Question about Westinghouse Refrigerators
I have a Westinghouse fridge model number RP 432V-R it is leaking water out of the door coming from behind the salad crisper draw where there is a vent quite a significant leak wets all of the floor
HVACRH20
  • 237 Answers
SOURCE: Fridge Leaking water from front right hand corner
Most likely you're correct, the defrost cycle produces water that is supposed to be captured in a holding tray, pan, etc. If the pan is cracked it would leak out or if the drip tube (pipe) is not in place it would miss the pan. It may be easier to remove the contents of the small frige and tip it over some to see what you can down there. I assume this small unit doesn't have any water souce to it (no ice maker or water). Check the tubing for damage and see if you can find the holding pan to inspect for crackes, etc.
Posted on Nov 10, 2006
  • 108 Answers
SOURCE: Westinghouse Aurora Frost free fridge
You need to remove the clog in the drain line from the freezer to the condenser, Look under the fridge for the plastic drain line and blow it out or otherwise clear it, Then insure that the unit is level. Sooner or later you need to clean the freezer drain pan. After using up your frozen food, remove the back panels of the freezer and clean the area well.
Ray
Posted on Oct 29, 2008
SOURCE: there is a water leak
I am the original owner of camry xle 1998 with wet floors. In 2000 I had drivers side door seal leaking at welt. Removed old door seal and new weather strip on drivers side installed. The door panel was never wet, but wet at bottom of door where there are drain holes...slowly leaking under carpet.
In 2001 later water again. Coming from overflowing A/C evaporator-drain plugged/ tank full of debris. Removed evaporator, cleaned + drain cleaned.
In 2003, driver door seal against window rotted. Removed door panel and found leak at window belt molding at the mirror joint inside + out. Lots of mold under carpet needed to replace! Made a fuss at dealers for reacurring problem and they replaced the carpet for free.
Posted on Dec 09, 2008
  • 17 Answers
SOURCE: GE tfx22r leaks water out bottom of freezer door
defrost drain is clogged, remove back panel, and pour hot water down drain and blow it out with pressure of some sort until water passes freely
Posted on Nov 01, 2009
localwonder
  • 6784 Answers
SOURCE: kelvinator frost free fridge leaking, pooling
Your refrigerator has a drain that leads to the exterior drain pan beneath the refrigerator. Occasionally this drain can become clogged resulting in standing water inside your refrigerator. A similar drain exists in the freezer, which when clogged results in ice build up on the floor of the freezer.
The drain is located either on the floor of the refrigerator, beneath the vegetable crisper, or in the wall behind a drain funnel.
Clear the drain by forcing a solution of water and bleach or water and baking soda into it with a basting syringe. If the solution will not flow through, slide a length of ¼ inch flexible tubing into the drain tube to push the clog through to the drain pan. Remove the tubing after clearing the clog.
NOTE-(This may be a leveling issue as well)
It is important for the refrigerator to be level. If it is not level, doors may not open or close properly and may not seal tightly. Also, drainage from the defrost cycle might be impaired as might the ice making cycle. The appliance was engineered based on it being installed in a level position. While there may be some tolerance for out-of-level installation, the appliance will operate at its best when properly leveled.
Place a level on top of the refrigerator near the front. Do not put it on the door because the door may not be aligned with the refrigerator case. Check that the refrigerator is level from side to side. Next turn the level to check that it is level from front to back.
If it is not level, adjust one or more of the adjustable leveling feet until it is level. The feet are bolts that can be turned to raise or lower the refrigerator. If they cannot be adjusted with your fingers, use a crescent wrench or pliers.
If you have an ice-maker, it should also be checked for level after first leveling the refrigerator. An ice-maker that is out of level will spill water into the ice bin or into the freezer. It can be repositioned by loosening the mounting screws, adjusting it for level and then re-tightening the screws.
Posted on Jan 06, 2010
Testimonial: "Thankyou so much for such a quick reply to an Australian, can't ask for better service! I will try your suggestions which make perfect sense."
Hi I have Westinghouse freestyle 450 my problem is that no matter how low I have temp the begs freeze in crisper other wise been very happy I have had this fridge for 20years
fridge settings work in reverse to freezer settings
1 for a fridge is almost freezing where it should be around 4
cold air sits at the bottom of the fridge so the setting will be colder in the crisper draw that at the top shelf
May 26, 2017 | Westinghouse Refrigerators
Westinghouse fridge model number RP 432V-R it is leaking water out of the door appears to be coming from behind the salad crisper drawer where there is a vent
Freezer /fridge water/ice in fridge and or freezer, or leaks on floor
Usually due to CONDENSATION due to bad door seals or a plugged evaporator drain line? Can use a soft flexable tubing and very hot water to clean it out. Bad door seals usually need replacement, but u can use a blow dryer and something to pry it closer to the door wall while blowing hot air on to it. To create a seal, to test for bad door seals place a dollar bill in between the door and wall of fridge where it closes. Then slide out the dollar bill with door closed. It should offer some resistance and not be easy to pull out.
