Log in to Nat West Account - Computers & Internet
I have not received my goods
sorry but we do not do that for people on this site we only answer questions that people ask . getting your merchandise from a seller on ebay is strictly between you and them and perhaps paypal
Apr 23, 2015 | Computers & Internet
My pay pal account has an old address I would like it changed to 69 Koonwarra street west haven nsw 2443
You have to log into your Paypal account and change your account information.
Apr 19, 2015 | PayPal Accounts
Natwest online banking login
You must use the login details supplied when you registered with Nat West
Mar 31, 2014 | Computers & Internet
Delete dawn west wrong name wrong friens only need one face book the crrect one Spice not west!
How do I permanently delete my account? If you deactivate your account, your timeline disappears from the Facebook service immediately. People on Facebook won't be able to search for you, though some info, like messages you sent, may still be visible to others. We also save your timeline information (ex: friends, photos, interests, etc.) in case you want to come back.
If you don't think you'll use Facebook again, you can request to have your account permanently deleted. Please keep in mind that you won't be able to reactivate your account or retrieve anything you've added. Before you do this, you may want to download a copy of your info from Facebook. Then, if you'd like your accountpermanently deleted with no option for recovery, log into your account and fill out this form.
If you can't log in to your account, you'll need to reset your password first. To do this, go to and click the Forgot your password? link below the password field. Once you've followed the instructions to reset your password and can log into your account, you can deactivate or delete your account using the steps outlined above.
Dec 31, 2013 | Facebook Social Network
I placed an order today No. NP112345748 and gave the wrong email address. my name is Jean P. Smith 1002 N. Miller St. aapt 205 West Liberty. Iowa 52776. Correct email and wrong one...
One of the steps in renewing your Norton or Symantec subscription is to create an account with them. Click here to log into your Norton account and log in. Your account will have the version you purchased or renewed and you should be able to get it to download again and just follow the screen prompts.
May 02, 2011 | Symantec Computers & Internet
1- Using your Browser, Log on to your router (by normally typing in the address check your router's manual to see what the default gateway address)
2- If you already know how to log in to your router, then skip this step. If you have never logged on to your router then more than likely you still have the default initial log in credentials (username: admin - Password:1234 ..... Again check your router's manual to be sure). The minute you log in you need to change that password immediately, most network-savvy folks know that 90% of the people out there never reset their router's initial password and they can log on and make any changes to suit their needs, including locking you out of your own router.
3- Once you are logged in, you should be able to find two advance settings (One if for NAT - and the other is for Upnp)
4- Let's start with the NAT setting changes, and we will move on the Upnp at the end. I have personally tried the NAT setting changes and it didn't fix anything, I still had a "Strict" NAT setting on my xbox360, Only when I checked for the Upnp "allow authorized incoming traffic" options when the NAT settings on my XBOX finally came back as "Open" and not "Strict". But I will still explain what I did anyways with the NAT table cause I know it may work for some other routers.
5- So what I did with the NAT setting is this. I located the NAT advanced setting on my router, I click on the NAT (Edit List setting) or whichever link/button you have on your router advanced NAT settings to access the table needed to open certain ports (TCP and UDP - 88 & 3074) .
6- You will need to find out what the static/dynamic (preferably Static) IP address you xbox360 has. To do so, go to the Dashboard, go to the Console settings page, and click on the network settings to see the IP address (should be something like 192.168.1.x). You will need that IP address to enter into your NAT table on your router.
7- Once you got your XBOX's IP address enter it in the NAT Port Forwarding table (From - To - IP address: those are the 3 fields you should have on the table if you are using SUA NAT)
8 - In the first line enter 88 under both "From" and To" fields, then enter the IP address of the xbox in the field where you are to enter an IP address. (this is for UDP port)
9 - Repeat the same step for port TCP (which is 3074)
10- If these changes do not help open your NAT settings, then try the Upnp option. Click on your Upnp Advances settings and click on the "Allow Traffic" option, this is mostly secure because you are only accepting the incoming traffic that matches your outgoing traffic.
Mar 02, 2011 | Belkin Basic Wireless Router
How do I change my NAT settings on this modem
Your NAT settings have to do with your router, not the modem. Log into your router's control panel. This is normally done by typing If that doesn't work, go to Start, type in cmd, hit Enter, then type in IPCONFIG. The Gateway Address is what you want to type into your Internet Browser. You will need to log into the router's Control Panel once you type this in. This is usually done by typing in "admin" as the username, or the password, or both.
This will be different depending on the manufacturer of your router, but once you log in, look for two advanced settings called NAT and UPNP. They should be near each other. You want to change NAT to Open.
If that doesn't work, go to and check the port codes from the service you are trying to connect to. You can enter these codes into the Port Forwarding section of your router's control panel.
Hope this helps!
Feb 14, 2011 | Arris SURFboard® SB5101 Cable Modem
How to change tp link tl-wr641g nat type? I am trying to play online and it says it is restricting my games because nat type is strict?
NAT is Network Address Translation.. It is a setting of the router... you need to login to the router navigate to the NAT page and set it to the required settings save and log out
manual below
Mar 05, 2010 | Computers & Internet
I need to change my nat type from strict to open
This router does not have the typical "strict or open" NAT types. Looking at the manual, it looks like what you want is NAT enabled and SUA only enabled.,420041221102511,420041221102520,420050117110858,420050117110916,420050117110934,420050831093216,420050831095441,420060420160946,420060420161739,420060816160116,420080815092146,420090427144843
Page 133 has the details.
Log into router
go to the NAT tab
Enable NAT
Enable SUA only
Apply the change.
Nov 18, 2009 | Zyxel P660HW-D1 Router
Computers & Internet Logo
26 people viewed this question
David Payne
David Payne
