Hot water stopped pumping, cold water works oK
Have you tried cleaning the screens where the hoses connect? sometimes hard water can clog them up and as a result will not get hot water or it could be your pump.
Posted on Dec 26, 2016
    New Friend:
  • 4 Answers
There might be problem with the hot water arriving spot. You should get a repairer to solve this type of malfunctioning or else damaged entire machine and the features set to unconditional.
Posted on Mar 22, 2017
    New Friend:
  • 3 Answers
Call An Expert
Posted on Mar 02, 2017
Tank full of hot water,faucets deliver only cold,water trickels into tank with rapid intermittend pump action
1) Copy following link:
http://waterheatertimer.org/Crossover.html
2) Add comment with clear description of water heater, fuel type, and pump?
Is this a pump problem or water heater problem?
Is this a water well pump?
Are you getting good stream of cold water at tap?
Which water heater do you have?
Is the heater new?
Or older heater that stopped working.
Dec 27, 2012 | Atwood 10 Gallon Gas/Electric Water Heater...
Maytag Performa wont fill hot water
The water fill valve - The water fill valve is a mechanical and electrical part, the coils on the valve need electricity to mechanically open the valve to allow the water to flow into the washer....myth....the washer pumps water into itself...no, it does not. The fill valve opens and the house water pressure pushes the water into the washing machine.
No cold water or no hot water - The fill valve has two coils, one for the hot water and one for the cold water. It is possible that one of the coils can fail and you loose that filling ability. If the cold water coil quits, the hot will still work and during warm fill you will get hot water only and during a cold fill you will get no water at all. If the hot coils quits, you will still have cold water fill, cold water only on a warm setting and no water on a hot fill setting. You can No cold water or no hot water - The fill valve has two coils, one for the hot water and one for the cold water. It is possible that one of the coils can fail and you loose that filling ability. If the cold water coil quits, the hot will still work and during warm fill you will get hot water only and during a cold fill you will get no water at all. If the hot coils quits, you will still have cold water fill, cold water only on a warm setting and no water on a hot fill setting. You can test a fill valve live for 120 volts, power to a fill valve coil and no fill = a bad fill valve. You can also test the coils for continuity, no continuity = a bad fill valve. Some Maytag washers have a fuse in the fill valve circuit, if this fuse let go the washer will not fill. Fill valves can also from time to time stick open and not stop filling. If you have to shut off the fill valves to stop the water from filling in the washer, you have a bad fill valve and you will have to replace it.
Nov 27, 2009 | Maytag Performa PAV2200
Hot water stopped working Cold is OK
may be the new facuet see if the hose is clogged detach it from the sink turn on the water and see if it comes out into a bucket if it does than its your new facuet
May 12, 2009 | Plumbing
Mixed Water Fill Causes Issues with Water Pressure
You will have to be specific about what problem the pump is having. It seems to pump ok for everything else. Could the hot solenoid be shorting and sending electricity down the water to bother the pump? Solenoids are not real expensive, try a new one.
Apr 25, 2009 | Kenmore 22422 Top Load Washer
Mixer tap makes a noise like a fog horn when cold water turned on
Usually happens when the stops and not ballanced(hot and cold pressures going to the faucet). Try ajusting the stops; open more on the hot or close more on the cold.
Feb 04, 2009 | American Standard Plumbing
Miele G 7856 Commercial Dishwasher
Hi. The above machine stops mid cycle and drain/fill light is on, also error code F3E, have cleaned both hot and cold water inlet filters, also checked drain pump and drain line, all ok. Machine drains with no issues and fills with hot water, runs for a while then shuts down.
Any ideas?
Aug 20, 2008 | Miele 24 in. G638 Plus Free-standing...
Ford galaxy over heating
need more info if it overheats in urban driving but not on hiway prb is in cooling fan electric or viscous?
Nov 24, 2007 | Baby Gear
Washing Machines Logo
3,057 people viewed this question
Top Washing Machines Experts
