Question about Refrigerators
I have a defy c310bd fridge freezer that freezes a lump of ice in the fridge above the crisper and freezes the defrost outlet?
  • 42 Answers
SOURCE: kenmore elite fridge crisper drawer freezing stuff
If you have a side by side model you need to look at the refrigerator compartment wall on the left of the bottom drawer and move the slide control to the warmer/fruit/vegitable setting instead of the meat setting.
I hope this helped. Please rate my help or ask for more help please. supertechks
Posted on Apr 06, 2008
shaggyrat
  • 1224 Answers
SOURCE: Side by side refrigerator freezing up
inside the fridge there is a cold radiator which has filled with condensation or water from freezing it when say cleaned out the fridge this can be remedied by letting set for a few days outside in the sun so that water can evaporate properly or you can call a repair man and he can pull out frost radiator inside and defrost all the water out by dry wet vac and heater dryer
ice builds apon ice even a little bit can build up to a mountain same thing happended to my top end whirlpool i pulled the metal grate and defrosted this by pouring tap water over the ice which it went down the defrost tube outside water drain this helped greatly havent had trouble with ice since
Posted on May 13, 2008
vanni7
  • 163 Answers
SOURCE: water dripping from top of fridge then freezing under crisper's
HII Your drain line is plugged remove evaporator cover and get a hair dryer and remove all the ice built up on the drain line its a hole just below the evaporator..show here the hole is on the left side.Good
Posted on Jan 05, 2009
SOURCE: ice buildup in the freezer. dripping from above refrigerator area
I have had water/ice down the back of a Gladiator as well. I just emptied it, disassembled the back wall of the upper portion of the unit. Just a few screws, and one has to disconnect a wire harness, and then after removing styrofoam and yet another panel, I was able to locate the drain hole. It was frozen solid. As I have hot water in the garage, I sprayed some in the drain hole area and then in the lower portion to get rid of some of the ice. After alternating several times (and removing the lower panel on the back of the unit), I was able to see a free flow of hot water from the drain tube at the lower back of the fridge. I have towel dried everything and have a fan on it now so that it is very dry before starting back up. I am guessing that the drain tube starts to freeze in the winter months (I am in Wisconsin), and then just has no way to thaw as it is sandwiched in the back wall of the unit. This winter I may try some extra insulation. Good Luck!
Posted on Jul 21, 2009
BMT60
  • 126 Answers
SOURCE: Frost accumulating on back of fridge - service light blinking
YOUR EVAPORATOR IN THE FRESH FOOD SECTION IS LEAKING FREON. THIS IS COMMON WITH EVAPORATORS IN THIS AREA. 12 PART WARRANY OR 6 YEAR FULL ON THIS. SUB ZERO HAS SUPERIOR CUSTOMEER SERVICE AND MAY COVER FULLY IF OUT OF THE 6TH YEAR. 1-800-222-7820 CALL THEM AND ASK.
Posted on Apr 24, 2010
Defy 620 litre side by side fridge freezer freezer not freezing or defrosting ice packs but when ice is remove than freeze until ice packs again
Try unplugging the refrigerator for 24 hours (Of course, remove any food.) Be prepared for it to leak. Then make sure the coils and door gaskets are clean. (A thin coat of vasoline applied to the door gaskets should help).
Sep 20, 2013 | LG LSC26905TT Side by Side Refrigerator
My fridge is leaking water down the back into crisper
The defrost drain is stoppped up. The easiest way to solve this is with a compressed air tank. At the back of the ref. at the bottom you will see a hose leading into a drain pan.Blow the air through the hose and it will unstop the drain.Hope this helps !
Sep 29, 2017 | Whirlpool GT1SHTXM Top Freezer...
Food in crisper drawers freezing
HI. UMMM I WOULD DEFROST ALL FIRST.24/48 HOURS.AND TRY.MIGHT BE PARTIALY BLOCKED WITH ICE IMPAIRING CIRCULATION.GOOD LUCK.ALI
Jul 05, 2012 | GE (GTS16BBS) Top Freezer Refrigerator
I have defy fridge/freezer combo c380, freezer gets cold at bottom but fridge above does not want to, what can be the problem?
Defrost cycle has problems. Could be defrost timer, heat element, or defrost stat. temporary solution, if you can see ice accumulated inside the fridge on the back wall, desconnect or turn it off, until this ice it's gone, can be use for couple days, until service could be done on it.
Dec 23, 2009 | Refrigerators
Freezer moisture overflowing into refrigerator
your drain is clogged, defrost the freezer and locate the drain either on the back or in the bottom of the fridge and clean it out. the water is coming from when the fridge goes into defrost
Sep 24, 2009 | Refrigerators
Water in bottom of fridge and in crisper drawers
the defrost drain in the freezer is clogged with ice.
empty the food from the freezer, and put through a defrost. you might have to help the fridge defrost with a hair dryer. you may also have to remove the rear panel (inside the freezer) or pending on the model to bottom panel of the freezer.. (usually held in by 1/4" hex screws.)
melt all the ice, and be sure that the drain is clear, and it should work.
May 26, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
Water dripping from top of fridge then freezing under crisper's
If the freezer is on top then empty out the freezer and remove the bottom and back liner of the freezer compartment usually phillips screws. In the back you will see the freezer coils along with a defrost element. Below these two items u will see a drip tray that collects water from the coils on defrost cycle, in the center of the pan will be a drain hole that connects to a hose that leads to a pan under the refrigerator.Normally the water is collected there and evaporated. The hole in the tray in the freezer is clogged. Thaw it and clean it until you can pour water in it and it goes to the pan down below. please rate me
Jan 08, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
Fridge freezer
did your friend use a knife to prize off lumps of ice? i bet he/she did and has punctured the evaporator. if so, not repairable
Jul 04, 2008 | Zanussi Freezers
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
