Question about Canon PIXMA MP150 All-In-One InkJet Printer
Scanning I want to know that if the cartridges are empty, and Error code 5, is there a way that I can still use the scanner? I have tried to scan, but to no avail. thanks! Charles
  • crstokes Nov 21, 2007
    I have tried the steps suggested. Did not work. Still shows error 5, and I cant use the scanner. Does the scanner work if the cartridges are empty or not installed??
    This is what I did according to solution 1:
    1.Switched printer on
    2.Opened cover to access cartridges, took both out.
    3. Closed cover.
    4. Unplugged power cord
    5. Held resume button, plugged power in, released button.
    6. Pressed resume button and released.
    7. Press and held resume button, released
    8 Did step 7 again.
    9. Pressed power to set data.
    After all of this it seems as it did not work. Did I do something wrong?
The all in one's are designed to only function (scanning included) only with working cartridges, but resetting the memory can many times bypass this.
Posted on Nov 21, 2007
    Problem Solver:
  • 5 Answers
Reset memory on it:
1: Remove Cartridge
2: Unplug the Power Cord
3: Hold down the RESUME button
4: Release RESUME after plugging in the Power cord.
5: Press the RESUME once within 5 seconds and release the RESUME .
6: Press and hold RESUME for two seconds or more and release it.
7: Press and hold RESUME for two seconds or more and release it.
8: Press POWER to set data.
Posted on Nov 20, 2007
Toner empty error message
my dear you chek toner and change toner tenk
Jul 08, 2015 | Xerox WorkCentre 3119 Laser Printer
If black or Color cartridge is empty in canon MP145 all in one printer, so scanner is not scan. how to scan without cartridge?pleae help me.
Hi, The scanning unit is independent from printing unit. You can scan even with empty ink cartridges. At sametime, if you wanna copy documents, you need both scanning and copying units to work. Try reinstalling the Driver from the provided driver CD.
Sep 02, 2010 | Canon Office Equipment & Supplies
How to load ink catritridge #4&5
plz follow the steps below:
Step 1 Locate the "On" button located on the top right side of the Lexmark 2600 Series Printer Scanner. Turn the unit on by pressing and releasing the "On" button one time.
  • Step 2 Raise the scanner unit until it locks into place. Allow the print cartridge carrier to move to the loading position. Wait for the print cartridge carrier to stop moving.
  • Step 3 Locate the color print cartridge in the carrier on the right. Release the empty color print cartridge by pressing down on the cartridge carrier latch. Raise the cartridge carrier lid. Remove the empty color cartridge by pulling it straight up. Place the empty cartridge in the plastic bag and set aside for recycling.
  • Step 4 Remove the new color cartridge from its packaging. Remove the protective tape from the nozzle and connector on the back and bottom of the color cartridge. Dispose of the protective tape.
  • Step 5 Install the new color cartridge into the right cartridge carrier slot. Close the cartridge carrier lid. Press down on the cartridge carrier lid until it clicks into place.
  • Step 6 Raise the scanning unit slightly. Release the scanning unit support. Close the scanning unit.
  • If u find this post helpful, then plz vote it.
    Thanks
    Apr 27, 2010 | Lexmark X2600 InkJet Printer
    Canon PIXMA mp240 All-in-one InkJet Printer. Error code: 2,140,2
    If you get a warning regarding Ink is Empty and even you cannot Scan your documents then you might require a small R&D, Just hold Stop/Reset button for about 5 seconds, then open cartridge access door, Remove both the Cartridge's and wipe it with the wet tissue or cloth... spray water or deodorant on the exposed golden surface of the cartridge and do not let it dry, install as soon as possible... Then close the cartridge access door and switch off your printer, then Re-start it and connect to your computer, Hold Stop/Reset button for 5 seconds and then enjoy scanning...
    Dec 09, 2009 | Canon PIXMA MP240 All-In-One InkJet...
    Hi, I need your help with this problem: the Canon MP210 ran out of color ink. I have removed both the cartridge. Anyway, the problem is not in the E5 error. The problem is, that the scanner does not work,...
    The scanner and the printer are connected together.Both need initialized for printing or scanning.You can't scan if you haven't cartridges in printer and you can't print if the scanner not initialized.Put cartridges back and press and hold the resume button for 5 seconds.If you still have E5 error that mean you have a defective cartridge and you need to replaced.
    Oct 19, 2009 | Canon PIXMA MP210 Photo All-In-One Printer
    Error message code 2,140,0
    I had a similar problem (error Code:2,140,2) in Canon PIXMA MP250 all-in-one, and it was solved when I replaced both ink cartridges which were in low ink (almost without ink). I know an scanner problem is not supposed to be in relation with ink or printer problems, but that's the way I've fixed it. Good luck!
    Mar 16, 2009 | Canon PIXMA MP240 All-In-One InkJet...
    MP210: Can I use the scanner without the printer?
    yeah same problem here wit a mp160.. will try it with new cartridges, if that fails, i'll never buy canon again
    Jan 18, 2009 | Canon PIXMA MP210 Photo All-In-One Printer
    E5 and 2,114,0 errors on Canon MP160
    Empty cartridges may cause this error. Here is the error code list for your printer
    E2-2 = No paper (ASF)
    E3-3 = Paper jam
    E4 = No ink
    E5-5 = The ink cartridges are not installed or a non-supported ink cartridge is installed, or the ink cartridges are not installed properly
    E8 = Waste ink absorber full, or platen waste ink absorber full
    E9 = The connected digital camera / video camera does not support Camera Direct Printing
    E14 = The Ink cartridges whose destination are wrong
    E15 = Ink cartridge is not installed E16 - Ink remaining is unknown
    E16 -E19 = Failed to scan head alignment sheet
    E22 = Carriage error
    E23 = Paper feed error
    E24 = Purge unit error
    E25 = ASF(cam) sensor error
    E26 = Internal temperature rise error
    E27 = Waste ink absorber full or platen waste ink absorber full
    E28 = Ink cartridge temperature rise error -
    E29 = EEPROM error
    E33 = Paper feed position error
    E35 15 = USB Host VBUD overcurrent error - USB
    E37 17 = Abnormal motor driver error
    E40 20 = Other hardware error
    E42 22 = Scanner error
    If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
    Thanks, Joe
    Nov 13, 2008 | Canon PIXMA MP160 All-In-One InkJet...
    Scanning
    I don't think it'll be able to function given it has any error u need to get rid of the error message first sorry.
    Nov 28, 2007 | Canon PIXMA MP160 All-In-One InkJet...
    Canon PIXMA MP150 All-In-One InkJet Printer Logo
    old marine
    old marine
