Question about Cell Phones
Dysentery Mot?rhead does not hold charge for longer than 8 min. It is being fully charged before use. What would be the reason for this?
  • 16 Answers
SOURCE: showing not charging display on screen when we hold for charging the mobile.
cause of the fault sometimes is in the charger it might not compatible with your phone try to use another charger, if the fault remain, refer it to service personel, I suggest it is the charging pin problem try to replace it, or maybe in battery terminal should fix the contact to battery.
Posted on Jun 24, 2007
  • 7752 Answers
have the firmware reflash on the phone this should correct the issue that you have had with the phone.
Posted on Mar 28, 2008
SOURCE: LG Chocolate
dont listen to the other guy you would not get three batteries wet unless your dumb... it is probably a cracked circuit board in your phone
Posted on Dec 15, 2008
  • 70 Answers
SOURCE: razor v3 wont charge is there anyway to fix the problem
It seems like you need a new battery, you can get a replacement one for cheap on Ebay.
Posted on Feb 26, 2009
  • 762 Answers
SOURCE: my battery is not getting charged and saying
Try take out battery for 30 min then insert it back but DON'T turn the phone ON and plug the charger in.
Posted on Oct 15, 2009
Usually an old (or older) battery will no longer hold a charge ... or will only hold a small charge (that will let you run the GPS for only a few minutes).
Often, when the TomTom device is always connected to the charger (in a vehicle), where it charges every time the car is turned on, whether the TomTom is being used or not, the battery gets charged (partially or fully) often enough to use up the "maximum number of charge" cycles for the battery. Hence, it will no longer charge properly or hold a strong charge.
Like for all lithium batteries, it's better if your device is not always connected and being charged (whether you are or are not using it). The battery will last longer and it will still be able to hold a stronger charge.
Feb 24, 2016 | Tomtom GPS
My kindle will not hold a charge for more than one day even after it has been fully charged
your battery is gone need new one when u charge your battery then it dies and this happens a bunch of time it is fryed cause when it is charging it heats up if it is holding for a day all may not be lost my kid leaning over my shoulder and hitting my last nerve just told me if u can get the battery out safely to put in the freezer for about ten mins make sure it fully charged and ONLY THE BATTERY gos in the freezer that battery will last a bit longer but its not a perment fix it gives u time for pay check or whatever reason to get it fixed oohhh my child has one more input to air out NEVER play on it or anything like it when it is charging that makes it heat up more and faster to killing a battery and never over charge does same thing good luck
Aug 11, 2015 | Amazon Kindle Fire HD
Why doesn't the motorola P4000 not hold a charge after charging it for several hours
Your battery is shot. Rechargeable batteries only last so long.
Feb 08, 2015 | Motorola Cell Phones
Lglp-ahmm sbpp0027708 sbl dc100725 battery in lgcx9200 cell only holds charge for about 10mins is there any way to force charge or reset the battery?
Under normal useage, the battery should hold a charge for at least an hour. Usually a lot longer depending on what your doing. However, the internet will kill a battery within mins! So keep your phone plugged in while your on the internet and even while doing other things until its fully charged. Shut your phone off when you go to bed and plug in the charger. Then unplug it when u wake up. If your battery still gives u severe problems, the battery cells may be totally dead or defective, in which case you will have to buy a new battery.
Jul 20, 2011 | LG VX9200 enV 3 LGLP-AHMM BATTERY
Can you tell me why my ku990 battery is so bad it only holds its charge for about 8 hours & if i make a call for about 3 mins it almost zaps it
yes i had the same problem with mine. its a quite common problem with all mobile phones. It happens because of irregular charges i.e. not charging it fully.
A replacement battery will fix this no problem you can get a compatible one of ebay for less than £5
hope this helps
Jan 19, 2010 | LG KU990 Viewty
I turn it on, logo comes on, and it turns off. I've tried holding the on button 8 sec, no luck.
With the limited information provided, a simple first step is to make sure the internal battery is either fully charged or is in a condition to accept a charge. When the internal battery's charge is allowed to below a certain level, it will no longer be capable of accepting a charge via the car charger.
The battery can be conditioned to accept a charge easily, however. This is done by connecting the GPS to the computer via USB port, NOT the car charger. Some Garmin GPS units come with a 120 volt charger that connects to the USB port of the GPS - this method is also an acceptable charge / condition method. Leave the GPS connected for 8 hours or longer (over night) and try to power up again.
I hope this helps!
Oct 24, 2009 | Garmin nuvi 205W GPS Receiver
Xantrex PowerPack 300 will not hold a charge
Machine no longer takes a charge. Light remains yellow, if you plug anything in there's not enough power. Any suggestions? Purchased XPower Powerpack 300 Plus from QVC appx. 6 - 8 years ago.
Mar 28, 2009 | Xantrex Technology Xantrex Xpower...
Cell Phones Logo
21 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
