My Midea MB70 toploader washing machine is not spinning or draining I have dropped a small metal object into it some months ago, wondering if this could be the problem?
  • 641 Answers
SOURCE: Itis a 'no spin".
It sound like you have a blocked pump. Remove the pump from the machine and check where do you have this clogged, inside the pump or in one of the pipes connected to it. Good luck!
Posted on Sep 04, 2007
  • 641 Answers
SOURCE: Itis a 'no spin".It washes, drains, then it rinses, bypass spin to off.
  • 14 Answers
SOURCE: Hotpoint WMA42 - Noise!!
appliance sounds like it has bearing failure.common on this machine.advise looking for a new machine.sorry
Posted on Dec 30, 2007
  • 86 Answers
SOURCE: tricity bendix BIW103W spins badly, clothes still too wet.
Hi, Your problem is very common and very easy to fix. You will first need to strip the machine down and remove the motor. Once you have done this then take off the motor carbon brushes, These are the little things in cases on the side of the motor casing. These should be at least 1" long! you will find that this is not the case and they will need replacing to resolve your problem. The parts should not cost anymore than around £20 for the pair.
Good luck any problems get beck to me............................
Posted on Mar 18, 2009
jsrock516
  • 5911 Answers
SOURCE: how to install lid switch
The symptom of a washer that fills normally, but stops suddenly and will not drain is commonly caused by a lid switch malfunction.
The following link explains how to install a lid switch:
http://www.fixya.com/support/r385198-replacing_lid_switch
If this is just a matter of reinstalling a switch that has come loose, a new switch may not be required. Inspect to ensure the mounting screws, switch casing, or switch lever are not broken. Make sure the mounting screws are tight. NOTE: You do not have to drain the washer to replace the lid switch. With the switch replaced, the washer will drain on its own. This will save anyone the trouble of having to bail. If you have questions, please let me know. I hope this helps.
Posted on Apr 27, 2009
Spindryer is draining but not spinning, can you help? It is a Midea MB70
Check drive belt that drives the drum via motor & pulley.
Nov 20, 2017 | Washing Machines
Midea washing machine not spin/draining
The drain may have been clogged with something else.
Nov 25, 2013 | Washing Machines
I have a 5 year old Midea aw60-982 washing
Sounds like a bad belt or a locked up pump.
Sep 16, 2013 | Washing Machines
Have a proforma toploader and is making a grinding noise in both wash and spin cycle. it is still draining and doing everything just making the noise.
We have a proforma toploader washing machine and when using the machine in makes a very loud grinding noise during the spin and wash cycle. On occassion it also does not spin the clothing out properly, however the machine is still usable.
Dec 29, 2010 | Maytag Performa PAV3200
The washer did not drain and won't forward to rinse. After removing all the wet clothes and scooping out the water I set it at rinse and it began to fill but I wasn't able to forward it to spin though it...
Check the lid switch first. It will not drain or spin if the switch is not closed. If the switch is ok check the pump for a foreign object or frozen bearing. If dropping the hose allows water to siphon out the blockage may be a small object.
Eric
Jul 17, 2010 | Whirlpool Ultimate Care II LSQ9564J Top...
Small stuff has gotten between drum and ? Makes clickadee clack noise while cycle washes/spins. How do I get access to area beneath drum ?
Drain the machine off by dropping the drain hose into a bucket
Take off the back panel check where the big hose leaves the drum to go to the pump
Lay the machine forward so that the gravity will send any objects towards that area
Take off the hose and retrieve the objects, possible bra wire which may require that you turn the large pulley on the back of the machine to bring it into view
Jan 03, 2010 | Whirlpool WFW8300SW
Admiral Washer AAV7000AWW everything works -goes through cyclebut will not drain
You,ve done a good job the first time the pump fail MikieM. You can do it again. We sometimes forget to empty our pocket. Some small metal things could have gotten into the pump...could be other hard foreign object. Good luck.
Dec 21, 2007 | Admiral AW22 Top Load Washer
Itis a 'no spin".
Oct 18, 2006 | Magic Chef CAV2000 Top Load Washer
Washing Machines Logo
46 people viewed this question
Top Washing Machines Experts
