Question about Garden
When engaging cutting leaver on rideon the belts underneath are still loose and does not turn cutting blades .all springs look okay
  • Garden Master
  • 2,321 Answers
Are you sure the belt is good. May be coming apart. If its ok check the pulleys and the belt adjusting tightener. sounds like something is not working properly. Have you installed a new belt and is it the right one for that machine. Has the belt slipped off the tightener. Can't say but just giving suggestions.
Posted on Dec 26, 2016
On my trroy-bilt lawn tractor pony i was in high grass it seem to stop cutting smoke came from the deck stop cutting the handle that engage the blade become reaaly easy to move nothing happened
It sounds like you got into a job that was too big for the machine, and you may have either burned up the drive belt, or toasted the transmission or clutch.
Someone knowledgeable about such things should be able to raise it up in the air and look underneath and discover which problem you have.
God bless your efforts.
Jul 08, 2016 | Garden
Blades won't engage on my zero turn 50" cut husqvarna (approx2011) I found a 7" spring on the ground and don't know where it goes back on. Can u help
Looking underneath the mower on top of the deck there should be a flat metal arm with a flat faced pulley on the end. This pulley pushes against the belt that drives the mower deck . The spring should be hooked on that arm and pulled tight over to a place on the deck and this is what keeps the belt tight enough to turn the blades when you engage the pto switch. My recommendations to put this back on is to remove the belt pulley cover on the deck right side roll the belt off at that pulley giving you a bunch of slack so you can hook up the spring and put the belt in the right position on everything else then go back to the deck right hand pulley start putting the belt back on that pulley and when it is to tight to get it all the way on reach under the deck and use the blade as leverage to finish turning the pulley and walk that belt on the rest of the way ,it will not hurt a thing, all you are doing is pulling that 7 inch spring over like it was intended to be, then replace the cover on the deck spindle.
May 17, 2016 | Husqvarna Garden
When I engage the lever for the blades to start cutting, the blades don't engage
Check for bad or loose belt also see if you are missing a shear pin in one of your drive pulleys. See if your lever to engage the blades is actually putting driving pressure on the belt. Could be a spring is missing as well.
Apr 12, 2015 | Garden
How to adjust a loose mower deck drive belt?
check your pulleys to make sure they haven't split as this does happen. Adjust the belt tensioner to tighten the belt when you engage the clutch to drive the mower. You should be able to see the belt tensioner by dropping the cutting deck to its lowest point and looking underneath the mower to see which pulley actually puts the tension on the belt to make it drive. there is no need to start the mower to find which pulley needs to be adjusted, it should be obvious when you look at the belt and the pulleys.
Hope this helps you
May 17, 2014 | Garden
Blades will not engage
when you actuate the "engage blade" lever, two things may occur,
First, a mechanical action, a spring moves to put tension onto the belt.
Second; at the end of its run, actuate a switch (PTF switch) to engage the clutch that moves the pulleys that consequentially move the blades.
if the tensioner is not moving , check if spring has come lose, undone or broken, (more likely in your case) or check the PTF switch.
any other assistance, contact me, good luck.
Apr 20, 2014 | Husqvarna Riding Lawn Mower 46 Cut Kohler...
Craftsman lt 2000 42
Hi, first check the spring that pulls on the idler pulley for lost tension then run the blades for a 10 to 15 minutes at half to full throttle. This is necessary to bed the new belt into the old pulleys. Regards Phil.
Sep 05, 2012 | Garden
Craftsman LT2000 Blade is staying engaged all the time, just did a blade mandrel replacement, where does the spring for the blade control reattach? What would make the blades be in motion all the time?...
sounds like you may not have the right mandrels making the belt to tight and it cant be left loose enough to allow the blades to quit turning.Otherwise you didnt put the belt back on correctly if it is around the tightener pully the wrong way that to will make the belt to tight
Apr 09, 2012 | Craftsman Garden
When I try to install the blade by pushing down and turning the top leaver clockwise, nothing happens. I appears that the leaver is not turning the nut under it. I can't get to the nut to turn it.
there is a very small spring under the mechanism that might have broken. To remove/install the blade you need to lift up on the lever to engage the nut to tighten the spindle until snug and then push the lever down.
Apr 20, 2011 | Skil 1587AVSK - Bosch Jig Saws Power Tools
G-110 deck belt keeps jumping off pulleys
check for a broken belt tension er or maybe grass clippings under belt area, check for a broken or loose pulley bearing, even a bent shaft on the deck.
Aug 07, 2009 | Mtd 46" Dozer Blade, Fits All & Yard -...
Stalls when engage blades in forward, but cuts fine in reverse
Did you try to disengage the safety feature that should shut the tractor off when the blades are engaged and the tractor is placed in reverse? I believe that it is located under the shift leaver
May 14, 2009 | Mtd Garden
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
