Question about Microwave Ovens
I need to know the settings for the micro wave oven I don't know how it work what buttons to press
    Top Expert:
  • Microwave Ovens Master
  • 49,083 Answers
Google make and manual we can not guess here
Posted on Dec 26, 2016
SOURCE: Panasonic NN 9850 wall micro/convection oven
Posted on Oct 05, 2007
SOURCE: micro wave oven doesn't heat
replace magnetron
Posted on Jul 24, 2008
SOURCE: microwave oven problem
My microwave oven makes my cups and dishes so hot they can't be touched . The dish is much hotter than the food or beverage inside .
Do I have a defective microwave ?
Posted on Sep 17, 2008
  • 49 Answers
SOURCE: I have a built in Whirlpool Micro Wave oven that quit
if you open the cupboard door above the microwave you should see two or four screws/bolts holding the microwave up there. there should also be an electrical outlet up there where the microwave is plugged in. have at least two strong people. put some blankets on your stove top to protect it. unplug and remove the screws. it should be connected in back by a metal plate also. when the microwave is tilted down at a fourty five degree angle, you can give a little lift and it should pop off the plate in back. it is heavy. get a new one at sears or other appliance retail outlets. i dont recommend best buy. they really screwed me over so i dont send business their way.
Posted on Oct 20, 2009
  • 8404 Answers
SOURCE: How many micro wave ovens will a 20 amp circuit support?
Please stick with me to the end ... some examples are for example only. There is no 1000 watt circuit per'ci.
This will not be possible overload, this is an accident waiting to jump on you, my friend
Install dedicated circuits for these ovens, my friend. It will cost you a little but will be better than having dissatisfied guests or talking to the zoning board or boarding house authority or (gasp) the fire inspector after the fire.
If you don't do this, when the breakers start flipping off, tenants will run extension cords to outlets that have power. A whole different and worse, problem!
Rule of thumb, lighting circuits should be designed to operate at 80%, for example, if you have 800 watts of lights on a 1000 watt circuit, you are at the max.
So, there is a possibility that your circuit for lights is already near max. Adding ovens is trouble. Don't forget the iPOds and cell phone chargers as well as lap top chargers, walkman chargers (older students), little TV's, DVD players, clock radio's, electric shavers, curling irons, steamers, popcorn makers, lava lamps and occasional electric heaters that will be snuck into the room.
What is a 1000 watt circuit ... good question. Ohms law comes into play here.
Volts X Amps = Watts
120 volts X 8.333 amps = 500 watts (a smoothie blender) 300 watts (slow cooker) 200 watts (hand mixer) = 1000 watts.
A 15 amp circuit will protect #14 wire and can carry about 1800 watts (a toaster (1500 watts), for example).
A 20 amp circuit will protect #12 wire and can carry about 2400 watts (i am using a big paint brush here. these numbers are pretty close but not exact and I am not a licensed electrician.)
When I wire, I aim lots lower, preferring to OVER build than to under build.
10 amp circuits are rare in modern homes. In general practice, if the need was to be protected at 10 amps, the wire used in the circuit would be #14 and it would be protected by the breaker at 10 amps. In this case, it is the device plugged into this 10 amp circuit that needs protection rather than the #14 wire (which would be technically oversized)
Another consideration for you is where is the water? If you have an outlet that is 5 feet from a water source (bath - kitchen - etc) it must be protected by a GFIC
A 30 amp circut will protect #10 wire --- but this is not a normal household circuit.
Maybe the best option is for you to have your electrician install a sub panel in the vicinity of use and run several 20 amp circuits from that location to the various rooms.
The answer to your question "How many (1150 watt)micro wave ovens will a 20 (amp circuit handle)" is TWO with nothing else on the line. The National Code requires dedicated circuits for micro wave ovens, BTW. A commercial application may have a different (more stringent) standard in your town.
Thanks for the opportunity to answer your question and thanks for your interest in
Please vote - positive comments appreciated by volunteer question catchers.
Posted on Dec 13, 2009
Change clock on dunelm micro wave
Please see the answer I posted for Joana Ball:
With this model because clock is the SECOND item listed, I suggest to press that button twice, wait for the clock to come up 00:00 and set it using the same button (preset option).
