Question about Garden
Mower starts fine but stalls when try to engage the cutters with push pull switch
    Problem Solver:
  • 15 Answers
After you start the mower can you rev. the motor a little bit ? ..trying to separate the componets ...is this a rider mower? what brand ..what year .....i would take off the mower deck ....check it see if it is bound up...either rust or something jammed in it ...did you run over anything lately ...
Posted on Dec 26, 2016
Ride on mower can ride around but whe engage fanbelt for cutter motor stall no power but very thing does turn easy with hand
Sounds like your mower deck safety switch is bad..it is located near the end of the handle that engages the mower deck..try unhooking it and bypassing it with a wire or heavy paper clip...then try mowing if it mows that is your problem..the mower deck will,operate that way but is a safety switch..you need to get it replace,,easy to do yourself..good luck.
Jan 09, 2014 | Briggs & Stratton Garden
JD 110 tractor stalls when put in gear
Sound like a safety switch has gone bad. Either the clutch or seat switch are bad.
Mar 24, 2017 | Garden
Toro 4200 time cutter stalls when the handles are pulled in
I believe the timecutter has a safety switch that only allows the unit to start with handles in the out position, then you need to be on the seat to be able to pull handles in without stalling engine. Have you tried checking the seat switch? It sounds like one of your safety switches isn't working. Either the seat switch or the handle switches. That's where I would look first. Good luck!
Oct 24, 2013 | Briggs & Stratton Briggs Stratton...
Motion belt was recently replaced and the mower seemed to be operating as intended; mowed the lawn with no problem. The next time I tried to use it I discovered that, as soon as the mower deck is engaged,...
This could well be a miro switch issue, start with the seat switch make sure the connector is fully pushed onto the micro switch, if no better make sure you are fully sat in the seat to activate the switch, if still no better replace the switch.
Jul 31, 2013 | Garden
Mower dies when directional pedal ( F/R) or engageing blades
check the safety switches start with the one on the pedal
May 16, 2012 | Garden
Poulan riding mower stalls when I release the clutch
there is other safety switches on the pedal and on the pto
Apr 03, 2012 | Garden
Engine runs but stalls when engaged
This sounds like a micro switch, or relay issue, it is not stalling it is being switched off, if there are some relays on the back of the bulk head replace them, they are just a push fit.
Feb 26, 2012 | Garden
Husqvarna_24hp_54_yard_tractor
when was the last time you took a look at the cutter blades,,or serviced the cutter deck? if the cutting blades are blunt or rounded off it will stall the engine stress the belts and the clutch,,,also if the mower has been standing un ran all winter it may have "rust" on the engine valves,,running the engine unloaded for a time may knock this off but under load the compreshion is pushed up into the inlet and pops back through the carb,,,try putting into the fule a little "two stroke oil" only 5cc a gall no more! this will lube the velves and carb,,,but sharpen them cutter blades up first,,,or its like trying to eat a half cooked stake with a blunt knife and no teeth? that reminds me? were have my teeth gone?
Jul 31, 2010 | Husqvarna 24HP 54" Yard Tractor ()
John Deere tractor stalls when I let up on the clutch.
when you let the clutch out and it stop engine it could be a safty switch. but a safty switch would not make it stop after it was runnig unless you have a short in the wire.
Jul 06, 2009 | Garden
Garden Logo
26 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
