Question about Electronics - Others
Can I record from a Sino Tec TV[ STL-32VN80] TV to a Memory stick[SanDisk] in one of the rear sockets on the TV
3 Suggested Answers
  • 336 Answers
SOURCE: how to insert sandisk memory stick micro 1gb to computer?
Yes, you will need an adapter unless you have a card reader that accepts that specific type of card.
Posted on Dec 05, 2009
bronk50
  • 27725 Answers
SOURCE: How do I transfer ereader books from a memory stick to my Kobo Vox
you will need to connect your Kobo Vox to your computer
click start click on computer to open you should see your drives C: and your other drives cd dvd and your Kovo Vox drive E: or F:
it might be seen as a mass storage device
from there you select the files right click on the file/s right click copy navigate back to the drive right click select paste or hold the mouse cursor the file/s drag them to usb drive then drop them example on how to safe data/files to a usb drive
click start all programs accessories open windows explorer navigate to your data
right click on the data select copy navigate back to the usb drive right click select paste or select
the data hold the mouse cursor then drag the data to your usb drive then drop it in
or if you are downloading data from the internet
once it starts downloading windows will ask whether you want to run or save it
a browse option will open you can save it into a folder in my documents or another device or a
usb device
if you need more help with this post a reply
hope this helps
Posted on Sep 03, 2012
Can I insert a Memory Stick to the USB Port &extract , say a movie ive downloaded, then put the M/S into a TV USB PORTAL, & show that Movie on the screen?
Depends entirely on your TV. If it is a smart TV with a USB socket on the back, then probably. You may need to change the format that the movie is recorded in. you can use a free converter for this - 'Handbrake' is very good for this.
Apr 08, 2016 | Tablets & eReaders
Why wont my computer recognize my sandisk memory card anymore
Sometimes it happens that your slot doesn't work you can use a another option like Olympus LS-10 digital recorder as a card reader for accessing the data. Insert the SD card in your LS-10 digital recorder then connect the recorder to the computer with a USB cord then it will show you two options for the onboard storage inherent and one for the SD-Card. Select first photoshop elements to read the card and then Windows Live photo Gallery to view and copy your photos.
If the Information helped you out then please give me some ratings. Thanks
Jun 01, 2012 | Sandisk 4 GB Standard SDHC Card with Rezo...
Purchased a Technika Model 19-220. 8 months ago never used the DVD recorder because we never had freeserve. Now we are connected to Freeserve the DVD will play DVD's but no accept blanks for recording...
Thanks for posting to Fixya and it is my pleasure to guide you.
"Will not accept blanks for recording it says No Disc."
from Technika manual: Start Quote
VCR/DVD Recorder; I have connected the TV to my VCR or DVD Recorder via SCART but it is not recording. In addition to connecting via SCART, you should connect the aerial cable from the wall socket to your VCR/DVD Recorder and another aerial cable from the VCR/DVD Recorder to the TV." Also; "Check the DVD is a region 2 disc - to change the region of the DVD player, refer to section 'Changing Regions'.
Note: USB record function is only avilable in Digital/Freeview TV/Radio mode. Due to copyright laws and illegal copying/recording it is not possible to record to/from any other input/output source.
DVD MENU: To access this menu, press [MENU] button on the remote control. TV System - Choose from the following options. NTSC; Normally used for discs from North America, Japan etc.
Auto; For both NTSC and PAL. This TV/DVD player is pre-set to play Region 2 DVDs.
Tip: This television contains one TV tuner, therefore it can only record the channel you are watching or record one channel while the television is in standby mode.
Tip: This TV/DVD player is pre-set to play Region 2 DVDs.
End Quote
You can not record to a DVD, according to their manual. That is why you get the no disc error. It does not have the play sector at the beginning of the DVD. You can record to USB Flash Drive however.
Quote:
USB RECORD - DIGITAL/FREEVIEW MODE
Built into this television is a USB record facility. This function is available in Digital/Freeview mode when used in conjunction with a compatible USB memory stick or USB Hard drive. The benefi ts of this are as follows:
• Pause live TV/Radio and then playback, fast forward and rewind (up to live TV)
• One button record, if you decide you want to record the current programme
• Easy programmable recording from the 7 day TV Guide
• Record TV/Radio and watch/listen back on your computer/laptop
Due to the nature of the product, it is necessary to use a high speed USB memory stick (as the TV reads from and writes to the memory stick at the same time, some memory sticks may not be suitable). You can purchase high speed memory sticks from some computer stores, alternatively, we have a selection of tested and compatible memory sticks available to purchase directly from the helpline/web site. These are available in 4GB, 8GB and 16GB. (Please check the web site/helpline for latest specifications and prices). End Quote
Good luck and please post back that you this has solved your problem and click thumbs up of your success or that I can be more helpful.
Jun 06, 2011 | Televison & Video
Is a file transferred to a memory stick traceable???
Yes.. & No... yes because it can be read after deleted maybe. And no because it hasn't got a GPS in it, but there is a record of a copy to a usb device that does have a particular number allotted to it. So a lot depends of whats what but if the chain is unbroken and they have the key well they can say that key was there got that info...
Mar 01, 2010 | SanDisk 2GB Memory Stick Micro M2 Memory...
How to insert sandisk memory stick micro 1gb to computer?
Dec 05, 2009 | SanDisk 1GB Memory Stick M2 Memory Card
I insert a memory stick and it says "No memory Stick" although it will take and record pictures . Does anyone know where i can purchase a 128 Memory stick for the DSC -F707?
You should purchase online from some secure seller.
Like here, its Sandisk Homepage.
search for the compatible Card from the bottom right tab.
Also Note that DSC -F707 doesn't support more than 128-Mb cards.
If helpful, Kindly DO RATE!
Best Regards.
Jul 17, 2009 | Sony Cyber-Shot DSC-F707 Digital Camera
Recording onto memory stick
JUST GET A NEW MP3 PLAYER WITH LOTS OF MEMORY SIMPLE AS THAT!!!!!!!!!!
JK JK JK JK JK
What you do is if you are using windows media player to transfer songs onto the player where the device picture is, it is supposed to say NEXT DEVICE then you click on it. real simple really. its like to devices on one. it literaly is to devices in one. Hope this works. RATE PLZ :p
Jun 13, 2008 | SanDisk Sansa e250 MP3 Player
Electronics - Others Logo
91 people viewed this question
Top Electronics - Others Experts
Are you an Electronics - Other Expert? Answer questions, earn points and help others
