Question about Panasonic Televison & Video
I have a Panasonic recorder DMR-BWT 835 and when I set the timer recording it doesn't record the programmed shows. I can watch already-recorded shows etc. Can anyone help?
SOURCE: Faulty Panasonic DMR-E85H
You must replace the inside "str" sheet feeding and condenser close. Everything back to normal. :-)
Posted on Dec 06, 2007
Palmbeach
  • 185 Answers
SOURCE: Panasonic DMR-E55 DVD Recorder
Ok guys, you asked for a fix for the DMR E55 Self Checking cycle. Here goes.
In 99% of cases this is caused by a faulty regulator on the main power board. The power board is located on the right hand side of the unit. The regulator is IC001 which is mounted on a thin metal strip which acts as a totally inadequate heatsink. This means that this component constantly works at temperatures beyond its tolerance. Because of this it usually lasts a couple of years and then starts causing problems. The Self Checking syndrome is typical. If the regulator burns out completely, it can take other components with it, blow fuses and scorch the circuit board.
If you are competent in using a soldering iron with care, order an STRG 6353 regulator. These can be obtained online from a number of suppliers. Disconnect your DMR E55 from the power source and remove the lid.
Next, remove the fixing screws from the circuit board on the right where the regulator is located. Carefully remove the multi connector on the left side of the board. Remove the screw above the power connector on the rear of the unit. The power board can now be removed from the cabinet. Using a small pair of wire cutters, clip all five pins from the old regulator as close the the top of the board as possible. Undo the screw securing it to the heatsink and remove the old regulator which can now be thrown away.
Next, using your soldering iron, remove what's left of the pins from the printed board and with a solder sucker or desoldering braid, clear the holes ready to accept your new regulator. Be careful because if you over heat the print it can lift away from the board.
Use a little heatsink compound on the back of your new regulator, poke the pins through the circuit board and then secure it to the heatsink. I usually fit an extra heatsink on these units which helps to reduce heat and prolong the life of the new component.
Next, resolder the 5 pins on the print side of the board. Use a magnifying glass and make sure you haven't missed anything or bridged connections in error and caused short circuits.
Now put the board back. This can be a little trick but it's easy enough if you take care. Replace all the screws and carefully reconnect the multi connector.
If you have followed this correctly, switch the unit back on, pop in a DVD and give it a try. Unless you are very unlucky, You DMR E55 will no longer repeatedly self check and will operate correctly. Whilst it saddens me to hear that some of you guys would toss your DMR E55s into the trash can for such an easily repairable problem, please do not attempt this unless you are confident in your own ability.
Finally, do check that the fan operates but remember it is temperature controlled and will not activate until it is needed. Do not assume it is faulty because you do not see it working straight away. I have repaired lots of DMR E55s and I have never found a single fan or fan control circuit to be faulty. That's not to say it can't fail. good luck...
Posted on Jan 15, 2008
Palmbeach
  • 185 Answers
SOURCE: AELFCHECK Problem with Panasonic DVD Recorder
Hi
This problem is associated with a regulator on the power board. It's an easy fix if you can use a soldering iron.
If not you may be able to get someone to repair it for you. I have posted instructions on how to replace the defective component.
Please note the instructions I have given refer to the DMR E55 but the E95H is much the same.
To see my earlier posting, please Click >HERE<
Posted on Mar 13, 2008
nandosnut
  • 112 Answers
SOURCE: DMR-ES15 Stops after 45 Min.
U88 means the unit has detected an error while recording or playing and has entered its recovery process to restore the unit to normal operation. You could try using a DVD-RAM disk or a different make of DVD-R but, as you say the unit is new, you should probably return it to the retailer for exchamge, repair or refund according to unit age and retailer's return policy.
Posted on Nov 06, 2008
SOURCE: Panasonic DVD player shows EXT-L in its display.
You have switched machine onto external link mode
Either press external link on remote or find it under the flap.
Has a small child been playing with the remote?
Posted on May 28, 2009
How do I set a program to record weekly, can do it 24 hours ahead up to one week.
On the timer record screen, move the cursor left to the 'date' field, and scroll down until the date disappears, and it only shows a day of the week. If it shows 'Mon', your programme will record every Monday.
Mar 06, 2015 | Panasonic DMR-EZ47V DVD Recorder/VCR
I have the DVD/VHS recorder/player Panasonic Model DMR-E75V, I have connected the 2 scart cables to the digital decoder and TV set but I cannot record even if I can play the VHSs and DVDs normally. It's a...
First of all you have to connect only one SCART cable ( one end to TV and the other to DMR ).When you are watching a program on TV select the DMR source ( input selector ) to SCART. Just press the record button with a blank DVD inside and it will record. Some Digital broadcast might have copy protect content which will prevent the recording from happening.
Mar 10, 2011 | Panasonic DMR-E75V DVD Player/VCR
Recorder has stopped decoding SD digital TV but analogue TV is OK
Dry joint - faulty capacitor on the PC board of the decoder. Found by wiggling the components and resoldering
Feb 07, 2010 | Panasonic Televison & Video
Can I watch tv with the timer on the dvd recorder turned on?
Hook up the cable wire that comes directly from the wall to the dvd recorder's in connection, then get a 3 ft cable cord and connect from the out of the dvd recorder to the in on the tv. You should be able to set the dvd recorder channel and timer and leave it off. you then should be able to have your tv on and watch any station but to watch the tv with dvd recorder on, your tv should be set to either channel 3 or 4 depending on the switch on back of dvd recorder. I hope this solves your problem. Foxpaw13
Jun 15, 2009 | Panasonic DMR-EZ37VS
DVD-Recorder DMR-EX71S
John,
I'm afraid that all I can find to assist is a copy of the Instruction Manual in Italian. See here:
www.panasonic.ch/doc/9301_9400/9391/userguide/userguide_4_dmr-ex71segk_-.pdf -
Mar 25, 2009 | Panasonic DMR-ES10 DVD Recorder
Is it possible to record one show, while watching another ??
You need to put a cable splitter on the cable. One side goes to the TV. The other side goes to the recorder. The output of the recorder goes to one of the alternate inputs on the TV. Set the recorder for whatever channel you want to record using its internal tuner. Use the TV tuner to watch a show live. Later, set the TV input to whatever you connected the recorder output to and watch your recording. You will probably need to do this to see the recorder menu to set up the recording.
Mar 10, 2009 | Panasonic DMR-EZ47V DVD Recorder/VCR
DMR E55 timer recording won't work
Your recorder doesn´t have a digital tuner, let alone an HD one. You can record digital programs via your TV tuner if it gives a signal out. Connect your TV to AV1 or AV2 on your recorder and program the recorder to record from the one you chose. You must program the TV separately (I don´t know if this is possible on your TV) or leave it on and on the channel you want to record.
Feb 15, 2009 | Panasonic DMR-E55 DVD Recorder
DVD Timer not working
It usually means that if it doesn't record you don't have a blank DVD in the slot. Hope this helps =)
Nov 06, 2006 | Panasonic DMR-E95HS DVD Recorder
Televison & Video Logo
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
