Question about Saeco Coffee Makers & Espresso Machines
Saeco Vienna deluxe is slow functioning post power on. 3 to 5 min. for the middle green light remain on. Press brew switch takes a 2-3 min. for the pump 2 activate. Once activated, coffee flows fine.
    Scholar:
  • 78 Answers
Machine is screaming for descaling. The Calcium deposits in the system are slowing down heating.
Do not think of using Vinegar.
Do not use R.O water or consider water is very soft in your area. There is nothing like that.
Posted on Dec 30, 2016
SOURCE: Saeco Vienna Deluxe
http://cerinicoffee.com/Saeco_User_manuals_free.asp
Posted on Jul 01, 2008
EsWorld
  • 1618 Answers
SOURCE: Our Saeco Vienna deluxe had a couple of problems:
What does the coffee produced taste like, is it bitter and watery, is there any creama on the espresso shot. Try adjusting the grind and the coffee level, maybe a little coarser.
Posted on Mar 26, 2009
EsWorld
  • 1618 Answers
SOURCE: Saeco Vienna Deluxe leaking problem and grinder problem
I would repair it, it sounds like the grinder needs to be adjusted (burrs may be dull), and the leak on the bottom may be coming from the small drain hole on the back of the brew chamber. If you remo;ve the chamber you will see the white water valve that the chamber connect to, if you look below the white valve the small chamber in there will be filled with water, below that there is a small discharge use a stit stick or paper clip to clear hole.
Posted on May 12, 2009
EsWorld
  • 1618 Answers
SOURCE: Stuck on ventilate
Try this, open steam wand, if it calls for ventilate pusi in steam knob, if that works then the tap rod on the steam valve needs to be replaced. To me it sounds like the machine is building up pressure and the discharge is not releasing through the water circuit.
Posted on May 15, 2009
  • 1089 Answers
SOURCE: Saeco Vienna Deluxe starts brew cycle then red light comes on
Hi
I think you put the tubes on backwards to the flow meter. The inlet side of the flow meter is by the pump and the exit to the pump is by the water tank. They cross.
Posted on Jun 29, 2009
Is my Coffee Machine dead?
Hi, you should check first the safety contacts (door open detection, brew group inserted detection) that will prevent your machine doing its initialization properly.
If all contacts are OK (check with a multimeter), it might be the electronics board has a failure. If the lights goes on, the power supply seems ok. Try ti figure-out which section is faulty.
Do you have any alarm light on ?
Hope that helps.
Aug 19, 2014 | Saeco Vienna Deluxe Automatic Coffee Maker...
Saeco vienna delux (analog)
meens its not getting right amount of power change the power suply in take to a local lite shop they could show u how if u dont know how ok thx nick
Feb 04, 2008 | Saeco Vienna Espresso Machine
Saeco Vienna grinds too much coffee.
Hi
If you have the Delux or Digital there are 2 knobs in the bean hopper. Turn the small knob back 1 mark and see if that will help.
Jul 12, 2009 | Saeco Vienna De Luxe Espresso Machine
May 07, 2009 | Saeco Vienna De Luxe Espresso Machine
Grind settings
The factory setting should be 8. The higher numbers are finer. The + and - knob is the doser amount, the amount of coffee in a shot dose. Average is 7 gm, the middle. The highest is 14, I think. Generally, the highest dose shouldn't be used consistently because it can cause stress on the brew group. Just brew two shots.
Apr 17, 2009 | Saeco Vienna De Luxe Espresso Machine
Low water pressure
i had the same problem the brew unit was block from many shot remove the little tube on top of brew unit be carefull after removing the 2 screw there a spring under the tube and glass ball clean it good
Apr 09, 2009 | Saeco Vienna Deluxe
Saeco Vienna delux
The brew group is out of place.
--> --> The brew group cannot be taken out.
--> --> Turn on the machine and close the service door. The brew group will automatically go back into place.
The brew group is out of place -Turn on the machine and close the service door. The brew group will automatically go back into place.
May 07, 2008 | Saeco Vienna Deluxe
Saeco Vienna Deluxe odd burning smell
gears are probably broke. Happens when to much coffee and coffee ground too fine get compacted into the brew drive unit.
Shreds the plastic gears like butter.
Machine has to be sent out for service, gear replacement is long and impossible for anyone untrained. Trained techs it takes at least an hour if not more.
Apr 21, 2008 | Saeco Vienna De Luxe Espresso Machine
Coffee Makers & Espresso Machines Logo
37 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
espressofixr
Level 1 Expert
83bj60
Level 1 Expert
Shehu Pro
Shehu Pro
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
