all the instructions, if that dosen't work then it could be faulty.
Oct 14, 2012 | Syma 107 S107 S107g Metal 3ch Gyro...
Inferred controller loses contact with the S107G
Moving to solution section so more people will see it:
Infrared is different band of electromagnetic spectrum from radio and is subject to the same problems as radio waves, namely, noise, transmitter problems, and receiver problems. the receiving antenna will not be a wire, it will be a infrared photocell. The sending "antenna" will be an LED.
A few things to try..
- make sure that nothing is covered on your handset and the helicopter that did not come that way
- Switch channels
- try a different location to see if anything in the environment is interfering, it could be something generating a lot of heat (including bright lights or sunlight) or another infrared device, like a remote control or some wireless devices like headphones and 3D video game systems with active shutter glasses.
- turn everything else off where you are trying to fly - might have to unplug electronics and remove batteries from remotes to make sure they are not emitting
- try linking a different helicopter or different controller that you know works to see if it is on one or the other of yours
I tried putting my hand over the emitter and the helicopter, and could not block the signal. I flew mine to the balcony out of site, and it still responded fine, so the signals bounce around enough quite a bit.
Jan 05, 2012 | SYMA Toys industrial New Syma S107 Mini...
We have two gyros S107G remote control helicopters. the instructions say to "set the band selector on the transmitter and helicopter to the same frequency." the switch on the transmitter is...
This worked for us.
Dec 25, 2010 | Air Hogs Havoc Heli Helicopters
Toys Logo
22 people viewed this question
Top The Toys Experts
David Payne
David Payne
ottworld5982
Level 1 Expert
Are you a The Toy Expert? Answer questions, earn points and help others
