Question about Watches
Need a link for my watchband or a new band?
Band is to small
  • 2,290 Answers
Go to a jewellery store and ask. If its worth repairing they will fix it. Get a price first as some watches you can buy cheaper than just a band.
Posted on Dec 26, 2016
I need to adjust my Style&Co SC1325 watchband, what can I do?
Your picture clearly shows the small arrows (on the inside of the band) the way the watch band pins need to be removed. You'll need a very small needle and a small hammer to drive the pins out in the direction of the arrows. Remove links evenly on both sides so the clasp is centered.
Once you fell you have removed enough links to fit your wrist, drive the pins back in reverse direction from the arrows, and set them smooth to the touch. If you can push the pins in to the hole just beneath flush, with your needle and hammer, it'll keep the pin from snagging your sweaters.
If all else fails most jewelry stores charge less than $10 to remove links. Have fun. It's not hard.
Jan 23, 2015 | Watches
The clasp on my steel watchband pulls away from the band creating a large gap. it looks bad and catches on things. what do i do?
You need to make sure that if you had the watch band adjusted they did not adjust it at the clasp. When you adjust the watchband links should be removed if you adjust it at the clasp the band keeps pulling open. When you open the clasp fully make sure the pins are on the end holes. If the pins are in the end holes then, the clasp is probably sprung somehow and you will need a new one or have a jeweler or watch repairman fix it! You may also be able to order a new clasp from manufacturer! Hope this helps!!
Sep 21, 2011 | Watches
How to shorten watchband
It all depends on the style of the band.
Go to where the links are all the same size, not tapered at all.
If you have a stretch band, along the edge, unbend the flaps that hold what look liks tiny staples. Pull out what you need removed and put the remailing pieces together.
If you have a non-stretch band, grab a SMALL paperclip about 1/8" from the end. Along the edge of the band you will see the pins that hold it together. Have someone hold the band with the bottom edge of the pin you are removing, over an opening. Between 2 hardback books wirks great. Tap the pliers to drive the pin partially out. Pull it out and do the same to remove as many links as needed. Put the pins back in, in the same direction they came out, from the same side they came out.
Dec 28, 2009 | Seiko Watches
How do i change watchband for casio bg169wh
Take the watch with the broken watchband and place it on the table. With a ruler, measure the width of the broken band at the point where it is attached to the watch. Now, measure the total length of the watchband when it is in one piece and fits around your wrist. There will be a crease on the band where it is normally buckled.
  • Step 2 Go to the local store and select a band that you like. You should make sure that the width of the band at the point of attachment to the watch is the same as the old band. Also make sure that the new band will be long enough and not too long to fit your wrist. Purchase the band and return home to change the band.
  • Step 3 Clear a spot to work and make sure that there is a small towel covering the table top so that you can see anything that may drop or pop out during the process of changing the band.
  • Step 4 Use a magnifying glass to look at the point where one side of the band is attached to the watch. You will see a small pin connecting the band to the watch on either side of the band. Carefully use the jeweler's screwdriver to depress the spring loaded pin from the watch to the band and release it from the watch. When the tension on the spring pin is released it may pop out of the band and you will want to take care not to lose it. Repeat this process with the other half of the band.
  • Step 5 Take the new band and slip the spring pins into the small holes on the end of the band where it will attach to the watch. Working with one end at a time, slip one side into the pin hole in the watch body.
  • Step 6 Use the jeweler's screwdriver to depress the other side of the spring pin and guide it into the pin hole in the other side of the watch body. Repeat this process with the other half of the watchband and other spring pin. You now have a new band for your broken one.
  • Jun 20, 2009 | Casio BabyG BG169WH3V (Size: ) Watch for...
    How do I shorten the watchband to fit my wrist?
    If you turn the band inside out...and stretch will see either 2 or 4 small tabs per section. Use a jewelers screwdriver to lift up each tab per section and slide that section out. Now it will be easy to take other sections out as you won't have to maintain pressure on the band. Reassembly is reverse order.
    Apr 24, 2009 | Watches
    Where can I get a new band for my LaCrosse Radio Controlled Watch
    Follow this link and choose whatever you want:
    Rate me, please.
    Mar 20, 2009 | Watches
    Versace watch
    call an authorized retailer in your area and they will be able to order a band for you. Here is a link for the website
    Sep 22, 2006 | Versace 27473-008-00 Wrist Watch
    Watches Logo
    19 people viewed this question
    Top Watches Experts
    Ansel Alberto
    Ansel Alberto
    Are you a Watch Expert? Answer questions, earn points and help others
