Tokyo gas fan heater 40 Fault code 11&12 display after switching heater on. What remady should be.
4 Suggested Answers
john224
  • 1378 Answers
SOURCE: raypak heater. fault cde says (ROL)
Thank you for posting your question here on Fixya.com.
Replacing the roll out switch is an easy do-it-yourself repair. Fixing the problem causing the roll out of the burner flames in the first place is a bit more of a pro job. Something is causing to much heat to roll out the the combustion chamber into the control area causing the switch to fail. You will continue to burn the link until the underlying problem is fixed.
If this answer does not fix your problem, please comment with additional details prior to rating the answer. Positive feedback is appreciated once your problem is solved!
John
Posted on Jun 01, 2010
  • 760 Answers
SOURCE: rheem digital gas pool heater fan code
The Fan code would indicate a problem with the combustion air blower. The is a pressure switch to indicate there is sufficent combustion air, and if not then unit shuts down. Either the fan isn't running, or there is an obsturction in the fan or exhaust piping, preventing enough air flow.
cfh would be call for heat, which would be a normal display when water temp is below setpoint
See the link below for a manual. Once you open the page look on lower right side for documents, then install manual
http://www.rheem.com/product.aspx?id=2388EEB7-3DEC-4601-AE76-EC7A07F17630
Posted on Jul 05, 2010
SOURCE: My Heater displays a fault code "OC". when this is
This is error code indicates an overheating problem. Please check if there are enough air/water flow to cool the system while it is running. Check the valves if they are operating properly.
Here are other error code that might be useful:
BD1 Board failure EEP Microprocessor error FAN Blower pressure failure FFL Flame sensing when pilot and gas valves are closed GVC Gas valve closed GVO Gas valve open HL1 High limit switch #1 open HL2 High limit switch #2 open IGN Ignition failure ILO Ignition lockout - Propane units only PRS Water pressure switch open ROL Heat roll-out safety switch open SNS Sensor failure, Water temp. below 36°F or above 110°F VNT Vent switch open
Please let us know if you will require further help. Thanks for using Fixya.
Posted on Sep 10, 2011
Where can i get operating instruction manual in English language for heater TOKYO GAS MA-B350FH
Try this web site. www.tokyo-gas.co.jp Key thing on these type of heaters-they take a lot of fresh air to run properly. If not, you coulkd wind up with a very sick house and sick people.
Dec 31, 2014 | Cameras
Tokyo gas fan heater user guide rn-a120fh-wh
Hi can u please send me the translation operation buttons in English language of RN 240 TFH fan heater manufactured by (Tokyo Gas) thanks.
Dec 12, 2013 | Rinnai RHFE-1004FA 38,400 BTU Energy Saver...
Hi i need English Language manuals for Osaka Gas Fan Heater Model 43-659... as the operating buttons of the heater is in Japanese Language. by mis handling it i got its timer ON. now dont know how to fix...
I have gas fan heater made by Tokyo Gas, model MA-A630TFH.
on the front pannel all the language is jAPENESE. PLEASE HELP ME AND MANAGE FOR OPERATIONAL MANNUAL IN ENGLISH.
Oct 20, 2012 | Heating & Cooling
Baxi duo tec e160 code
Fault Code E160 on a Duotec Boiler is a fan fault.
Mine has just gone for the 2nd time! Gas engineer is on his way......
Jan 31, 2012 | Heating & Cooling
My rinnai 1004 keep shuting off and is blinking 14
CODE DISPLAYED FAULT REMEDY 11 Ignition Failure Check that gas is turned ON. Service call if repeated. 12 Flame Failure Check that gas is turned ON. Service call if repeated. 14 Overheat Clean filter. Service call if repeated. [1] 16 Room Overheat Lower room temperature to less than 104°F (40°C). 31 32 Room Temperature Sensor Faulty Service call. 33 34 Overheat Temperature Sensor Faulty Service call. 49 Sensor Breakdown Service call. 53 Sparker Failure Service call. 61 Combustion Fan Failure Service call. 70 Faulty ON/OFF Switch Service call. 71 Faulty Solenoids Service call. 72 Faulty Flame Rod Service call. 73 Communication Error Turn heater OFF, then ON again. 99 Flue Block Check around the flue terminal for blockage. [2] [1] Remove any obstructions. The flue needs to be kept clear to expel exhaust gases. If the appliance fails to operate contact a qualified service agency. [2] If the fusible link needs replacement, it must be done by a qualified service agency. In addition, the cause of the overheat needs to be determined. The fusible link is a one use safety device that breaks to shut off the appliance.
Dec 17, 2010 | Rinnai RHFE-1004FA 38,400 BTU Energy Saver...
Rheem digital gas pool heater fan code
Jul 04, 2010 | Solar Rheem Gas Fired Pool & Spa Heater...
My hotpoint washing machine wt960 keeps displaying the fault code f-08 when trying to do a 40 c wash
Error code F08 is indicating that the heater relay cannot be activated.
Check all connections on pressure switch----module---- and heater.element.
Hope this helps, this is the recommended procedure.
Dec 01, 2009 | Washing Machines
Rinnai natural gas log fire heater
12 is a fault code, look in the book if you have if, i think 12 is no or low gas pressure, cheers
Oct 06, 2008 | Rinnai Desa Vent-Free Infrared Gas Heater:...
Heating & Cooling Logo
75 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
