I have a message saying my box isn't getting a signal,i am in nw95st
  • 5,621 Answers
Check your sky sattellite dish connection.
Posted on Dec 26, 2016
Sky+HD box isn't a getting satellite signal
My Sky+HD box isn't getting a satellite signal
Apr 16, 2013 | Sony Grand WEGA KF60DX100 60" Rear...
Is there a cord that connects my tv to my dish box? It is a VIP 211k.
Ethan Lensch,
I can definitely provide more assistance with this. The TV doesn't connect to the dish itself. The cable from the dish goes into a switch, then from the switch it runs in to your receiver.
On the back of the receiver is a "SAT IN" slot. Verify the cable plugged in there is hand tight, and follow it back making sure any other connections you see are tight. If the signal doesn't return, unplug the receiver for 10 seconds and plug it back in.
If the signal is still out when it powers back on, run a check switch test. This is done by going to Menu > System Setup > Installation > Point Dish > Check Switch > Test. When it is done it will either go back to the Check Switch screen, or give you a message. If it takes you back to the screen, exit out and see if signal returned.
If the signal still isn't returning, or you get a message saying "Fewer satellites dectected", let me know here or by email at and I can look into getting a tech out to fix this!
Tommy Faust
DISH Social Media Representative
Nov 11, 2012 | DISH Network ViP 211K
I need the maual for this rca tv L37wd22yx6 tv just keeps saying unusable signal and i need the maual
What is the signal source for the TV? Make sure that you are on the correct input. Use the Input button on the remote. If you do not have the original remote, you need one that matches that function. (Often a Source or Input button is not available on the low end remotes.) Check that you have the signal set to Antenna or Cable if you are using the coaxial connection and the source is TV. (Menu > Setup > Channel Setup > Signal Type)
If your source is a computer, use the VGA port not the HDMI port. Computers send a different type of video signal than video set top boxes. The L37WD22 can't interpret the PC signal on the HDMI input.
For a set top box on the HDMI port, the unusable signal message indicates a communication issue. Try pressing the Info button on the remote. If you see an additional message of Acquiring Channel, then the set top box isn't responding to the remote. Check that the device is on and set up correctly to communicate with the TV. (For example, if your set top box offers progressive scan, try turning of that feature with the control for the box.)
The L37WD22 was built by TTE for the RCA label. The manual is available on the TTE support page.
The direct link to the User's Manual in English is .
I hope this helps.
Aug 29, 2011 | RCA Televison & Video
Screen only displays a message that says, "no sync detected". This message is also displayed upside down. If I hit the 'menu' button on the remote, the menu is displayed on the screen upside down also.
Ur cable or satalite box it not getting the signal to ur tv.Unplug,replug the box about an hour,let ur boxes upgrade new software ur in comming tv broscast signal should return.
May 18, 2010 | Hisense TA42P-HDRA Television
Message says, "No signal."
try the tv on ch 4 in case the converter box outputs on that channel. let me know what happens and we can get this working
Mar 04, 2009 | Sanyo DP32746 32 in. LCD Television
Converter box
You'll need to keep your TV on channel 3 or 4 depending on what channel you set the converter box. All your channel changing will be done through the converter using its remote control after that. If you change channels on the TV itself and go off channel 3 or 4, the TV will not get a signal and will show you that "no signal" message.
Nov 24, 2008 | Sanyo AVM-3259S TV
Can't get picture
Hello matthew95765,
The TV is working, the message is coming from the dish box. What you need to do is to determine if the dish box is connected to the dish and that it has signal at the box, because the message it is delivering to the TV is that it is not receiving signal from the satellite. so you have to check the connection at the satellite and at the box because those are the only point that can generate the error you are getting.
I hope this helps,
Thank you,
Jul 23, 2008 | SVA-USA SVA HD4208TIIIBU 42" Plasma...
Install new power supply?
The monitor is not receiving any signal from the PC. When you push the power button ON, is there any activity on the PC (LEDs on, power supply fan, etc) or it's just dead ? In this case, yes, the first thing to check is the power supply.
Jul 06, 2007 | HP Compaq Presario 6430NX (DA237A#ABA) PC...
Televison & Video Logo
27 people viewed this question
Top Televison & Video Experts
