Question about LG Dryers
LG front load dryer, clean filter lite flashing everything has been cleaned and vacuumed but dryer will not turn on
SOURCE: Clean filter light stays on LG TD-C70045E Dryer
I had the same problem. It actually has nothing to do with the filters. If your dryer sounds like it wants to start the capacitor is blown.
Posted on Jan 10, 2009
SOURCE: LG td-c70040e tumble dryer Clean Filter indicator will not go off
There is an access flap below the door on the bottom left.  Open the flap turn blue levers, take plastic cover off (there may be a bit of water there).  Clean the inside.  Problem solved
Posted on Feb 14, 2009
SOURCE: LG dlg5988W Gas Dryer - flashing "clean filter" light
i got the same problem and no repair man could help . i think i just got mine fixed 6-15-09 .what you do is go behind the dryer , remove the air duct and then remove the pipe that is inside the machine by removing one screw . this will give you access inside the machine .first clean as much as you can of the lint inside by vacuuming it . if you look to the left you will see 2 wires with a black button in the middle this is the ignitor ,clean it good because i think the dirt is not allowing it to light up . i did that and mine is working but the cooling light is still on .
Posted on Jun 16, 2009
  • 11 Answers
SOURCE: everytime i turn on my lg tromm it says check filter
TRY TAKING OFF THE VENT HOSE AND RUN A CYCLE WITHOUT IT AND SEE IF IT DRYS FASTER....YOU MAY HAVE A CLOG OF SOME SORT IN YOUR WALL
Posted on Jun 23, 2009
SOURCE: front loading dryer
Wrong Richard-sorry- but had this issue. Check filter light would come on and I ignored it (after checking for built up lint) and now the dryer wont start. I pulled everything apart and it seems I had a duct loose inside letting all the lint inside the dryer. It was a warning I ignored.
Posted on May 02, 2012
SMART SENSOR SAYS CHECK FILTER BUT THERE IS NOTHING IN THE FIRLTER
It could be the vent hose in the rear is constricted. Check to make sure all hoses going in the rear are in good shape. Nothing constricted, nothing pinched, etc. If it's not that, check to make sure they aren't clogged.
Oct 09, 2012 | LG WM3987HW Laundry : Dryers :...
LG DLG5988W
check your door interlocks and connections
Mar 15, 2008 | LG DLG5988 Gas Dryer
I have a 5 year old LG front loading dryer, model # DJG2524W. When I went to start to dry a load, the dryer started, and then stopped after only a second or two. The check filter light was flashing. We...
Hi
I believe that everything else is fine rather it is the thermal fuse that is located inside the rear panel to the exhaust duct that is bad and should be replaced. If you want you can test this fuse for continuity and if it is bad then it should be replaced, as it cannot be reset. If the fuse is fine then it can be due to the control board that is bad and should be replaced. Hope this helps...please post back for further assistance.
Daniel
Aug 24, 2011 | Dryers
Electric front load dryer flashes check filter.
what is the indicator lights in the board means. The green light is flashing one flash in then going into lock mode.
Model# RGPJ 05 EAUER
Jan 29, 2010 | LG Heating & Cooling
Lg dlg2522w check filter flashing, motor spins,no
Did you put a load of wet clothes in the dryer and run it?
You can't change the setting while it's running.
The sensors won't let it heat up if there is nothing in the dryer.
This is not your grandmas dryer, this is a high tech machine.
There is probably nothing wrong with it.
Oh and the filter light flashes like that, it is supposed to, it is telling you to check the filter for lint.
Nov 24, 2009 | Zanussi FJD1666W Front Load Washer
I have a Maytag front load dryer. When you push start everything runs good except the gas won't kick on. I have vacuumed out inside between the walls and drum, removed the lint filter and shoved a...
first make sure gas is on then turn it on and look at the ignighter should be as brite as the sun if so you will here a click when tha gas is to come on and you get nothing then the coils are bad easy fix make sure you unplug it then unplug coils 2 screws that hold it down you can not put them in wrong
Jun 26, 2009 | Maytag Neptune MLE19PN Front Load Stacked...
Front loading dryer
The check filter light is just a reminder light and cannot be reset.  Nothing to worry about.  Just keep the filter clean before each use.
Nov 21, 2007 | LG DLG2524 Gas Dryer
Dryers Logo
Top LG Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
John Tripp
John Tripp
Are you a LG Dryer Expert? Answer questions, earn points and help others
