Question about Maytag Washing Machines
Maytag neptune model number mah5500bww washer not draining
  • Maytag Master
  • 5,323 Answers
Washer will not drain:
Thedrain water pumpis the main part in your washing machine that pumps out the water. If this is defective or has failed in any way, this will be the reason why your washer will not drain the water. Before you order a new drain pump, make sure tocheck the pump to be sure a small object like clothing or similar has not lodged itself insideof it causing the NO DRAIN issue and even a no spin issue?. If the drain pump is not clogged, you can test it with a multimeter and remove and replace if needed. Go to Google or YouTube and search for "Replace Washing Machine Drain Pump" then type your brand and model number of washer to show you details on replacement.
Read more:http://removeandreplace.com/2014/10/30/fix-washing-machine-that-wont-drain-washer-not-draining-water/#ixzz3X2LbXMWJ
The washing machinedrain hoseis where the water flows through to get the water out.If this drain hose is blocked, kinked, bent, or clogged, the washer will NOT be able to remove the waterfrom the tub. Check the drain hose to be sure it allows the water to flow freely. You can take the drain hose off and run water through it in your sink to be sure it is not blocked. If there is water STILL in the washer when you remove the drain hose, grab a bucket as the water will exit from where you disconnected it
Thewater pump belt(to drain out the water) may have broke or become frayed or loose.If this belt breaks then it is unable to drain and remove the water from your washer. Inspect the belt to see if this is causing theNO DRAINissue and remove and replace if needed.
If thelid switchis not working as required it will cause your washer to not drain (and many other problems).This may be unlikely as a bad lid switch will usually cause your washer to alsonot agitate or spin.However on some models this can vary. The best thing to do if you have a suspected bad lid switch is to test it. It can fail electrically and or mechanically. If mechanical failure is the issue, you should be able to see if it is cracked, broken, or not in place to make contact with the lid. To test it electrically, use a multimeter set on Ohms and test it for continuityMy advice is free cuz God is good!
Fix Washing Machine That Won Drain Washer Not Draining Water
Posted on Jan 15, 2017
IFIXALL
  • 868 Answers
SOURCE: Beeping Neptune washer...
Replace control board
Posted on May 25, 2008
duby1990
  • 367 Answers
SOURCE: washer will wash but not spin
Sounds like the control board is bad. take the back panel off the control panel and look at the R11 resistor and see if it burnt. If it is replace the control board and the door wax motor (in the locking mechanism)
Posted on Nov 21, 2008
aborcass
  • 2651 Answers
SOURCE: maytag Neptune front loader rubber boot replacement
can be done just need PATIENCE!.. youll need ot remove the door assembly, and the 2 screws oppisirethe heing willalow for the front "u" shaped panel to be reomved.. next remove the 4 screws from with in the dispenser area, and then there are perhaps (6) 5/16 screws holding the nextfront bulkead and maintop assy down.. after removing theese screrws youll be able to lift eh main top back wards( prop it with something, a few more screws will release te hlatch assembly.. from here you can probably install the new bellow, remove the spring and wire, and the work the new bellow around the tub lip. a third hand will come in handy, after working it around , youll needto reconnect the tension spring..HARDEST PART OF JOB>>> REQUIRES PATIENCE!!!!!. sometimes this goes on for me with out issue in 5 min, other times 25 min and im PISSED AT IT!!!!!!!,, wrap the wirer around bottom of lip and your going to hold one end of spring, needlenose vice grips work perfectly. then with another set of needle nose. stretchthe spring togethr to lock the wire around.. whern you finally get this reassemble the latch and drop the top back down replace all teh screws, and finally you need to retuck the bellow into the front bulkhead( tabbs line it up nicley.. good luck!!!
Posted on Feb 22, 2009
SOURCE: replacing door gasket on maytag neptune MAH5500BWW washer
I need to know what are the steps to replacing the door gasket, I would like to know what to take apart, and what not to take apart. Like a step by step lay out.
Posted on May 25, 2009
  • 109 Answers
SOURCE: i was wanting to know the year of the maytag
Try and get the serial number then contact a Maytag agent. The serial number in most cases is a date code.
Posted on Jun 17, 2009
My maytag neptune Model #: MAH5500BWW is flashing
The error code you describe is not listed in Maytag's book of codes. The link below will take you to Maytag's website error code page where you might be able to match it up.
http://maytag.custhelp.com/app/answers/detail/a_id/2885/session/L3NpZC8yY3lEMjNEag==/sno/0
Jul 15, 2009 | Maytag Neptune MAH5500B Front Load Washer
I was wanting to know the year of the maytag neptune washer? model # MAH5500BWW
Jun 17, 2009 | Maytag Neptune MAH5500B Front Load Washer
Tub fills with water
replace water valve in the washer. Serial number is needed to find the correct part number. It's likely 22003834, but call any parts supplier with model/serial numbers to verify.
Good luck,
Vlad
First Choice Appliance
Jan 12, 2009 | Maytag Neptune MAH5500B Front Load Washer
Washer will wash but not spin
Nov 21, 2008 | Maytag Neptune MAH5500B Front Load Washer
Door Lock
on your model all wax motor door latch's have to be replaced,go to repair clinic .com and you can order the part or go to ebay,and put in maytag neptune mah5500bww wax motor and it will come up and the guy selling the motors has pictures on how to install,let me know-mike
Jun 25, 2008 | Maytag Neptune MAH5500B Front Load Washer
Maytag neptune mah5500bww leaking water
Here is the solution I found that worked for me, there is a small drain hole at the bottom of the boot that is connected to a drain hose. Remove the hose and clean out to make sure that it has not become plagged. replace hose and reattach boot. Mine stoped leaking imediately.
Feb 22, 2008 | Maytag Neptune MAH5500B Front Load Washer
Washing Machines Logo
62 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
