Question about Blenders
Hi i broke the spining part of my smooth maker blender where can fix it
Where can I purchase spare parts for rosemary conley juicer/blender
I have a Roseary Conley blender and recently the blade broke. I looked everywhere for a replacement and couold find none. What part of your blender is broken? We could probably make a whole out of the two. Let me know.
Feb 03, 2012 | Blenders
I think it is the blade that is inside anyway it broke in two places
Find the model number of your Smoothie maker and then check the follwoing site for replacement parts for your particular model:
Aug 03, 2011 | Back to Basics Smoothie Elite Work Top...
How do I remove the black rubber rotating bit on the Kitchen Aid Blender?
My clever hubby made a spanner (piece of metal with a slot cut into it) that fits round the spine under the plastic cog and then using pliers he could just unscrew the offending piece. Use masking tape to protect the top of the blender. Thanks for previous suggestions though as it saved going to a repairer and paying unnecessary costs. Cheers.
Feb 04, 2011 | KitchenAid KSB5 Ultra Power Work Top...
I need the blades to the blender bobby flay model bf 9349
Hi. Our Bobby Blender jar broke and we can't find a replacement. We can part it out; do you still need the blades?
Aug 15, 2010 | KitchenAid KSB3 Classic Work Top Blender
V5785 mixing part broken (leaking)
I need the villaware smoothie maker top model V5785 as mine broke & can't find anywhere. Please help!
Apr 19, 2010 | VillaWare 4785 Smoothee Work Top Blender
Broke the coupling to our blender #KSB50B3
If you have a Kitchenaid Blender (model KSB50B3 or similar) and the rubber teeth on the coupling (that spikey rubber thing on top of the base) broke off (see picture), here is how you can fix it yourself! The Task: The coupling is screwed onto a vertical shaft like a button mushroom. The shaft is round with two flat sides. You need to find an U-shaped thing [such as a wrench] to secure the shaft and loosen the coupling by turning it CLOCKWISE. What you need: 1. New coupling: Part number KA-9704230. Shouldn't be more than $6. I got mine at Their shipping fee is very decent and the service is also good. 2. An U-shaped object: Some had success with household forks. That didn't work for me. Most successes came from the use of ignition wrenches. There's only about 1/4 of an inch between the coupling and the base, and these very thin wrenches can get in there. You will need size 5/16 or 9/32. I got mine at Sears. They come in a set and are not cheap!! The steps: 1. Rip the rubber cover off the coupling. There's a metal disc inside. 2. Secure the shaft with the wrench. 3. Grab the metal disc with a plier and quickly **** it CLOCKWISE. This is to overcome the inertia. 4. If not loosened repeat steps 2~3. 5. Screw new coupling on COUNTER-CLOCKWISE. Now you are ready to make that smoothe or margarita or what have you again! Disclaimer: Kids, don't do this at home. I am not responsible for any explicit or implicit damages caused by you repairing your blender. Read manufacture's warranty policy before proceeding. Call their service center if you don't feel comfortable performing the aforementioned repair.
Apr 22, 2008 | KitchenAid KSB5 Professional Stainless...
Top part of base broke off
This just happened to me too, and I think I just fixed it.  First you have to get a replacement part called the "blender coupling" (I got mine online from Goodmans for $3.99).  I also replaced the square drive and slinger (two parts come together for $2.99)-that's the little part that sticks up and attaches to the pitcher.
Unscrew the bottom four screws of the base where the rubber feet are.  Remove the rubber skirt to reveal four screws that hold the motor in.  They are way in there so you'll need a long screw driver.  Remove the motor and unscrew the old coupling.  Mine had not been replaced since my grandmother bought this blender who knows when, so the coupling was really stuck.  I did not have a tool narrow enough to get a good grip to apply enough torque to remove the coupling so I had to try a few other tricks.  If your blender is the same, remove the bottom nut, fan blade and two washers.  This gave enough of a rod to grip to get the old coupling off.  (I also had to use some WD40, and heat and cool the coupling a few times to break the old seal).
Good luck!  Hope that helps!
Jan 09, 2008 | Oster 465 Work Top Blender
Blenders Logo
133 people viewed this question
Top Blenders Experts
Are you a Blender Expert? Answer questions, earn points and help others
