Question about KitchenAid Dishwashers
Where is the filter in model 9741068H kitchenaid dishwasher?
2 Suggested Answers
How do we get to the filter to wash it
What is your model number. Some dishwashers don't have filters they have grinders and or "choppers" that grind the food and materials. If yours has a chopper then you more than likely do not have a filter
Apr 07, 2015 | KitchenAid Dishwashers
Dishwasher hums intermitantly and after the wash cycle is completed
Sounds like you have a bearing going out. It could be in the system pump or the rotating washing arms. I would suggest getting ahold of Kitchenaid's customer support and relay when during which cycle the noise occurs and they should be able to identify whats going wrong.
Jan 22, 2014 | KitchenAid KUDE70FXPA Builtin Dishwasher
Kitchenaid KUDI02FR fill time
most have a float switch and will not fill above that Time makes no difference to it all depends on the flow into the machine
Oct 31, 2017 | KitchenAid 24 in. KUDI02FR Built-in...
Our ten year old kitchenaid dishwasher doesn't get the dishes clean. there is food particles left on dishes if we don't completely rinse our dishes. is there a cleanout filter that needs to be emptied?
Locate your dishwasher's filter. It is typically on the floor of the dishwasher. Pull out the bottom rack and look along the bottom of the dishwasher until you find it.
Use a paper towel or sponge to remove any residue or debris that has accumulated on the outside of the filter once you locate it. On some dishwashers, the filter area does not detach or open, so your hand cleaning will stop here. On other models, you can unscrew the filter housing to access the inside and clean any debris from the filter area. Simply wash out the filter using soap and water, then reassemble once cleaning is complete.
Further clean the filter area by pouring a quart of white vinegar into the bottom of the empty dishwasher. Turn to a wash cycle and allow the dishwasher to run with the vinegar cleaning the mechanisms, including the filter.
To deep-clean your dishwasher and the filter periodically, mix the following ingredients together in a bowl, then pour into the bottom of the dishwasher: 1/2 cup salt, 1/2 cup baking soda and 1 cup bleach. Let the mixture sit in the bottom of the empty dishwasher overnight. The next morning run a wash cycle, letting the bleach mixture clean and disinfect the dishwasher thoroughly.
Aug 29, 2010 | KitchenAid Dishwashers
How do you remove the lower spray arm for a kitchenaid dishwasher, model KUDP01ILBS6? I want to clean out the filter and mascerator.
I have put together instructions on how to clean out the sump area where the mascerator is on your model. Follow the link below and let me know if it is what you need.
KitchenAid Cleanout
Jun 21, 2010 | KitchenAid 24 in. KUDP01IL Stainless Steel...
Water is not coming out of the top water jets for dishwasher
What is the model of this KitchenAid diswasher and approximatly how old is it? On some newer, energy saving models water is alternated from lower to upper spray arms. But ...
Remove filter that is in the sump area beneath the lower dish rack. Screws will need to be removed to open the area up. Look for blockages and clean filter.
Reassemble and test. If problems remain, it is probably a failing pump motor and will require a service call.
Mar 30, 2009 | KitchenAid Dishwashers
Dishwashers Logo
70 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