Fix any gaps in the door seal.Pack out the seal underneath the areas where the door seal has the gaps. This can be done with a small strip of weather stripping, as shown here, or a bit of tightly rolled up paper under the door seal. Alternatively, you can heat the door seal up with a hair dryer to fix the gaps. This softens the door seal and allows you to stretch it.
Most all fridges have a drain. Look inside your fridge for a "V" shaped channel with a small hole. This hole leads to a tube and a small pan which sits on top of your refrigerator's compressor. The defrost cycle causes water to run into the channel, down the tube, and then it generally evaporates with the heat of the hot condenser/compressor.
However, if that tube is clogged with food crumbs, particles , debris etc, you will have to clear it to get back to a normal mode of operation. A toothpick, pipecleaner, straw or a cotton bud can often do the trick. Another trick one can use is to connect a copper tube wire with one end going into the drain hole then attach the other end to the heater wrap it around heater a few times. That will take care of the drain problem when it comes to ice build up but not food build up.
Even a frost free freezer will still ice up at times in the areas away from the heated defrost area and the drain line can freeze. This icing causes the pipe work to the compressor to ice over or sweat and cause a puddle. Or if the drainage has frozen over, it will need to be de-iced. ( usually the line is under the freezer bottom plate covering. Towards the back of the unit) And there is another inside the fridge area also.
Give the freezer a good overnight defrost until it's totally clear of ice in addition to making sure the drain is clear to the pan at the back and then restart the freezer.
God is so good: so this is why I give free advice so please thank him not me.
Dec 26, 2016 | Westinghouse Refrigerators
I need a right hand crisper draw for a Samsung refridgerator model srf680cdls
Hello Kate Nicholas,
Your model srf680cdls... does not respond domestically in the USA... If you provide your ACTUAL PART NUMBER I could attempt to check CRISPER availability ... here (you appear to have an "AU" model.
Just looking around the large plastic body would appear to cost about $60 (USA)... I'm pretty sure we share the MANY of the same internal part numbers..
http://www.woolleys.com.au/?gclid=CPqQzujj184CFQYdaQod1n0AIw
BigWarehouse Spare Parts samsung crisper drawer
Sydney Only Samsung SRF680CDLS 680L French Door Fridge with Water and Ice...
http://www.ebay.com.au/itm/ws/eBayISAPI.dll?ViewItem&item=121998338668&catId=20710&item=121998338668&mid=503315&sdc_id=1081525136346&sortbid=15&rmvSB=true
Samsung 28 15 cu ft 4 Door French Door Refrigerator in Stainless Steel...
http://www.appliancepartspros.com/samsung-case-veg-assy-da97-08437d-ap5805507.html
Aug 23, 2016 | Samsung Refrigerators
Refrigerator leaks water
At the back either behind or above the salad crisper there is a groove leading to a tube which exits the fridge. The tube often becomes blocked and needs to be cleared. Don't forget to empty and clean the container the tube empties into.
Apr 16, 2016 | Amana Refrigerators
Can we get parts for proline fredge freezer model pf200w
You can get that part here:
http://www.partmaster.co.uk/proline/pf200w/salad-crisper/catalogue.pl?path=67607,126607:126606&model_ref=2008318&refine=salad+crisper
May 24, 2014 | Video Game Consoles & Games
Water line for ice maker/cold water leaking underneath
Check your connection at the bottom of the freezer door, behind the kick plate. Also pull out your crisper drawers and check the cold water reservior. If this only leaks when the water dispenser is pressed I would try to track the line from the bottom of the freezer door back to where it goes into the refrigerator (behind the crispers) to the cold water reservior.
If you absolutely have to lay this fridge down lay it on it's BACK only. Also be sure to let it stand upright for at least a half an hour before you start it back up.
Good luck with this!!
Jun 14, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
What is causing water to build up inside the refrigerator section? there is water in the crispers and on the shelves.
A condensation problem inside a fridge, normally means either, you are puting uncoverd food /or food that has a high water content (i.e.salads) into the fridge, which may be warmer than the inside temperature of the fridge, hence condensation(leaving the door open too long has the same effect)only remedy is paper towels in bottom of crisper so that salads dont go soggy.and wipe out fridge as often as needed.
Mar 10, 2010 | Whirlpool ES5FHAXS Side by Side...
Please reference SubZero Model No. 680. My
OMG DO NOT TAKE THE DOOR APART!!!!!!! The water line is not in the door. It comes from the valve on top of the unit into the fridge behind the control. Make sure that the drain behind the crispers isn't blocked causing your leak.
Jul 20, 2009 | Sub-Zero 680 / S
Replace door
The fridge should have come with a card that looks like a credit card to remove the handles.  There are directions in the manual on how to do this.  If you don't have the card then use a sturdy card like a drivers license.
Oct 26, 2007 | Kenmore 73502 / 73504 / 73509 Bottom...
Refrigerators Logo
Top Westinghouse Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Westinghouse Refrigerator Expert? Answer questions, earn points and help others
