Question about Refrigerators
Jenn Air JSD2789AES crisper broken
Shelves don't seem to sit flat unless side rails are off the support on the bottom of the fridge. Whole thing is collapsing.
SOURCE: Bottom of freezer/fridge only getting cold.
Thre is a fan inside the freezer which circulates the cold air around both the fridge and the freezer compartments.
You should be able to feel cold air blowing around the inside, particularly at the top of the freezer.
If the defrost thermostat fails open, the internal fan (depending on freezer) will stop and this can be the cause of the freezer being warm at the top and no ice.
You say the bottom of the freezer is blowing cold, but are you sure its blowing, as it can feel like a cold blow. Of course the fan could have failed or may be the defrost heater itself.
Have a look at this site for some useful trouble shooting
And a good site for troubleshooting and general info
Refrigeration Help Section, Fridges, refrigerators, not cold enough, frost free problems and how to test, noisy fan motors, clicking on and off compressors, door gaskets
Nige
Posted on Sep 28, 2008
docjohn174
  • 943 Answers
SOURCE: JENN-AIR REFRIDGERATOR JSD2789AES
HI thanks for your question. remove cover to the compressor relay, check for burnt wires. clean all coils. replace the relay. thanks
Posted on Oct 14, 2008
  • 236 Answers
SOURCE: Both freezer and fridge Not cold on top
sounds like the circulation fans are jammed/seized or faulty -try a full defrost and see what happens after that.
Posted on Apr 04, 2009
woodchuck789
  • 4070 Answers
SOURCE: rails for drawers have broken
This diagram shows the parts available for your model. It shows some rails. If you can see how the rails detach and go back on you can probably replace the broken ones. http://www.searspartsdirect.com/partsdirect/getSubComp.pd?modelNumber=PDS22MCRABB&productCategoryId=0161000&brandId=0432&modelName=BOTTOM-MOUNT-REFRIGERATOR&diagramPageId=00001&componentDescription=DOORS%20&%20SHELVES&documentId=GR708119&blt=06
Posted on Oct 06, 2009
SOURCE: Jenn-Air Refrigerator JSD2789AES broken shelf support studs
part number is AP4069509 this fridge is such ****! i still need three parts
Posted on Sep 25, 2010
I have a side by side double door fridge. My freezer is cold and working fine but my fridge side is not getting cold.
check yor damper door, it's the little door at the top and or bottom of the fridge insid near the top and or at the bottom behind the crisper drawer when working right they open to let cold air in from the freezer and warm air out. top one cold in, bottom one warm air out.they work on a sensor/relay when the freezer fan goes on they open when cold air is needed.
Mar 12, 2011 | Jenn-Air JCD2389G Side by Side...
Broken shelf? help!
if it is the very bottom shelf then here is your part number 240354602.
if it one of the glass spill proof shelves here is your part number.240355211
Feb 09, 2010 | Frigidaire FRS3R5EMB Side by Side...
Why are my veggies freezing even thought the temp is set to 40?
Most fridges have crisper drawers that have a selection lever on either the front or side of the drawer that allows you to select eiher veggies or meat. Veggie setting is supposed to keep the crisper drawer warmer, while Meat setting makes it the coldest possible.
If you don't have the selector slide levers, I would suggest you use the highest possible crisper drawer available, as the lower in the frdge compartment you go, the colder the air will be. That should resolve the problem you're having, other than lowering the fridge temp setting slightly.
You might notice a cold air exchange vent next to your crisper, which supplies cold air from the freezer section into the fridge section, so that could be contributing to the colder temps in the crisper where you keep your veggies.
Hope you find this Very Helpful and best regards!
Aug 20, 2009 | Jenn-Air JBL2088H 20 Cu. Ft. Cabinet-Depth...
Apr 04, 2009 | Refrigerators
Dec 24, 2008 | Jenn-Air JCD2389G Side by Side...
Aug 30, 2008 | GE GSS20IEP Side by Side Refrigerator
Refrigerators Logo
26 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
