Question about HP LaserJet 1300 Printer
  • 10 Answers
SOURCE: hp 4250 paper jam erro
Is it a new or refurbished fuser? Where exactly does it jam. By trays, registration or before fuser? Problem can be with various sections. Need to know more.
Posted on Feb 13, 2008
  • 138 Answers
SOURCE: HP 1300 LJ Fuser Film
If you didn't have the orange light to start with and were replacing the sleeve due to a torn or damaged sleeve it sounds like you haven't plugged everything back in. The Error is an electrical fault with the fuser circuit.
Verify that all wires are plugged back in. Two areas to pay specific attention to are as follows. (1.) BOTH slide clips witth wires that you removed on the upper fuser edges to mount the new sleeve. Thats the connections for the ceramic element. If you get to having to uninstall and check the fuser, put an ohm meter on both ends of the element to ensure it's not shorted. My meter when on ohms has a beep when the leads are touched together when the meter is measuring ohms. Check for the beep when touching both ends of the element and that will prove the element good.
(2) On the board in the base of the machine, there are some plug in connections on the lower board very close to the rear edge and just about centered left to right. It's a cluster of about 3 or 4. Unplug the connections and pay close attention to the height of the pins inside the connection. One of those connections has a nasty habit of the pins slidding through to the other side and not making good contact. If I remember right its the right hand connection in the cluster or the one next to the right one. You can use the connections rest to it as a visual referance for the height. If the pin or pins have pushed down, carefully pull them back up with needle nose pliers or tweezers and replug the connection back in.
Hope that helps you. Just in case, heres a free manual PDF link to use to resolve. It's a 1200 manual as the 1300 wasn't listed but the processes are identical. Most of the parts are the same but check first before ordering any parts.
Posted on Aug 04, 2008
  • 1314 Answers
SOURCE: Fuser Assembly damaged by user trying to remove paper jam.
This is one of those that is not quite so easy. I have uploaded the service manual for you. You may download it here.
Thanks and please take a moment to rate this solution as fixya as I have taken the time to upload the manual for you. Good luck!
Posted on Feb 14, 2009
  • 2035 Answers
SOURCE: hp psc 1400 inkjet fix, paper jam
Please try these steps :
1. Turn the printer off and open the access cover.
2. Look for any obstructions in the paper path and remove them if necessary. (It is possible to move the carrier assembly with the power off.)
3. Turn the printer on, load some paper, and press the Form Feed button.
4. Watch the paper as it feeds through and try to determine where the jam is occurring.
5. Check to see if all the rollers are turning.
If all the rollers are turning, there may be something in the feed path that you can't see. Go to step 6.
If not, there is probably a feed motor or a gear problem and the printer may require service.
6. If the paper is jamming under the carrier assembly, you may be able to fix it using the manual feed slot.
7. Turn the printer off.
8. Take a #10 envelope and feed it through the left side of the manual feed slot until it comes right through the printer to the back of the exit rollers.
9. Move it up and down first, and then slowly move it over to the right side. If something is stuck under the black guide plate, this may work it loose.
Posted on Feb 27, 2009
SOURCE: HP laserjet 5500dn paper jam at fuser
I was able to fix my problem. On the left side of the fuser assembly there are two small plastic tabs or flags that move up & down. One is attached to the plastic rod/flap that you can see from the top of the fuser and moves when the paper comes out of the "chute". The other tab, which is below the first tab and moves when the paper has passed some point in the fuser, was broken off. I glued the tab back on and now the paper is ejected from the printer like it is suppose to.
I'm thinking that the broken tab was part of a page sensor flag that would tell the printer to stop rolling the fuser assembly when the paper was ejected. Without the flag, the sensor would disengage the fuser prematurely and stop ejecting the paper while the paper was still in the fuser.
Posted on Apr 21, 2009
I have recently had a paper jam in my HP Laserjet 100 color MFP M175a printer.getting the error message "jam in output bin. Open rear door and clear jam"
You should check inside the fuser at the back of the printer. Probability is that there is a folded sheet or fragment of paper still in the fuser. It may be readily accessible in which case open the tensioning clips either side and carefully pull the offending item free. If you can't get at it, the fuser may need to be removed and dis-assembled.
Oct 25, 2017 | HP Office Equipment & Supplies
How to clear a paper jam in my printer?
  1. Turn off the machine, and unplug the power cord of the machine from the power supply.
  2. Open the paper output cover. ...
  3. Make sure that the jammed paper is not under the FINE cartridge holder. ...
  4. Hold the jammed paper with your hands.
  5. Pull the paper slowly not to tear it, then pull the paper out.
to know info SAF 2507 pipe fittings
May 20, 2016 | HP PSC 950 All-In-One InkJet Printer
How do I solve this problem? My hp LJ 4345 printer experiences intermittent paper jam in fuser(accordion-like) with half of the paper out of the fuser. We've replaced the fuser with a new one but the
This error can be caused by the following:
1. Fuser that is close to end of life. Maximum print quantity is 225,000 pages.
2. poor quality paper, very thin paper never feeds well and will jam.
3. Printing an image that is almost entirely black can cause the paper to buckle before entering the fuser.
Try different paper to see if that resolves the problem.
Sep 02, 2014 | HP LaserJet 4345mfp Printer
I have hp lj 1300 printer befor problem fuser sleeve damage that is repalacing and fixing but now not working only read light bilnking how can repair sir
red light blinking gnerally for
1.door open cartridge
3.fuser element blown( measure fuser element with volt meater)
4.sensor error
and so many
these are the mejor.
Jan 09, 2011 | HP LaserJet 1300 Printer
I have an hp 4250dtn and the fuser rollers at the initial point don't turn, also I am getting paper jams on top by the cartridge, I noticed that the paper is not fusing with the ink, but I am not sure...
The fuser and swing gear asm (the swing gears drive the fuser) probably needs to be replaced. I rarely see the fuser drive motor cause this kind of problem. Are you hearing any noise coming from the back?
Nov 03, 2009 | HP LaserJet 4250dtn Printer
Seems to jam in fuser, fuser has been replaced
if it always jams at the same place (fuser area) try another fuser or check the BLACK PLASTIC ASSY. THAT is mounted in the left door and takes the paper right after it comes out of the fuser ;part is called (PAPER DIVERTER) And sometimes one of the FLAPS That routes the paper is broken,hence causing paper jam.
Jul 30, 2009 | HP LaserJet 9050 Printer
Paper jam hp officejet 4110
clean the roller of your printer if problem occers then u need to change it
Jan 22, 2009 | HP Officejet 4110 All-In-One InkJet...
Hp 4250 paper jam erro
Feb 12, 2008 | HP LaserJet 4250dtn Printer
Fuser paper jam
the cheapest online service manuals that I have found is
for 4.95 a manual.
good luck
Dec 06, 2007 | Muratec - MFX-1300 Copier
Printouts with shadow
Two things - Fuser or cartridge - stop print halfway in machine, if fault occurs before paper has gone threw the fuser then it is a faulty cartridge, if print is ok before fuser (the hot bit at rear) but gets doubled up after fuser then the hear roller in fuser are faulty change fuser....but 95 % of the time it is due to dodgy refill cartridge or worn cartridge (the rubber blade inside cartridge fails to apply enough pressure against drum to clean away old image  hence duplicating itself onto your nice clean paper! Try a known good cartridge if in doubt..
Oct 16, 2007 | HP LaserJet 1300 Printer
HP LaserJet 1300 Printer Logo
Ben Johnson
