Vess l98 starting it will wind to the end of its cycle and start some times help
2 Suggested Answers
lpfaff1
  • 11573 Answers
SOURCE: My maytag performa washing machine makes a winding motor noise when starting it starts spin cycle. Also has louder than normal noise while spinning and when cycle ends,
Sandra, washer may have a broken or faulty balancing spring. Have a good tech. diagnose and estimate repair. "I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Posted on Aug 11, 2016
Aug 11, 2016 | Maytag Washing Machines
No fast spin at end of cycle
You may have burned up the motor's starter windings. About the time it eases up to speed, the motor overheats, and shuts off. Five or so minutes later, the overheat switch resets and it attempts to start the spin cycle over.
Jun 02, 2015 | Washing Machines
How do I get the bobbin thread to wind?
Are you holding onto the end of the thread while it starts to wind? You must provide tension on the starting thread by inserting the end of. The thread up through a hole in the bobbin and hold onto the end to start the winding.
Oct 11, 2014 | Brother CS-80
When moving off from start up winding clunk from front end only lasts a couple of seconds.
RAISE THE FRONT END OF THE MOTOR CYCLE JUST OF THE GROUND AND SEE IF THE WHEEL IS FREE TURNING IF IT FELLS TIGHT IT COULD BE A BEARING PROBLEM OR A BINDING BRAKE.SAFE RIDDING
Oct 18, 2013 | 2000 BMW R 1100 RT (ABS)
My Defy Automaid DAW285 only works when you put in a small load of washing
It seems that the "start" winding of the motor is defective or the capacitor is defective
Peet
Nov 15, 2011 | Washing Machines
When starting a cycle, tub will fill properly, then when it is time for the wash cycle to begin, nothing happens. you can only hear a relay or other type switch click one time. after the one click, the...
The question is why the main motor is not running. Either there is an open contact in the timer, or the motor has a blown thermal protector or tripped internal breaker.
Troubleshooting starts at the timer. Most washing machines have a wiring diagram on a sheet of paper either folded up and stored inside the control panel or pasted on the back panel of the machine. Find the wires going from the timer to the motor. The motor has two windings, RUN and START. The RUN winding has one connection to neutral (WHT or WHT/BLK, meaning white or white with a black stripe) and the other to the timer. The START winding has both connections going to the timer. The timer connects it power one way for agitate and the other way for spin. (The direction of current through the START winding determines whether the motor will turn clockwise or counterclockwise.)
If you are comfortable working in a live 120 VAC circuit with a voltmeter, use the wire colors in the diagram to identify the motor terminals on the timer, set the timer to the agitate position (i. e., right after the machine is done filling and you hear the click), then check for voltage on the RUN and the START winding terminals. For the START winding, measure between the terminals going to the START.
If you don't want to probe a live circuit, you can use an ohmmeter to test for continuity between the hot terminal of the power cord and the motor terminals on the timer. Repeat for the neutral terminal. A failure at this point indicates either a timer problem or (unlikely since the timer runs) a bad contact on the water level switch.
If you get voltage to the motor on both windings, or you have continuity through the timer for both windings, then, with the machine unplugged, test for continuity through each motor winding at the timer. An open indicates a problem with the motor. Note: most machines use a capacitor in series with the START winding. In that case, measure continuity between the capacitor terminal going to the motor and the timer terminal going directly to the motor.
Apr 17, 2011 | Washing Machines
My pull start cord won't retract. How do I fix it
Remove the starter assembly from the engine and pull the cord out--it should have spring resistance to pulling. If nothing, the rewind spring may be broken, or it may have pulled loose from one of the attachment points. Remove the cord from the pull handle and unwind it from the spool if it isn't already pulled out. Remove the spool from the frame to expose the spring--check the ends for breakage and the attachment points for damage (one will be on the under side of the spool). Repair or replace any damaged components and assemble the spring into the attachments. Wind the spool/spring about 2-turns CW, then wedge it to prevent unwinding. Fit the cord back into the spool and wind it CW until the cord has about 8" or so to feed out through the cord port. Fit the cord end back into the handle, tie an overhand knot, and push the knot into the handle bore. Remove the spool wedge and try pulling the cord several times to make sure it goes out and back smoothly. Return the starter to the engine and attempt starting. Hope this helps!
Nov 08, 2010 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
AEG Lavamat 16820: Strange noise coming the machine
Ok, the motor windings are bad. the A.C. hum is a warning that the motor will sound when the windings are separated or shorting. its unable to hold a balanced current.the motor will actually stop soon if it isn't repaired.
Feb 15, 2009 | AEG Lavamat 16810 Front Load Washer/Dryer
Kenmore gas dryer buzzes but does not run
sounds like the start windings in the motor have gone bad. The only way to fix this is to replace the motor.
Feb 04, 2009 | Kenmore 73932 Gas Dryer
Washing Machines Logo
21 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
