Question about Air Tools & Compressors
Can I useT38 MT424 nails in my trade air nailer PAB1350
  • 125 Answers
SOURCE: won't feed nail
This happens to my gun too. You probably need to oil the gun once in a while. Here is how you fix it:
Disconnect the gun from the compressor first don't wanna get hurt or anything like that. There is a pin that shoots the nail out well that pin is jammed so what you have to do is push that pin to the original position. using a flat head screwdriver would help you to push that pin back into place. Let me know how that turns out please. I pretty sure that is the problem with your gun. Make sure you lubricate the Nailer once in a while.
Posted on Oct 02, 2008
Loringh
  • 185 Answers
SOURCE: My nailer blows out air when I connect to the hose.
Skinney70
Have you been lubricating it regularly with nail gun oil. We use framing nailers every day at the commercial tree farm I work at and one of the operating instruction is to put 6 to 8 drops of oil in the air hose connection on the nailer before every use. I suspect the O ring on the piston is worn out/
Hope this helps Good luck Loringh PS Please leave a rating if appropriate Thks
Posted on Nov 16, 2008
  • 1388 Answers
SOURCE: CRAFTSMAN NAILER
Generally, if your nailer is not leaking air, the orings are probably ok. Remove the head and check for stuck headvalve or stuck driver/piston. Make sure that you can press the headvalve into the head with your thumb and that it returns. If your driver/piston is down when you pull the head, remove the cylinder and check for damage to it or the bumper. Some cylinders have an oring or strip of rubber about med section which acts as a check valve causing the piston to return to top. Check for bent driver or broken tip causing driver to jamb. Use silicone lube to assemble. Enjoy
Posted on Dec 08, 2008
  • 1388 Answers
SOURCE: brad nailer not firing nail...can hear brief air noise upon pulling the trigger
Porter cable makes a number of brad nailers (18 gauge) that very quickly suffer from the problem that you are having. You did not mention the model number of your gun but if it is one of these, (bn125a, bn200a, ns100a) kit # 60061 will fix the problem. It costs between 25 and 30 dollars. Google that part number or order from www.dewalt.com. Dewalt owns the porter cable brand. Before you order the kit, check that the driver blade is not bent and stuck. The driver should travel freely down the cylinder. When you install parts, use Danco silicone grease to lube (availabel at Lowes in the plumbing department) If your model # is different from those mentioned above, please email me and I will recommend a repair.
Posted on Apr 27, 2009
rowdy45176
  • 2176 Answers
SOURCE: air blows thru the trigger on both my finish nailer and staple gu
there is an o ring in the trigger valve referred to as a Purple o ring that is probably split. If you can find a air tool center that has them you will save a lot of money versus replacing the trigger valve. Let me know what you are going to do and I will help you with the removal of the valve.
Posted on Oct 06, 2009
I have propulse 2 inch Brad Nailer. Model 57265001. when i press switch just air blow out but no nail or nailing
1. Does it have any nails in it? A) add nails
2. Often when you get down to the last few nails it will quit working. A) add more nails, you may have to discard the remaining nail or three before adding more nails.
3. You may have reached the end of a group of nails and the last nail or 2 are jamed up in the end of the nailer. A) Need to open end of nailer and remove jamed nails. Don't forget to disconnect nailer from compressor first.
4. Other options are not enough air pressure, or the gun is damaged and needs repaired or replaced.
Good luck.
Aug 02, 2016 | Air Tools & Compressors
My senco fusion 18 nailer won't set nails
is this a air nailer or something eles. if it is a nail by air adjust the air for more pressure
Jun 10, 2014 | Senco 6E0001N 18GA Fusion Brad Nailer
My nail gun fires but no nail comes out
Wow these nailers have lots of problems. Try readjusting air pressure up or down. Look for a nail jammed in the end. Use good quality nails.
Mar 29, 2012 | RTO PasLode 900420 Impulse Framing Nailer
When I pull the trigger it will not fire a nail, air running through the nailer is all that will happen?
You could have a nail jammed. Remove the front assem. where the nails come out and see if somthings stuck like a nail.
Jan 23, 2011 | Dewalt Clipped Head Framing Nailer
My nail gun was fired and its air flowed through the trigger, but the nails don't shoot out. Why is this? Please assist me.
nail jam remove air, open front of nailer, make sure the shaft goes back up in..also check for incorrect size or type nails
Oct 22, 2010 | Nailers 3 12" Pneumatic Air Round Head...
I work for a Fire Dept. in Vermont and we use the FC350A air nailer for building shores and other wooden support stuctures for our Urban Search and Rescue team. FEMA engineers say we have to use round...
Your nailer will only use clip head. Model FR350a looks similar however is designed for full round head. Take your gun to a large fastener company that deals in mainly construction industry nails/nailers and talk to the manager about purchasing nails for future events tell him your issue with FEMA. I'll bet that you could exchange your nailer for little no cost to the department for a round head type. They usually have plenty of used, trade-in and unclaimed guns. Good luck
Sep 26, 2010 | Porter Cable Cable No. FR350A Rnd Head...
Adjusting airpresure
There is nothing on a nailer to adjust the air pressure. You have to do it at the pressure regulator. It is feasable to mount a regulator at the gun but more likely it's on the compressor. Most nail guns are rated for 90 to 120 psi. Set your regulator to hold the hose pressure between 90 and 100 psi. Using higher pressure to set the nail will ruin your nailer. Use the depth adjustment on the gun to set how far the nail is driven.
Sep 23, 2010 | Nailers 3 12" Pneumatic Air Round Head...
Wiil a 22 degree Paorter Cable FR350A Round Head
No... it will fire 21-degree nails and perhaps 23-degree nails (but sont think they exist) and it is a full-head framing nailer so it is designed for firing round head nails. Using clipped nails will likely jam the nailer as these nails are stripped closer together with overlapping heads in the nail strip and the FR350A has a full round driver so you will run into issues with clipped nails. If you are having problems finding full round head nails, you can find them on Amazon to fit this nailer. Otherwise any good tool or trade tool store that sells nailers will likely have a suitable nail supply available for the FR350A.
Feb 09, 2010 | Porter Cable Air Tools & Compressors
Senco 601 nailer shoots 2 nails each time the trigger is pulled.
the 601 had a design flaw, in the nose, where the nails hit as the are being pushed forward, the peice was made out of a peice of metal that was too soft, it wore down and that is where you get the double nail problem.
Senco offered a trade in, this was years ago, for a limited time and gave us credit towards new guns, which we gladly did
Dec 31, 2009 | Senco & Frame Pro 601 Framing Nailer
Dont know what nails to use on my makita brad nailer
is that a model AF505? if it is, your problem may be the gauge. make sure you use 18 gauge nails, he 16 gauge are too big and will jam in the gun.
Feb 26, 2009 | Makita Brad Nailer Finish Nailer...
Air Tools & Compressors Logo
82 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
