Question about Ovens
Cooker flases up A4 will not start central heating fine what can I do to start oven
    Top Expert:
  • Ovens Master
  • 49,235 Answers
Contact the manufacturer .or Google it we have no idea what you have in use
Posted on Dec 26, 2016
How do I change the element surrounding the fan
The motor driven fan central to the element is blowing the heat off the element to disperse is around the oven box, however, this brings the first .... Make sure that the cooker has not been running or has power on it before you start work on replacing the fan element, one can cause burns and the other Buy Instagram Followers UK Get free Likes on Instagram from 0 59
Dec 15, 2017 | Ovens
Beko DVC5622X bottom oven wont heat up
This tutorial will show you how to check your Beko element and how to replace your Beko cooker element.
Here are the 3 main faults to look for in your oven or cooker that is not heating
    1.Your Beko oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Beko manual.
    2.If your Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
    3.When you turn the oven on, the household electrical supply trips on the Rcd (this is the earth trip in the fuse board sometimes called the breaker tripping) your fan oven element has gone to earth and needs replacing. If this helped you why not get me a beer?
Paul is from the Naturally he would appreciate beer How to Repair Home...
Oct 27, 2011 | Ovens
I have a westinghouse 476 gas oven, the oven does not turn on all the time the ignitor heats up but no gas comes out. when i take the cover off the ignitor and tap on base of oven it ignites and works...
It sound like you have a valve problem some types of ignitors have a heat release valve, by hitting it you cause this to release, I would suddjest replacing the ignitor unit but this requires a Gas Fitter that is approved, as all sorts of tests, requires specialised equipment, if you have gas central heating, the service engineer could perform the same for your cooker. remember to ISOLATE MAINS POWER if this model uses it for ignition.
Hope this has been helpful
Jun 06, 2011 | Ovens
My whirlpool oven will not heat up, the fan comes on and the display is fine but the oven wont heat up.
If your electric oven is not heating then you probably have a bad heating lelement in your oven. This is not that hard to fix yourself...
Check out this tip that I wrote about the Oven not heating problem..
Oven Problems Electric Oven is Heating Slowly or Poorly
May 05, 2010 | Whirlpool RBS245PD Electric Single Oven
How do I change the fan oven thermostat on cooker Tricity Bendix SIE 531 TCGR
These will give you the basics
1 How to change a fan oven element and How to change a cooker oven fan Motor
2 How to fit a New Thermostat to a Cooker or Oven
If you have a electric Cooker or Fan Oven which is not heating it could be one of the following problems.
3. If you have the opposite problem i.e. your oven is over heating and burning everything then you will need to replace your oven
Mar 04, 2010 | Ovens
Our oven will not heat up. Wife did used the self
If you have a problem with your cooker or oven then this diagnostic video will help you find the fault and i hope it helps you. i have put a link also so you can get the parts for your cooker
cooker parts
Need help fixing your appliances
these repair guides will also help you find and understand the exact problem with your cooker
How to Repair
and if we really helped you you could always buy us a beer
Buy Paul Beer
Feb 15, 2010 | Whirlpool RBS305PDS Electric Single Oven
Oven does not heat. Broiler and stove work. NO gas smell.
could be the oven thermostat, get a plumber/heating engineer out, but make sure you can trust him, cause he could try and say u need a new cooker when it MIGHT only be a new oven thermostat.
Feb 02, 2009 | GE Ovens
Oven not heating up but fan and light on
oven not heating up but light coming on fan working and grill working . it allso heats up on other settings but not enough to cook
Jul 04, 2008 | Baumatic B187 Stainless Steel Electric...
Ovens Logo
26 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
Are you an Oven Expert? Answer questions, earn points and help others
