Question about Ice Cream Makers
I have watery diarrhea what causes that i haven't eaten hardly anything except a mince pie & a little cream
    Habit-Forming:
    New Friend:
    Welcome Back:
    Visited the website for 2 consecutive days.
HAVE YOUR DOCTOR TO GIVE YOU.. DICYCLOMINE 10 MG WORKED WELL FOR ME.....
Posted on Dec 26, 2016
Do you have a service manual for the Taylor Model 702?
being a fellow fixya guy, you will know that fixya does not have anything except advice
go google and type in --service manual for taylor model 702--and look for a pdf version
Oct 03, 2016 | Taylor Ice Cream Makers
Will not turn at all just makes humming noise
I had one do that and I opened the gear box and found that the last time we made ice cream & it started getting hard the motor caused the gear to pop a tooth off (plastic). so now you hear the motor running but no transmission. Take it apart and check or turn the ice cream tub connection socket 1/4 turn and see if that makes a difference.
Nov 18, 2015 | Cuisinart Ice Cream Makers
Do you refrigerate a pie made with a sour cream topping
I've made a lot of apple pies and normal ones can be left out. Never made one with sourcream.
Sep 08, 2014 | Ice Cream Makers
Maverick ice cream shoppe
I have one and a working unit all except for the freezer bowl. That corroded.
Jun 07, 2012 | Maverick MIC-001 1 Quart Ice Cream Maker
I plug it in and nothing happens with the motor, no hum no nothing on ice cream maker 8550 been sitting for a year and not abused. is there a switch ? the thing will turn by hand , or is there a safety...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Aug 23, 2011 | Rival 8550-X 5 Quart Ice Cream Maker
I loaded the machine with mix and turned it on but machine keeps on turning but mix is still very watery
My small Business had this same problem. The first thing you need to look at is the product you are using. It turns out that if you are making your own soft serve. which Includes water and powder, it will save you a lot of time and stress to switch to cartons of soft serve that you just pour right in. It turns out that there is no consistency in powder icecream. the water will eventually separate from the mix, resulting in watery soft serve once dispensed from the machine. Next, if this isn't the prduct you are using then it can be other problems such as your compressor not working, or turning on when it's suppose to, maybe you have a weak motor, or your machine isn't set to the proper freeze level, Also, make sure that your machine isn't backed up against a wall or I between two other machines. These machines need to Obsorb cool air in order to work properly and not overheat . The machine's fan, which is located on the right side, needs to be have a certain amount Of space from walls or other machines. If this doesnt work you can always call a technition to come and check out the machine, I hope this helped, best wishes with your repair
Jul 16, 2011 | SaniServ 401 20 Quart Ice Cream Maker
The ice cream is granular in texture-
Hello!
I actually own the same ice cream maker, and it has made some very good ice cream for me. The most likely causes of grainy ice cream are too short of a time in the machine or recipes with incorrect proportions of water, fat, and sugar.
Firstly, make sure that you are using one of the recipes provided in the maker's user manual, or a different recipe from another source which says that it works with all ice cream makers. Following these recipes will ensure that your ice cream base (the liquid that you pour into the machine) is the correct consistency and composition for freezing. For example, too much sugar could cause improper freezing by oversaturating the solution, or too much fat (or fat incorporated incorrectly) could cause the mixture to become grainy or separate.
If you are using a recipe that calls for eggs, make sure that you mix them with the listed amount of sugar thoroughly before tempering them with the hot cream/milk solution. Additionally, make sure that you only pour a little bit (quarter - half cup) of the solution into the egg mixture at first, stirring thoroughly, before adding the rest. This assures that the eggs do not curdle when heated, which could cause a grainy texture.
Finally, make sure that you are freezing the mixer bowl overnight, using chilled ingredients, and allowing the machine to run for the full 20-25 minutes. The ice cream should be a bit softer than the consistency of soft-serve when you take it out of the machine - easily scoopable with a spatula. If you like it firmer, an 8 to 48 hour freezer session will greatly improve the texture in my opinion.
Hope this helps!
Mar 19, 2011 | Cuisinart (ICE-20) 1.5 Quart Ice Cream...
My ice cream churn just spins the lid and does not turn the canister. The only thing that is different is that the lid does not seem to come to a halt when I place it on the cannister and turn it. There...
maybe you have a super strong husband who tried a little too hard to loosen the lid once and now it won't seal or catch. if he is equally smart as strong maybe he could get some sort of gasket type idea going with the lid or something else ingenious. but it sounds like that might not be up his ally as much as throwing it across the room. could you try buying a new lid since everything else is working well? maybe the lord is telling you to get more iron in your diet and less ice cream? ha!
julie j your beloved daughter
Aug 18, 2010 | Rival F69206 6 Quart Ice Cream Maker
Out of stock
I have an 8401 4 qt and have used it for several years. The dasher broke on Memorial Day, and I just bought another 8401 on Ebay for $14.99 plus shipping.
Anyone who would like to have parts from my old one: contact me here and I give you 1 or all parts for the shipping cost. I have everything except the dasher and the instruction manual. I will also share my family recipe for vanilla ice cream - FREE!
My older model is about 5 years old and has had moderate use. It DOESN'T look brand new! :)
Paul in Texas
Aug 18, 2008 | Rival 8401-M 4 Quart Ice Cream Maker
Ice Cream Makers Logo
410 people viewed this question
Top Ice Cream Makers Experts
Dennis Boxerman
Andrew Taylor
Andrew Taylor
Are you an Ice Cream Maker Expert? Answer questions, earn points and help others
