Question about Home
I just replaced my cartridge. And when I turn it left I get cold water and when I turn it right I get hot water.
frcs68
  • 1605 Answers
SOURCE: water is either hot or cold
yes, the valve should be close at the downward postion. and the water should be clod to hot from left to right.
open the handle and pull out the cartridge.
make sure the valve body is installed right side up.
if it is, insert the cartridge with the lock pin on top.
reinstall the handle.
Posted on Jan 27, 2009
  • 34 Answers
SOURCE: No warm water in showers
Pleae do not follow smthbrother's advice. It is just a simple problem with the valves, nothing to stress about. I am a plumber by trade and see things like this all the time. If you post the name of a pic of the valves I can tell you what you need to buy and how to fix them if youwant to take this on. If you feel this is something you might not want to I can figure a price up to repair it..this will give you an Idea of what it should cost when you have someone come out to repair it so you dont get taken. Repost if you need anything or you want me to walk you threw it.
Posted on Feb 08, 2009
mpcheeseman1
  • 1400 Answers
SOURCE: Have no Cold water coming out of shower/tub.
Hello
Take the plastic knob off.Turn the brass stem with a pair of pliers until you get it in the proper position.
Off faces down
Cold faces left
Hot faces right
Once in the position screw pastic knob back on.
Posted on Mar 16, 2010
  • 349 Answers
SOURCE: Poor hot water pressure form Delta single lever faucet
it can be adjust take handle off and remove locking collar first turn water off,
it has a metal or plastic ball with a shaft for the handle it may have spun or a washer may be bad under it,
you can get a replacement at lowes or Home depot to replace it if this is the problem .
Posted on May 05, 2010
  • 349 Answers
SOURCE: We have a home that
Remove handle to gain acess to the temperature limit stop. Remove handle and pull out handle adapter kit and next there is a dail that can be adjusted to control the water to balance the temp. It could have been installed wrong, pay attention to where it is now and pull it back to it disengages out of the stem and move it counter clockwise a little and reinstall. Put handle on and test water for correct movement.
Go to link below for a part's diagram if needed.
TO ORDER PARTS CALL: 1-800-465-6130
www.moen.com
Posted on Aug 15, 2010
Replaced my Moen cartridge, finally got the leaking to stop, but now have no hot water no matter which direction the single handle is positioned
Turn on hot water supply
ok to easy but maybe
take valve cartridge out of valve It may be put in 180 degrees out
compare cold side inlet to warm side inlet: spring, little black gaskit/s seal maybe a ball/s
The cold side works right
Nov 28, 2010 | Moen & Replacement Cartridge
Hot water comes out when i turn the thermostatic temp to the right. cold water comes out when i turn the thermostatic control to the left. Since hansgrohe is a German brand, is this correct? i believe...
no, someone probably reversed the water lines in the wall, or if the cartridge was replaced, it was installed backwards.
try removing the cartridge and flipping it, and try it out....
this works on almost all grohe faucets
Aug 03, 2010 | Hansgrohe Plumbing
When you turn to hot it doesn't come out. Cold does.
Assuming that you have hot water at other faucets the problem could be a varnish buildup in the cartridge. After shutting off the hot and cold water either by turning off the main or at the faucet stops (if equipped), remove the cartridge and soak it in white vinegar to break up the varnish. You can clean it up with an old toothbrush and make sure that it is working. It should rattle when you shake it. new cartridges are not very expensive so you can just buy a replacement at any home center as well. If you are the original owner of the faucet Moen will send you a free replacement cartridge if you call them.
May 24, 2010 | Moen 3175 Legend One Handle Shower Faucet...
No cold water from Moen 2253 tub/shower valve, when i turn handle to cold I get hot water, when handle is turn to hot i get hot water
Here is a quick check to see if the cartridge may be at fault allowing the cold and hot to mix. Turn off the hot water supply, with hot water supply off turn faucet on. Turn to the hot and cold sides, If you have only cold water then your faucet cartridge is at fault or the cartridge housing is worn. Shut all supply valves and remove cartridge and inspect housing for signs of wear. If wear is visible a new shower valve is needes. If none visible replace cartridge. I have included a link of a PDF file an exploded parts list. I hope this helps in solving your problem. Please rate if the answer helps in any way. Good Luck and have a great week. Jeff
Apr 05, 2010 | Moen & One Handle Tub & Shower Faucet
Have no Cold water coming out of shower/tub. Replaced the Moen cartridge and still, no cold water. When knob is turned right I get hot water when turned left I get a trickle of hot water.?????
Hello
Off faces down
Cold faces left
Hot faces right
Mar 16, 2010 | Moen & One Handle Tub & Shower Faucet
Water will not turn off
are the handle extensions on the cartridges all the way. i know sometimes the moens are a pain after you put the trim on to get them on and seated right so it actually spins the cartridge. also check the cartridge alignment the cartridges have little white tabs on the sides that correspond with a slot in the valve body if they aren't aligned it won't shut off either
Jul 31, 2009 | Moen 2919 Chateau Two Handle Tub and...
Water is either hot or cold
Jan 27, 2009 | Moen & Posi-Temp Single Handle Shower Or...
Hot and cold water in shower comes out in a triclkle
shut off the water from the main pipe.
use a allen screw driver take the handle off the shower control.
pull of the wall cover.
pull out the pin that stablized the cartridge in the control body. (remember how it is, before you take it out. or take a digital pic of it). pull out the cartridge. and bring it to any home center or plumbing store.
install in reverse.
Jan 04, 2009 | Water Pik Waterpik& Elements& Handheld...
Home Logo
60 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
