I'm getting 3 codes now and then 617, 66, 17 it shuts down unit. I clear the code it starts. Is there anything I need to get done to refer?
  • kakima Dec 26, 2016
    Hi Charanji Lal, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
    What make and model?
5 Suggested Answers
  • 86 Answers
SOURCE: i keep getting error codes
i know what the problem is phone 07764303923 for the cure
Posted on Feb 14, 2008
  • 168 Answers
SOURCE: Canon NP 6230 copier - what does error code e244 refer to?
you have a scanner or lens problem look in the glass when you turn it on both the scanner and the lens should move some
Posted on Jan 13, 2009
hamzaskilltd
  • 316 Answers
SOURCE: how to clear code E000001.0004 had paper jam then
fixing assemble overheating
Posted on Jun 20, 2010
i al ready reset the error code . changed the tharmistar and also restled web rular but same eroor code problems e000001-001 and e000001-0010 model 5070 please solove the problem
Posted on May 06, 2012
What mean code p2006
this refers to the inlet manifold runner control stuck, you could try having the code cleared as this can be a momentary occourence , if code recours i'd run a tank of fuel with an addative in to clean out any carbon etc built up as if car has done a lot of stop start journeys the manifold flaps get coated with fuel that can become sticky and keep the flaps stuck shut so an addative should clean this and other deposits away , if this doesnt work , i'd try 2 full taks with addative first,then a new manifold will be neede as no repair is available as is made from blown plastic compound
May 18, 2014 | 2005 Ford F-150 Regular
Service engine soon light is on
can you please explain the problem in detail sir?
it will help us serve you better
Jul 31, 2008 | 1991 BMW 3 Series
Can not clear a 303 code HELP!!!!
After you make a repair you need to clear the computer codes. Try taking the pos cable off the battery for 5 or 10 minutes, then put it back on, DO NOT let the pos. cable touch anything on the car, wrap a thick rag around it.
Dec 31, 2012 | 2001 Chevrolet Astro
I have a daewoo cielo 1996 model. My car is giving out black smoke from the exhaust and it smells like rich mixture.(more of petrol less of air) The onboard diagnostic shows code 13 and 44. where could the...
Make the FixYa experience better for everyone by voting.
The Code 13 refers to the camshaft position sensor and should be fixed ASAP since it can cause the engine to shut down without warning, You can replace the unit in under thirty minutes. Plan on paying about $50 for the part on eBay or Amazon.
The replacement should clear up the P0044 HO2S Heater Control Circuit High (Bank 1 Sensor 3) reading.
All the best,
Ben
Oct 01, 2011 | 1999 Daewoo Lanos
Working on a N1321-ASME unit installed in a Taco Bell. Getting error code 21. Unit gas pressure is at 8.5wc and manifold pressure spikes to 2 when it come on but unable to see what it remains at because...
I recently had a similar problem with my N-132M-ASME heater. The unit would come on, then shut down and flash Error Code 21. According to the owners manual, that code indicates the unit is not getting enough air. I tried vacuuming the unit, blowing it our with air and checking to be sure the exhaust lines were clear. Nothing helped. A service technician came out and recommended I descale the unit and clean the burner. I did this but the problem did not go away. He also suggested I replace the Burner Sensor. It's not an expensive part, around $20. I ordered the part and have not had a problem since I installed it. Hope this helps.
Jul 09, 2011 | Noritz Commerical Tankless Water Heater...
TV turns off and standby light blinks. Blinks 3 times, pauses, blinks again 3 times.
Three blinks means technically 'B+ over voltage protection (OVP), unit goes to the standby mode then displays the 3 blink fault. This is also a problem in the power supply circuit, check T603 and R672.'
After a little more research i found this comment:
"Guys I have found the problem. (referring to T603 and R672) I have found mine anyway. When I replaced my projection lamp, I failed to push the lever all the way down, but this was not the problem, just something you need to be sure to check. The problem was the lamp door. This needs to be shut properly. I found another thread where a guy had tried the same thing. It worked. The door clicks hard at the end to set itself. This worked for me. Hope it helps you."
IMPORTANT: After you repair the unit, you MUST clear the values on this diagnostic screen. These codes do not reset themselves after the fault is corrected, so if you don't clear them, you'll be seeing "old" fault codes the next time you enter this screen. Clearing is done by going into the service mode (display, channel, 5, volume plus, then power ). Press 8 and Enter, which returns everything to the factory preset condition.
So my question is have you replaced the lamp?
Hope this helps
TV_Doctors
Jan 05, 2011 | Sony KDF-E50A10 TV
2000 vw cabrio runs normal and shuts down, takes 5 to 20 minutes to restart, engine cranks but doesnt start, changed ignition coil, pulled diagnostic codes getting short to ground codes on cylinder...
On some models, the Engine Control unit has a power supply relay. These relays some times get internal dry solder points. After driving for some time the the solder will get hot and separate. When it cools down it makes contact again. You will have to replace this relay or open it up and re- solder the solder joints. The relay is usually located on the main relay station in position 3. the relay station is located behind the right dash panel.[right hand drive vehicles]. You may need to refer to a manual for your specific model to find the exact location of the relay.
Jun 04, 2010 | 2000 Volkswagen Cabrio
System error E000 how do I fix it. I tried what it said in the instructions to turn it off for a while then turn it back on that didn't help. Canon NP6025 copy machine.
To delay the 3 second shut down and enable the technician to access service mode; open the front door and pull out the transport unit. Do not actuate front door microswitch. Press the service mode button, enter " * 4 * ", scroll to error clear and clear error code. Machine will automatically turn off power after clear. Power up machine and test.
If the power shuts down after error code has been cleared, the cause of the error has not been corrected. Correct cause of error code and clear error in service mode.
May 07, 2009 | Canon Office Equipment & Supplies
Xerox XC 1020 copier code H4
With "H4" flashing press:
1.Clear button
2.Auto button then again
3.Clear button
4.Auto button
It should be done quickly. If it's done quickly enough all lights on display should go off.
5.Enter number 14 (as if you are making 14 copies).
6. Press START/COPY button.
The machine goes back to normal. If not, thermistor on the fuser (heater) should be replaced.
Sep 02, 2008 | Office Equipment & Supplies
Konica 7020 copier
what happens when u run L-detect. Make sure the sensor near the drum sep claws in the drum unit is clean. Any toner or setting powder on this semsor will give u errors while running L-detect.
Dec 10, 2007 | Konica Minolta DiALTA Di200 Copier
26 people viewed this question
k24674
jasbo
jasbo
