Question about Insignia NS-PDVD10 Portable DVD Player
What does the AV cord look like for hooking up a laptop to a NS-PDVD10 to play movies
SOURCE: insignia NS pdvd10
Unlock
Insignia NS pdvd10
It`s really works
1) On the remote control type "SETUP" button
2) Select "PREFERENCES" in the menu with
3) Validate it with the button "OK"
4) Enter the code : "224455"
5) With the direction keys type:
a) Left key : < (Nothing happens)
b) Down key : v (a menu appears on the screen
with all region)
6) Select the Region : 0 (all) with the direction keys
7) Validate it with the button "OK"
8) Finish the process by typing the "SETUP" button.
Posted on Oct 03, 2008
Unlock
Insignia NS pdvd10
It`s really works
with all region)
  • 98 Answers
SOURCE: portable dvd player insignia ns-pdvd10 screen problem
Check the screen switch on the right top side where the door closes there is a little circle and the release switch usually gets jammed (this is a common defect) you will need a small thin flat head screwdriver to pry out the switch.
Posted on Nov 07, 2008
John-INSG
  • 312 Answers
SOURCE: Insignia NS-PDVD10 Speaker Volume Control
The volume control is on the right side of the player, closest to the front. A copy owner's manual can be downloaded here; select the Support tab. I hope this helps!
Posted on Jul 28, 2009
localwonder
  • 6784 Answers
SOURCE: Plays CD but not DVD, says no disc
HI.This will occur when the optical assembly becomes unstable. this ((Whole One Piece)), assembly incorporates the spin/load motor, optics housing /arm, tracking device and tracking rail. This is connected to the loading dock assembly. This 'NO Disc' or CD NOT PLAYABLE, code is the result of a failed or burned out lens. It is possible that you have a dirty lens cap. you can try using a cleaning disk in this case to confirm actual lens failure. if the cleaning doesn't restore normal reading capabilities, this will confirm my diagnosis.
You will need to have the optical assembly replaced in this case. once replaced, your unit will be able to read and track once more.
Posted on Aug 13, 2009
How can i hook my dvd player to my flat screen to watch a movie that we all can see
Connecting this up will be easy. What you do is get a yourself a set of the right, for your setup, cables. That uses EITHER one of the formats, of these described, below. You will need, either, a THREE way Cable, or three separate " Coaxial Cored" Cables with RCA PLUGS on them. ColoredYellow, (Video) Red, & White. (Audio) AV. OR If you have SCARTConnection Sockets, it's a big Black Socket at rear of unit(s), you get aSCART Cable.& It's all inside. Now some units, use a standard calledComponent Video, that uses, a Green, Red, & Blue Plugs. Now, with the Component setup, you will also ,need, Two more Cables, for the AV Audio. these are, Red & White.(So with Component Video there are 5 Cables/Plugs in all). In any event ALL Cables go Color to Color, at each end, plugging into the corresponding Colored RCA Jacks, on either machine, or VCR or TV. Now if you have SCART, then it simply plugs in only one way. It is that simple. So connect up with the leads your set uses, and select the correct "Input" from TV/Remote, it is NOT on a "Channel" it will be on AV, AUX, and Press "Play" on VCR/DVD whatever.... should be all go.
Mar 02, 2010 | Insignia NS-PDVD10 Portable DVD Player
No disc fault appears on screen of model insignia ns-pdvd10. Am I able to correct this problem?
Ensure that the disk is clean. The player may not play a disk if there is internal condensation; leave the player on for an hour. You may wish to try a lens cleaner. If these steps don't resolve the problem, repairs may be required. Service can be obtained by carrying the unit in to the place of purchase.
Dec 25, 2009 | Insignia NS-PDVD10 Portable DVD Player
I have Insignia PDVD10 portable DVD player. So
Press remote button audio track. That solve my problem.
Jul 04, 2009 | Insignia NS-PDVD10 Portable DVD Player
I am looking for the book of instructions for the Insignia NS-PDVD10 player.
check the manufacturer's website:
http://insigniaproducts.com/
You will find the manuals in English, Spanish and French:
http://insigniaproducts.com/products/dvd-players-recorders/IS-PDVD10.html
Jul 01, 2009 | Insignia IS-PDVD10 Portable DVD Player
Insignia NS pdvd10
Unlock
Insignia NS pdvd10
It`s really works
with all region)
Feb 26, 2008 | Televison & Video
INSIGNIA NS-PDVD10 Problem
I have a NS-PDVD8 . I purchased DEC 2006. I used it in April 2007 and then again in Jan.2008. When I went TO use March -2008 I received message NO DISCwhen attempting to play DVD.i messed with for an hour by rebooting and and dusting with compressed air.No help
next day I tried a CD and after very long loading time played music.
after I let it run for an hour I attempted DVD but same response.NO DISC
I cleaned the optical lens with a damp soft cloth and dried with soft cloth ( I do not recommend using a cloth but I was fed up and needed the player for flight next day) I believe you can purchase a cleaner kit.
I also ran the lens back and forth 5 or 6 times to make sure it could move fully along track.I heard clicking and wondered if this was ever going to run again.
I tried a CD first and the Cd loaded almost immediately and played
Next I tried a DVD and loaded successfully and played entire movie.
I turnred on and off about 10 times and reloaded movie without any problem.
Jan 23, 2008 | Insignia IS-PDVD10 Portable DVD Player
Insignia NS pdvd10
Unlock
Insignia NS pdvd10
It`s really works
with all region)
Jan 09, 2008 | Insignia NS-8PDVD
Insignia NS-PDVD10 Portable DVD Player Logo
20 people viewed this question
Top Insignia Televison & Video Experts
Jaime Hernandez
Are you an Insignia Televison and Video Expert? Answer questions, earn points and help others
