Question about Garden
2146 runs fine for 10-15 mins then suddenly quits, gas supply fine, after sitting 2-3 hrs starts and repeats, ie 10-15 mins quits, suspect voltage regulator
  • 850 Answers
Coil may be breaking down or earthing out as vibration over time can wear out the insulation on the wire
Posted on Jul 21, 2009
Info for Mule 610
sounds like electric fuel pump when it quits,take fuel line off at carb turn key on you should hear pump and see fuel coming at line
Sep 21, 2014 | kawasaki 2013 Mule 610 4x4
Won't keep running quits after about 30 min. you let it sit awhile and it starts all over again.i replaced the air filter and fuel filter.still has the same problem only has 110 hrs. on it
Sounds like your gas cap is not venting. Your fuel tank has to breath in order deliver fuel, so make sure the check valve in the gas cap is working. You can test that theory by removing the cap, and running the machine with a rag over the gas filler neck. Other things to look for would be fuel lines getting hot, or an over heating fuel pump. If it sounds like it runs out of gas when it does die, I would suspect fuel delivery. If thats not it however, check for spark once the machine dies, a magnito or coil can't be ruled out. Keep me posted please! Good luck!
Sep 28, 2011 | Garden
Dometic refrig runs on AC fine, runs on gas for 8 min. then off.
freon line may be plugged...try flipping it up side down for 24 hrs.. hope it helps
Sep 19, 2009 | Refrigerators
14sb mower starts and runs 2-4 min, then quits
The plug is breaking down.Change the plug.
Jul 24, 2009 | Garden
Put car in drive and put my foot on the Gas and the car cut off
Check to see if there is fuel coming to the engine. If your fuel pump is working you should be able to hear it pressure up when you turn the key to the running position. Change your fuel filter. I really don't suspect the filter is your problem when it quit this suddenly. If it was bogging out the last time you drove it or running poorly, the filter would be more suspect. When you're convinced that that is working, check for spark. Best way is with a timing light. If there is no spark, the first thing i would check is the timing chain. If that's okay, then you'll have to check ignition components. ie : idle control sensor, mass air flow sensor etc. Good luck, and let me know how you make out.
May 01, 2009 | 2000 Dodge Intrepid
Starts and runs fine when cold, dies after 10 to 15 min.
i would try first change gas make sure its a mix of gas and 2 cycle engine oil,second new spark plug third make sure theres nothning in the gas line hope this helps
Apr 06, 2009 | Homelite Leaf Vac Attack
Stalling on a 22re engine
hi voltage sistem is overheting (vovina) chench it
Nov 03, 2008 | 1985 Toyota Celica
Garden Logo
164 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
