Question about Canon CANNON IR 3530 COPIER FOR 220 VOLTS ONLY
E000732 0001 error in ir 3530 how can i solve
    Habit-Forming:
    New Friend:
  • 25 Answers
Official instructions from Canon are these, try if it works for you:
Solution 1:
  • Check all the cables outside of the printer: they must be plugged, especially between the differents elements of the copier:
  • Solution 2:
  • Check all the connectors on the main board.
  • Solution 3:
  • Unplugg and replugg all the leads between the boards and modules
Posted on Dec 29, 2016
  • 56 Answers
SOURCE: ERROR c-6000
Hi, enter 10871087 on keyboard of machine, then enter 163.After that press "execute" and start button.machine will restart and will be ready to copy.Otherwise,call service.
BR
Posted on Jan 27, 2008
canontech
  • 1219 Answers
SOURCE: canon ir 3530
E000 fixing overheating
E001 fixing assembly overheating
E002 fixing assembly low temperature
E003 post-standby fixing low temperature
E007 fixing film rotation error
E010 main motor rotation error
E014 fixing motor rotation error
E019 waste toner case full, waste toner case full sensor error
E020 toner clogging between sub hopper and developing assembly
E024 developing assembly connector disconnection
E025 hopper motor, bottle motor error
E032 NE controller counter error
E064 power supply voltage error (high-voltage)
E100 BD interval error
E110 scanner motor error
E191 communication error for high voltage power supply
E202 CIS home position detection error
E225 CIS light intensity error
E227 reader unit power supply error
E248 backup memory error
E261 zero-cross signal error
E315 image data error
E400 feeder communication error
E490 wrong DF type
E500 finisher communication error
E503 finisher internal communication error
E505 finisher backup memory error
E514 stack delivery/trailing edge assist motor error
E519 gear change motor error
E520 off-set motor error
E530 rear alignment error
E531 stapling error
E532 stapler shift error
E535 swing error
E537 front alignment error
E540 stack tray ascent error/upper tray ascent error
E542 lower tray ascent error
E577 paddle error
E584 shutter error
E590 punching error
E591 puncher dust sensor error
E592 punch horizontal registration sensor error
E593 punch shift error
E5F0 saddle paper positioning error
E5F1 saddle paper folding error
E5F2 saddle guide error
E5F3 saddle alignment error
E5F4 saddle rear stapling error
E5F5 saddle front stapling error
E5F6 saddle butting error
E5F8 saddle connector error
E5F9 saddle switch error
E602 hard disk error
E604 image memory error/shortage
E609 hard disk error
E610 herd disk coding key fault
E674 fax board communication error
E710 IPC initialization error
E711 IPC communication error
E716 communication error for pedestal/ communication error for 3-way unitA1
E717 communication error for NE controller
E719 coin vendor error
E730 PDL software error
E732 scanner communication error
E733 printer communication error
E740 Ether board error
E743 DDI communication error
E744 language file/boot ROM error
E745 TokenRing board error
E746 accessories board wrong model error
E748 controller board and SDRAM size mismatch
E805 fan error
Posted on May 04, 2010
SOURCE: cannon ir 3530 all error
Code Error name/description
Posted on Mar 03, 2011
muleskinner2
  • 270 Answers
SOURCE: I am using Canon IR
I had the same problem on a IR-2230 and I had to replace the Developer Assembly. Check the connection first - have you recently had this worked on?
Posted on Jun 22, 2011
ganggawangsa
SOURCE: SYSTEM ERROR
error 610 machine kyocera km-3035 ????
Posted on Nov 28, 2012
JAM ERROR 0207 ON CANON IR 3530
Open the printer and remove the paper jam.
Dec 04, 2014 | Canon CANNON IR 3530 COPIER FOR 220 VOLTS...
Sir i have cannon ir 3530 xerox machine that shows 002 my cell no 9833273003
fuser temperature not rising....try to reset in service mode * 28 *, function, clear,err
Dec 12, 2013 | Canon CANNON IR 3530 COPIER FOR 220 VOLTS...
Display touch is very hard
my printercanon ir 3530 insaid disply was rain water in said but how to open and cleen the disply bord tuch screen
Dec 15, 2012 | Canon CANNON IR 3530 COPIER FOR 220 VOLTS...
CANON ir 3530 finisher error
canon ir 3530 shows finisher error (displays spanner)
Nov 10, 2012 | Canon gpr-16 ir 3530 blk...
I am using Canon IR 3530 the error code is E000024-0001 please help
Mar 07, 2011 | Canon imageRUNNER 2000 Copier
Cannon ir 3530 all error code and solution
Mar 03, 2011 | Canon ImageRUNNER 3570 Copier/Printer
What is the meaning of BD cycle out of range
Hai iam mahesh form india : umae4umahesh@yahoo.co.in
to solve this probllem remove laser unit and clean surface the polygon motor its not to free run and clean the in side mirrors
thankyou
Jan 13, 2011 | Canon iR 2016i Black and White Copier
Canon ir 2830 error code e 490
SIR CONON IR 2830 COMPUTER SE ATTACH HO SAKATI HE
Sep 03, 2010 | Canon IMAGERUNNER 3530 Copier
ERROR c-6000
BR
Jan 26, 2008 | Kyocera RI-3530 Black and White Copier
Canon CANNON IR 3530 COPIER FOR 220 VOLTS ONLY Logo
35 people viewed this question
old marine
old marine
