Question about Pioneer Car Audio & Video
I don't have a wiring harness for my Pioneer Avic Z1 need to know how to wire the pins
Pioneer avic z1 won't close or eject
You need to take it out take the fuse out the back and reset it wait 30 seconds Then put the fuse back up power back up and it should operate like it supposed to.!!!
Feb 04, 2013 | Car Audio & Video
Can I install a Pioneer Avic Z1 into a 2002 gmc jimmy?if so is there a dash kit and wiring harness available?
Yes, that is the best way to go. Most local automotive stereo stores sell an installation kit that has a surround that the new stereo mounts in to and fits the space of the stock stereo, and also comes with a wiring harness that wires the new stereo to a plug that fits tthe car's stock radio connector.
May 15, 2010 | Pioneer AVIC-Z1 Car DVD Player
I NEED TO KNOW ARE THE COLORS MEANING FOR PIONEER AVIC N2 WIRING
Red = power Organ = battery Blue with a strip =remote
Blue antener ( the rest are speakers )
Aug 16, 2009 | Pioneer Car Audio & Video
Need Wiring Harness for Pioneer AVIC-F700BT
you can purchase a wire harness adapter for your pioneer from best buy . just give them the model # of the stereo deck and your vehicle make and model and year they will have one available for you so all you have to do is plug it in no cutting wires or hassle
Apr 20, 2009 | Car Audio & Video
Dvd player while driving
he is right to an extent i have installed many of these the yellow black wire off the rca harness you have to pull the pin out of the harness and move it up one space and ground it out just an fyi if you vss wire is connected it wont work either let me know if you have any other questions
Sep 12, 2008 | Pioneer AVIC-D3 Car DVD Player
I need the wiring harness for pioneer avic-n2
i need wiring diagrame for pioneer avic n2 cpn1955
Aug 22, 2008 | Televison & Video
AVIC-Z1 options just quit
It actually sounds like you don't have your parking break wire (light green wire on wireing harness) grounded. I have an 06 F150 and the same thing happened to me when I instaled it. I had no address search and some other functions didn't work as well. Try to locate the light green wire and ground that to anything metal. Hope this helps, the install manual isn't very good at describing this.
Aug 11, 2008 | Pioneer AVIC-Z1 Car DVD Player
Avic-n1 bypass
Heres a good site that has alot of bypass guides for Pioneer Avic Units
http://underground-secret.com/avic_n1_bypass.html
Pioneer Avic D1, D2, D3, N1, N2, N3, N4, Z1, Z2, Z3, F700BT, F900BT & F90BT.
Aug 03, 2008 | Pioneer AVIC-N1 Car DVD Player
AVIC N2 parking brake bypass
There are two ways to complete this project:
1st
underneath the mounting bracket of the radio not the brain theres a silver sticker like mentioned above there are two silver solder points right beneath the sticker it must be jumped with a wire or you can use the solder to connect the two contact points after this you must still ground the green parking brake wire to the car.
2nd-(also my favorite choice and the one I'm using on my N5 & on my 7800dvd those who know pioneer know what i'm talking about)
buy a ptr7 pheriphial device and wire as follows (they come factory ready to bypass alpine and pioneer units)
wire as follows-white wire to green parking break of the deck your bypassing
red wire to vehicles 12v source
green wire from device to remote
black wire to vehicle ground wire
final important step I know because this happended to me
make sure you take a little screwdriver agfter wiring or something and switch the
PTR 7 to the off position-or else this will make the PTR7 not function correctly
May 08, 2008 | Pioneer AVIC-N2 Car DVD Player
Pioneer D2
Found this online:
In order to watch the AV source in the AVIC-D2 or to have all the NAVI function while driving you must do the following:
1. Ground the original parking wire (Must Do)
2. There will be a open pin in the wiring harness under the ground wire. You must also ground this pin. I just pulled the wire out from the cellular mute pin and stuck it in the new pin and grounded it.
Nov 07, 2007 | Pioneer AVIC-D2 DVD Nav/6.5"...
Car Audio & Video Logo
59 people viewed this question
Top Pioneer Car Audio & Video Experts
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
