Question about Health & Beauty
How do i remove old battery from uni- ckm model 51153
What is the phone # for salton small appliances. I need parts for my salton cookie press model number ckm 25
look up manufacturer and if carry part buy it or ask for a distributor in your area or locate a small appliance shop in your area
Oct 28, 2016 | Cell Phones
Asus tp500L. Purchased new laptop 360degree flip using it for uni assignment but froze so I forced shutdown but now can't turn it back on? Please help
Try to
-remove the battery and power plug
-press and hold the start button for 30 seconds
-put the battery back -start on the battery or power cord
Nov 15, 2014 | Computers & Internet
Need to remove the starter
NO THE STARTER MOTOR IS NOT TIMED. JUST UNBOLT IT AFTER YOU HAVE REMOVED THE NEGATIVE LEAD FROM THE BATTERY. HAVE YOU HADTHE BATTERY CHECKED ??? DO THIS BEFORE REMOVING THE STARTER MOTOR.
Jan 20, 2013 | 1981 Yamaha-1983 Xj550 Xj 550 Maxim Seca...
I have a toshiba laptop SPM30, I need to bypass the bios passwod to use the uni, help!!
I believe if you remove the cmos battery for a period of time it will reset it.
Oct 09, 2012 | Toshiba Computers & Internet
How do I change the universal joint in a 2005 sorento. The drive shaft pops when teh car goes into gear. I was told it was the uni Joint. I am wondering how to change it. I know it has to be pressed on but...
the drive shaft is fastened with just four bolts, you need to remove those bolts using a spanner or socket wrench so you could pulldown the shaft and you need to mark the shaft end where it was originally matched up because the shaft is perfectly balanced to avoid vibration while rotating. the universal joint comes with a circlip ring and you need to remove those so you could take out the old uni-joint...hope this helps..
Apr 13, 2010 | 2005 Kia Sorento
How do you remove the battery from a UNI-TRI-NT
Battery is built in. Take it to were you bought it.
Aug 24, 2009 | Packard Bell Computers & Internet
Type of batteries??
I think this NV uses 2 double A batts. plus I think it uses a couple of watch type batts as well.
good luck. :)
Feb 14, 2008 | Gsci UNI-MG1 Goggles
Sony PCG-F340 keeps shutting down
Old Sony laptops do this when the battery is dead, or the charging system is below required voltage. A battery with a dead cell (which this sounds like) can damage your external PSU and internal battery/power regulator circuit. Remove the battery (shut down and disconnect PSU first). You can run the laptop forever, without the battery, if you cannot find a battery replacement, or do not like the cost. Obviously, though, the laptop will not run at all without the AC/PSU connected when the battery is removed.
Feb 08, 2008 | Fujitsu Siemens AMILO Pro V2000 Notebook
Health & Beauty Logo
46 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
