Question about Home
What is the dial,at 6 o'clock on the invicta model 22762 pro diver and how do I adjust it.
I want a link for invicta pro diver model 0886
https://www.invictawatch.com/watches/detail/0886-invicta-pro-diver-men-488mm-stainless-steel-stainless-steel-silver-dial-pc32a-quartz
Nov 11, 2016 | Invicta Watches
How do I set the time on an Invicta Pro Diver watch?
Depending upon the movement, most pro divers have a *****-down crown for water tightness. First unscrew the *****-down crown. You can then pull the stem out one or two clicks. The first click permits you to set the date by turning the crown one way or the other. The second click should permit you to adjust the time. Then push the crown back in, hold it down and ***** it down 4 water resistance. Be gentle when manipulating the crown and stem!
Nov 02, 2015 | Invicta Diver Watches
How to set?& manual required invicta.15343 pro dive
Invicta Pro Diver - View model
invictawatch.com/collections/view-model/15342-pro-diver
INVICTA COLLECTIONS click to view models · AKULA ... Instruction Manual Print. More models of the same style. 15343. Invicta Pro Diver · share watch. 15341.
Sep 25, 2015 | Watches
Invicta 8926A gains about 2 or 3 minutes after winding.
Send in for warranty repair with a description to Invicta
Oct 12, 2012 | Invicta Automatic Pro Diver 8926A Wrist...
The dial and spring on my Invicta 9937 Pro Diver are missing, Do you have replacement parts?
mcdevito75 here, Best Bet Contact shop NBC foer Invicta parts info, here"s their number, 800-474-6762 Hope this helps.
Aug 03, 2010 | Invicta Pro Diver 9937OB Watch for Men
Invicta model 8926A picks up 30 seconds per day
http://calibercorner.com/seiko-caliber-nh25a-vs-nh35a/
The link will take you to a drawing of the movement.
You will see an adjustment - or + you need t adjust it to the -.
Best done by a pro but totally something you can do on your own if you have some small screwdrivers.
Dec 19, 2017 | Invicta Automatic Pro Diver 8926A Wrist...
DIFERENT DISPLAY FOR THE SAME WATCH MODEL.
A watch is considered Swiss, when it is made in Switzerland (hope I spelled that right), by a Swiss Comapny, using 50% or more parts that are also Swiss. Watches made this way will have "Swiss Made" Swiss" or a similar print on the back.
If it has the lables of "Swiss movement" "Swiss Case" then it means that it is only partly swiss made, and will not have a lable listed in the first part of this solution branded on the back.
Hope I helped, have a great day.
Jan 13, 2009 | Invicta Swiss Pro Diver 9309 Wrist Watch
How to set a invicta 3443 watch up
To set the time pull the crown out to the first position and set the time by turning the crown. Pull the crown out to the second position to set the date. Since this is a diver model you will need to unscrew the crown before it will pull out. Make sure you replace the crown and screw it back down for a good protective seal.
The alarm sets the same way. Unscrew the button to set.
Nov 24, 2008 | Invicta Pro Diver Collection Grand Diver...
Invicta pro diver strap length
ur supose to leave that one open and the rest u can tightin
Jun 10, 2008 | Invicta Pro Diver 9321 Wrist Watch
Home Logo
27 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