Unfortunately I don't know this for certain as I am only using an educated deduction on other brands of microwaves with similar front panels.
I really hope this helps, please let me know if it works as I will be contacting Dunelm to ask for a pdf manual.
Mar 29, 2015 | Microwave Ovens
My micro wave reads that it is locked how do I unlock it. it is sears ultra wave
The "lock" function is nice if you have kids who like to push buttons. It disables the microwave oven to prevent it from running unnecessarily,
To disable the lock feature push the "STOP-CLEAR" button. Then press and hold the "START" button until 'locked' is no longer shown on the display panel.
To re-lock it, do the same thing until 'locked' appears on the display.
Have a nice day.
Oct 20, 2013 | Kenmore 63662 / 63664 / 63669 Microwave...
Where is the reset button located on spacesaver micro wave oven
  • locate the microwave's power supply cord.Remove the power supply cord from the wall outlet.Wait one to two minutes.Re-insert the power supply cord into the wall outlet. The microwave is now reset.
  • Mar 24, 2012 | GE Spacemaker JVM1640SJ Microwave Oven
    Try2910227 serial ywmh2205xvb-0 model arcing on the back corner were the rack sits.Is there a way to repair this seen is the unit was purchaced in June of 2011.
    Yes, take the rack out and recycle it. I do not know why these micro-wave company put racks in the micro wave ovens. You get some insulation on the inside the micro flaking off next the rack.
    The mega-tron tube is a very high energy transmitter. The energy will come out of the top inside the micro wave oven in a wave guide. Micro wave energy that generation by the tube is high frequency into Gega Hertz. You have a metal tray in side the micro wave acts like a big capacitor it stores energy in form of heat the next you know it look like Marconi is putting on a lighting display.
    Leave the wire tie on a loft of bread and put in you micro wave oven to defrost. The next thing you might see is a load bread burning, instant toast. ----The use of micro wave were invented by the British before WWII. The mega tron tube generation very high frequency radio wave and these wave struck an object 100 miles away some of this beam energy would balance back to a receiver-----You have Radar.... I wish you and your family well being and be careful of micro wave ovens it can burn from inside out. GB you...stewbison
    Aug 22, 2011 | Microwave Ovens
    Need manual . Didnt have in box when purshased! Don't know how to use the thing! Thanks!
    need user manual ( free) for emerson MWG911SL micro wave.. Cant seem to get anywhere tryin to get it.... ThNKS Z
    Jul 24, 2011 | Microwave Ovens
    How do i set the clock on my hinari life style micro wave mx698tcss
    Usually one must press the cancel/stop button before setting the time by pressing the clock button and pressing hour/minute buttons and then clock again to memorise it.
    Jan 19, 2011 | Microwave Ovens
    My Emerson microwave is about 2 years old. I washed it just like I do every week and the power went out on it.
    you mean it want power up or want work when you press the star buttom?
    1. check the fuse if no power.
    2. If it doesn't work when closing the door after setting timer it is the micro switch that the metal lach hits when the door close.
    3. unpluge the micro wave unscew the scews to the cover of the microwave remove the cover. up front by the door you will see the micro switch maybe (brown,black,white,red/white ) what ever color it is disconet it take it to the hardware store buy a new one and replace it,themreasemble your micro wave.
    Oct 30, 2010 | Emerson Microwave Ovens
    Dont know how to set clock
    hello there:
    to set the time on you're micro wave you will need to push the clock button and use you're number pad to enter the time and once you have got the time set properly you will need to press the clock button again.... hope this helps you out sincerely D.Jones
    Jun 06, 2010 | Goldstar MV-1501 Microwave Oven
    Need to replace handle on micro wave can not
    Dec 18, 2009 | Jenn-Air M439 Microwave Oven
    I cannot set the clock on my LG MS1949G Micro wave
    After spending 25 minutes on hold while LG try to find out how their own product sets the clock, I now know that the LG MS1949G Microwave open does NOT have the ability to set a clock that shows the time of day.
    Jul 11, 2009 | LG LTM9000 Microwave Oven
    Microwave Ovens Logo
    26 people viewed this question
    Top Microwave Ovens Experts
    William Miller
    William Miller
    Are you a Microwave Oven Expert? Answer questions, earn points and help others
