Question about Unicom Home Security
How to remove and relaplace batteries in alarm uni-com model 51152
2 Suggested Answers
  • 14 Answers
SOURCE: how to reset unicom 51152
After inserting battery, press "000" then PROG.Enter your new 1-6 digit code and press PROG again.
To programme the alarm timing, press PROG then press:-
1 for 30seconds alarm 2 cycles, 20 seconds rest in between.
2 for 60seconds alarm 2 cycles, 30 seconds rest in between.
3 for 90seconds alarm 2 cycles, 30 seconds rest in between.
any more you wanna know let me know.
Tonybeatty@hotmail.com
Posted on Jul 08, 2010
Need wiring diagram for uni den grant xl mic
4pin version.. newest models
1ground
2audio
3tx
4rx
5pin older ones
1- Audio
2- Shield
3- Receive
4- Sw Com
5- Transmit
Oct 12, 2013 | Radio Shack TRC-447 CB Radio
Only alarm sound when turn it on
Remove the battery, reboot. Any change? Post the Dell Model and the OS you are using. When you say alarm, do you mean beeping? Try DELL support: http://support.dell.com/support/topics/global.aspx/support/product_support/dd_segmenter?c=us&l=en&s=gen
Jan 07, 2013 | Dell Computers & Internet
I have the Firex i4618, after changing the battery it continues to chirp, have tried 2 new Duracell proper model batteries with same result.
Smoke Detecotrs have a limited lifespan of 5-7 years. So sounds like you need new one (Its not worth to buy just a sensor). Take a look on amazon Amazon: Amazon com Smoke Alarm. I hope this helped you. Have a nice day
Jan 06, 2013 | Kidde Firex I4618 Smoke Alarm W/battery...
I have a toshiba laptop SPM30, I need to bypass the bios passwod to use the uni, help!!
I believe if you remove the cmos battery for a period of time it will reset it.
Oct 09, 2012 | Toshiba Computers & Internet
How do we go about replacing the 9v battery? we have a kidde 0916AUS model on our ceiling.
The manual here, https://www.detectorsandalarms.com/images/pdf/kidde_0916k_manual.pdf describes replacing the battery.
Basically you, 1) Remove the locking pin if it's installed, with some long nosed pliers. 2) Twist the alarm free in the direction of the off arrow. 3) Install a new battery. 4) Twist the alarm back in place, in the direction of the on arrow. 5) Insert a locking pin 6) Test the alarm.
Mar 14, 2011 | Kidde i12040 Hardwire Smoke Alarm with...
I have a Uni-com wireless doorbell, model 55075/SC352R. I would like instructions as I'm not finding it easy to reset things and have inadvertantly set the alarm and don't know how to turn it off!
With the display in normal mode showing the time, date and temperature and with the double dots flashing each second, press the MODE button. The first press will give you the option for setting 12 or 24 hours on the time display. The second press should bring up the setting for the alarm time. Press the SET button once and it flashes the hour for the alarm. Press it again and the minutes for the alarm will show. Pressing the SET button a third time lets you set the number for each musical tone choices for the alarm. A fourth press will ' set' the alarm so the alarm time will show, plus the number representing the ring tone you selected below the alarm time. Normally what you would do next is press MODE again 3 times to return to the ordinary time display. But if you want the alarm off, instead of doing this, press SET a fifth time and this will set the alarm time to 'off' and the display for the alarm will show '-:--' now press MODE 3 times or until you see the ordinary time display with the double dots flashing. You can check the alarm is off by pressing the ALARM button - it should still show '-:--'. The ALARM button is only for showing the alarm time which has been set, not for actually doing the setting. A quicker way, starting from the normal display with the seconds flashing on the time, is to just press the ALARM button once, then press SET 5 times then MODE 3 times.
Aug 27, 2010 | Vacuums
Smoke alarm keeps bleeping
Here are the steps:
Was this always like this? If not, change the batteries, clean it up. Consult the local fire dept. The help for free.
If that does not work, you will need to get it serviced/repaired.
Cheers
TeaCii
If you own website, add live support almost free
Real security guard to watch your cctv for $1/day
Apr 18, 2010 | First Alert SA302 Dual System Smoke...
How to reset unicom 51152
Feb 03, 2010 | Kitchen Appliances - Others
Model 158.1786080: bobbin rewind will not rotate. Rubber on drive wheel seems to be worn below size limits.??
i think you have solved your one "Q" and your right .. the wheel is warren out or the rubber is gon hard and will not pick the drive . some models have just the rubber ( wheel ) as a replacement . an other will have to relaplace the inner (drum) and rubber as assmbl..
Jan 15, 2010 | Sewing Machines
Home Security Logo
47 people viewed this question
Top Unicom Home Security Experts
Lawrence Oravetz
Are you an Unicom Home Security Expert? Answer questions, earn points and help others
