Question about Konica Minolta bizhub Office Equipment & Supplies
Konica bizhub 600 after scaning show now printing
  • Konica Minolta Master
  • 6,674 Answers
Sir/Mam,
Have you had the developer and drum replaced recently, or does the screen say Replace PC Drum? There are certain house chores the copier does before "Ready to Copy" it is waiting for them to get done, so that equals "Please Wait". One big item is making sure the developer and toner are properly mixed inside the image unit underneath the drum or next to it depending on the series. Might want to have the developer replaced and drum/cleaning blade normally done all together, then run the F8 procedure/Developer Charge, and make sure the counters where cleared. Did you recently replace the drum and the developer if so did you clear the counters for the drum and developer, FIRST? IF not then the copier thinks the new drum and new developer are old. The copier works on the counters that is how it knows it got a new drum and developer. Get new developer and a new drum and have it installed correctly. Counters are clear before the unit is yanked out of the machine, then you remove the image unit/drum unit replace the developer/drum and cleaning blade. (DO NOT USE A VACUUM CLEANER WHEN REPLACING THE DEVELOPER static electricity can destroy the sensor located below the developer unit. Then reinstall and RUN F8/Developer Charge. Make sure the fax line and Ethernet cable is removed can't print anything until the F8 is run. Or you will start all over again with new developer and a new drum.
Posted on Jan 08, 2017
SOURCE: konica minolta bizhub C252 printer Problem
Is anyone else having problems getting Konica to stand behind its products.
Posted on Dec 20, 2007
  • 44 Answers
SOURCE: How do you do a hard reset on a Konica Minolta BH 600?
To recover/change the Administrator password perform the following;
1. Enter the Service mode.
2. Press STOP-0-CLEAR to enter the Enhanced security mode.
3. Enter Administrator Password setting, and enter new Password.
Posted on Nov 29, 2009
xeerie
  • 347 Answers
SOURCE: desbloqueo del codigo m2 en konica minolta bizhub 163
Este código significa que la vida las partes de su desarrollo + unidad de imagen se ha caducado. Ahora es el momento de reemplazar las partes.
Posted on Jun 19, 2010
hamzaskilltd
  • 316 Answers
SOURCE: Solution for error code c2557 konica minolta bizhub 250 machine
ADTC sensor failure
Posted on Aug 07, 2010
sinclair_cum
  • 38 Answers
SOURCE: konica minolta bizhub pro c6500 error c2452
i have checked all those parts and tested them with a multimeter and there seems to be no problem is there any other way i can overcome this problem
Posted on Nov 15, 2011
How to reset a password of bizhub 600-750
Which password the admin or the individual passwords Default admin 12345678 or 00000000
Go to:
Admin setting- Security setting -admin password
Oct 23, 2014 | Konica Minolta Bizhub 600 750 Image...
PROCEDURE CHANGE DEVELOPER KONICA BIZHUB 600
First clear the developer counter in service mode.
then remove the drum cart. remove developing unit. remove old developer. then run Auto max density. If you don't and make a copy or print you will have to replace the developer again
. recommend cleaning all toner around the drum and drum sensors requires removing drum be careful a nick on the drum will show up on all copies/prints
Apr 24, 2014 | Konica Minolta Developer 02xk Dv710 for...
Hard Reset Konica Bizhub 600?
Any reset will wipe the memory and network settings so I would recommend you have tech look at it and see if you can save all setting before wiping clean
Apr 01, 2014 | Konica Minolta Office Equipment & Supplies
Konica minolta bizhub 6oo Plz wait warming up is showing plz tell me ho to fix this.
Check yout waste toner container. If it's full you should clear it or change it. Or maybe the problem is in some sensor, probably temperature senor on fuser.
Dec 17, 2013 | Konica Minolta Developer 02xk Dv710 for...
Error code c6708
Please send me konica minolta bizhub 600 full service manual and help us this code c6708 still and my next machine bizhub 750 still warming up why problem this machine please help and send me your email address.
i want to talk to you continuous
May 18, 2013 | Konica Minolta Developer 02xk Dv710 for...
My konica minolta bizhub 750 show me 5003 error. please can someone tell me what it means and solutions. thanks
Printer Control Board fault. Recommend first checking all connectors pull each one out then reseat them, as you do that check each connector on the board for a bent pin, if not have bad image control board $$$$$$
Apr 02, 2013 | Konica Minolta Bizhub 600 750 Image...
KONICA MINOLTA bizhub 601 problems
Does the machine work ok as a copier? Not as a Printer but a copier? if so then check you printer properties and insure that the paper is correct portrait or landscape, thickness correct draw check a different computer.
Dec 12, 2012 | Konica Minolta Developer 02xk Dv710 for...
I connect the konica minolta bizhub 210 to my win xp system then i try to print but i can't the system show the message "failed to print" what is this .please help me
SOLUTION:- Follow these steps. 1-First of all take a usb cable. 2-Connect its one end to Bizhub 210 and the other end to your computer. 3-you will see your computer will show a notification " Found new hardware". 4-Now insert the printer Driver disc of Bizhub 210 in CD-ROM. 5-autoplay will show at the desktop 6-Now click on "Install Printer" 7-Follow the instructions and install the drivers. 8-when the drivers are correctly installed you will see printer icon of bizhub 210 in "Printer and Faxes" at control panel of your computer. 9-Now right click on this icon and click on "Properties" 10-now click on "PRINTING PREFERENCES" tab. 11-select Paper size, i.e if you are using A4 size in bizhub 210 then select paper size=A4 from the list. 12-now give a print command.ctrl+p. of any document. 13-printer will start printing.
if still having problem, then please do check the usb cable, it may be broken. if there is any other printers are installed on your computer which are not in use then remove them/ delete them. use konica minolta bizhub 210 as a default printer.
Jun 28, 2010 | Konica Minolta bizhub 180 All-In-One...
37 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
