X1 DVI, plugged into HDMI
Xfinity x1 sensing DVI when plugged into HDMI
2 Suggested Answers
dnsnakdndjws
  • 708 Answers
SOURCE: HDMI&DVI ports already used on LG HDTV.I have X BOX 360 S,has a HDMI plug, can I use a HDMI splitter to plug in the X BOX in the DVI port ?receiving computer via HDMI now
Hdmi splitter could connect it ,more details:https://www.amazon.com/MALLCROWN-Splitter-adapter-Converter-Switcher/dp/B01I4WJV5U/ref=sr_1_1?ie=UTF8&qid=1479625360&sr=8-1&keywords=mallcrown+hdmi+splitter
Posted on Nov 20, 2016
Can I program a GE 24116-V2 universal remote control to operate a Xfinity X1 Cable box ?
This remote control have no setup codes to Xfinity. If you wish to get more details visit the site linked here. http://electrohelponline.blogspot.com/ http://remotesearch.blogspot.com/ http://homenol.blogspot.com/ Setup procedure and set up codes for many popular brand remote controls are given.
Feb 08, 2017 | GE Televison & Video
You will not be able to split them, but they do make a HDMI Switcher, allowing you to use your Xbox 360 as number one and your PC as number 2, w you cannot mix both at the same time.
May 02, 2016 | LG Televison & Video
How do I get my HDMI ports to read 1080i instead of DVI?
The question really doesn't make sense. That's because 1080i is a signal resolution, and DVI is the connection cable that carries the signal. The two things are connected, but different.
It sounds as if your TV is searching for a signal; looking first at the HDMI input, and then the DVI input, before giving up because it found no signal.
Your next question should add some detail about the makes and models of the equipment involved and how you have them connected.
Sep 04, 2014 | Televison & Video
Im zoomed in on the xfinity guide! i have the xr2 remote and the x1 cablebox
XR2 doesn't have the ability to zoom in / check your TELEVISION remote. ( one that came orig with tv ) and see if it can be adjusted there. if that fails physically unplug your television to see if the setting will reset to default. if that fails try a different hdmi input. GOOD LUCK!
Oct 11, 2013 | Comcast XFINITY
Hi, I have bought LG LCD ld310 . Can I connect my computer output to lcd tv through dvi-hdmi cable or vga-hdmi cable Thanks Jatinder Kumar
Hi Jatinder Kumar ,
Yes you can connect your computer output to lcd tv through dvi-hdmi cable or vga-hdmi cable.
1. Connect to HDMI (DVI) : just plug in HDMI (DVI) out of PC or laptop to HDMI or DVI TV. Than select source from HDMI.
2. Connect to PC : Plug D sub to TV, select PC in.
I hope that will help you.
thanks.
Mar 21, 2011 | LG Televison & Video
I have my PS3 hooked to the HDMI port, but the monitor won't switch inputs to the HDMI port. If I have something plugged into the dvi port it works fine, but I currently need only the HDMI port, and do...
There are a varity of HDMI cables, ensure that your version is supported also using the input touch "button" to change the input through VGA, DVI and HDMI.
damnor01
Nov 22, 2010 | Acer H233H bmid Monitor
My monitor says cable not connected
If it like my monitor, same hookups as yours, then when you want to use the hdmi port you need to disconnect the dvi cable. The monitor cannot read from hdmi & dvi when both are connected, Try this & see if your PS3 works. Good luck
Jul 03, 2009 | Hannspree 22" widescreen LCD Flat Panel HD...
Macbook Pro DVI---> HDMI + Digital Optical Out = Problem w/ Sound
On the Sony The HDMI takes "priority" over all others, that's why you loose audio. If you run your DVI/HDMI to the TV and optical to the soundbar that would fix your issue. If your TV does not have Multiple HDMI inputs, you can get a DVI/Component adapter for your MBP then run it to the TV, or, If you have to have HDMI just to have HDMI, you can get a 2:1 HDMI switch and still have optical to your soundbar. Make sense? If youneed more help, just post a comment and I'll help some more.
Jun 23, 2009 | Sony HT-CT100 Theater System
Philips 32' lcd hdtv
are you using a DVI to HDMI converter? Radeon cards older than x1*** series or roundabout didnt support hdcp on dvi which is required to run Hi-Def rez thru an HDMI cable on most TVs. A video card with hdmi prebuilt in or HDCP compliance listed on the box should be able to handle it. And you should find a resolution both your normal monitor and HDTV can handle to set the coimputer to before you switch it over to the HDTV to be sure it will still show you picture. If you arent using 1080P you might as well use a component input which doesnt require HDCP.
Oct 12, 2006 | Philips 32PF9966 32 in. HD-Ready LCD...
Televison & Video Logo
23 people viewed this question
Top Televison & Video Experts
