Question about Vacuums
I replaced the belt but as soon as I start the vacuum I smell burning and the belt is broken?
    Top Expert:
  • Vacuums Master
  • 40,473 Answers
The brush roller is clogged with debris and unable to rotate. Because of this, the new belt was unable to move and the motor shaft spun in one place until it burned through. The brush roller has to be removed and disassembled to allow the end caps to be cleaned inside.
Posted on Dec 26, 2016
  • 10 Answers
SOURCE: smoking belt
Belt is slipping because the bearings on the beater brushes, which it turns, are jammed or full of dust.
Alternatively the belt has stretched after being overheated and needs replacing because it now slips.
Posted on Dec 31, 2007
  • 30 Answers
SOURCE: Burning smell and smoke
I ran into a scenario similar to this at work. With the burning smell and smoke combined, it leaves only one problem remaining; the motor. The motor and the pulley that enables the belt to spin could be malfunctioning (causing friction between the 2 parts) and thus causes the burning smell and the smoke. I'd highly advise not to touch either part after having the unit on (YOU WILL BURN YOURSELF).
The only other likely possibility is to make sure there aren't any hairs caught in or around the motor and the bearings of the agitator.
Posted on Mar 08, 2008
  • 1554 Answers
SOURCE: burning smell
Unlock the sweeper brushes and take them out. on each end is a cup bearing and should be free of debris.
then check around and under the belt and likely there is debris wrapped around it.
the post is getting hot as your pulling too much of a load.
though if it continues the motor may have a bad set of motor brushes (inside the motor) or bad wiring (kinda unlikely).
Posted on Apr 01, 2008
  • 6 Answers
SOURCE: Kenmore Elegance Upright Bagged Vacuum Belt Broken and Smelling
It sounds like the brushroll has caused your belt problem and will be the cause of your burning smell as well. What commonly occurs is that carpet fiber,hair,string, thread,etc got wound around the brushroll and some will get caught in the end caps which is where the bearings are.The end caps need to be removed and cleaned so that the bearings can allow the brush to rotate freely.Check that there is no melting of the end caps or the base plate where the end caps fit into the machine._Good Luck
Posted on Oct 26, 2008
SOURCE: Dirt Devil Reaction Vacuum belt replacement
The manual is confusing - I had the same problem. Make sure you put the belt around the smaller motor axle, not the lever arm attached to the on/off foot switch. It's a bit counter-intuitive, but that was my problem with this. Jeff
Posted on Jan 15, 2009
Why are the belts burning and the brush not turning?
Check the ends of your brush roll. Most have bearings on the end and if one of those is locked up and will not turn it will burn the belt. Sometimes hair will get in the bearing area and will contribute to the bearing locking up.
May 14, 2014 | Hoover U5780-900 Windtunnel Cyclonic...
Burning smell
Something may be keeping the brush roll from spinning freely which may have caused the belt to break.
Jan 02, 2014 | Electrolux Central Vacuum
Eureka burning smell
Hi, it's Cindy from Crucial Vacuum.
Since you have replaced your Eureka 4870MZ 9200 Proheat 2x vacuum's belt, the issue may either be caused by your roller or the position of your belt. It sounds like as soon as your vacuum is lowered, the belt is either slipping or wear on the end caps is causing your roller to stop. This will cause the burning smell since your motor is now straining against the abrupt stop. Try taking off your roller and checking the conditions of the end cap or try to reinstall your belt. I have included an instructional video:
You can purchase direct your replacement brushroll from Crucial Vacuum with free shipping and an exclusive 10% coupon for viewers, use code: FIXYA10
I hope this was helpful. If you would like further assistance, please feel free to give us a call at 877.750.9239. We have helpful and friendly customer care representatives on the line ready to assist you.
Cindy Yuk
Crucial Vacuum Customer Care
Apr 20, 2013 | Eureka The Boss SmartVac Upright Vacuum...
I have the G series Kirby silver vacuum, I was vacuuming and started to smell some burning. Looked down and my green light was off also. What could it be? PLS HELP
Your belt is burning and will eventually wear down and break. The green light comes from copper brushes on your roller creating an electrical current that lights the little green light. As long as the roller is turning, the light will stay on. There may be something jamming the roller (hair, string, paper, etc). Clean the roller off and replace your belt. If you don't replace the belt it will break soon enough. Once you start smelling the "rubber burning" smell it's and indication that your belt has deteriorated at some point and has a weak spot in it. Clean the roller and replace the belt and it should be fine.
Apr 20, 2013 | Kirby Ultimate G Bagged Upright Vacuum
Work well but smell like a burning belt
If it smells like burning rubber, the belt is probably worn and slipping. If it's another burning smell, your motor windings are probably shorting and will burn out soon
Oct 12, 2010 | Rainbow E series Canister Wet/Dry Vacuum
Buning smell whenever I use my vacuum
If it's a rubbery burning smell, check the belt for the beater, it could be rubbing on the sides or even broken.
Jun 22, 2009 | Eureka 2961AVZ Bagless Upright Vacuum
Burning smell coming from vacuum
use a penny to turn the 2 screws on top a quater turn then fold down the vacuum and lift up the cover and you will have access to the belt. Clean the small hepa filter with soapy water. their may be 2 of them. The cannnister filters need to be shaken but not washed. Good luck.
Apr 09, 2009 | Hoover U5753-900 WindTunnel Bagless...
Brush froze up and keeps breaking belts
I had the same problem but I found that I had replaced belt incorrectly. After placing one end of belt around pully, it has to be run behind the "belt disengager" which looks like a 1/2" wide metal tab just past pulley. After placing belt correctly I had no more belt, burning smell or brush problems.
Feb 25, 2009 | Bissell Upright Vacuum - The Pet Hair...
The belt is broken of my dirt devil
Remove brush roller and black caps at each end of the roller. Clean and oil the bearings.they must turn freely.
Dec 10, 2008 | Dirt Devil Vision Turbo W/Bonus Upright...
Smells of burning
You may either have something caught up in the under part of the vacuum or the belt may be broken or partially broken causing it to smell like that. Try laying the vacuum flat on its back and plugging it up. Then turn it on and see if the brushes spin and if they do not, then you will need a new belt which is not expensive. Then check the bristles and the thing that holds up the bristles to see it there are any strings caught in them causing it to smell of burning. Take the strings out and then try it. It should stop smelling of burning.
Oct 31, 2008 | Vacuums
Vacuums Logo
27 people viewed this question
Top Vacuums Experts
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
