Question about Charger-Desulfator - 12 Volt, AGM Batteries, Model 2013
I need help with my agm batteries - Charger-Desulfator - 12 Volt, AGM Batteries, Model 2013
    Problem Solver:
  • 19 Answers
What sort of help ??
Posted on Dec 28, 2016
a 6ya Mechanic can help you resolve that issue over the phone in a minute or two.
click here to Talk to a Mechanic (only for users in the US for now) and get all the help you need.
VETERANS HOME JUST GAVE ME A USED QUANTUM WHEELCHAIR AND PRIDE MOBILITY CHARGER. HAS AGM BATTERIES. CHARGER MODEL EA11488 SAY LEAD ACID BATTERIES ONLY ????
AGM batteries( absorbant glass mat ) batteries have a different charge rate to ordinary lead acid batteries
it is all abiut the charging rate or charging volts so the charger you have may not be suitable for the AGM batteries in the chair
the difference in the lead acid battery and the AGM battery is the construction
Lead acid batteries will spill acid if tipped over where as a AGM the acid is absorbed in the glass mat or is an acid gel
to get a read of what it is all about go www.batteryuniversity.com and you will see what I am refering to
next best thing is to ring your local battery shop and ask then what charger you should be using for AGM batteries and if a normal lead acid battery is suitable for the job
Jan 24, 2017 | Pride Health & Beauty
What does the 12volt AGM button mean on 80amp battery charger by Schumacher
For charging AGM batteries.
AGM (Absorbed glass mat)[edit] AGM batteries differ from flooded lead acid batteries in that the electrolyte is held in the glass mats, as opposed to freely flooding the plates. Very thin glass fibers are woven into a mat to increase surface area enough to hold sufficient electrolyte on the cells for their lifetime.
What are the advantages and disadvantages of Gel, AGM, and Flooded / Wet Lead Acid Deep Cycle Batteries?
Generally, gel and AGM batteries have about 20% less capacity, cost about two times more, and have a shorter cycle life than comparable flooded lead acid batteries. However, Gel and AGM batteries do not need watering, are safer (no acid spilling out), can be placed in a variety of positions, have a slower self-discharge characteristic and are more efficient in charging and discharging than flooded batteries. Gel batteries are more suitable for deep cycling applications whereas AGM batteries are more for light cycling and some engine-starting applications.
Jan 01, 2016 | Jensen Schumacher Sc-600a Speedcharge High...
Can i replace the AGM batteries in my Bombardier class e, with deep cycle batteries?
A deep cycle battery for personal mobility equipment would be how to look into this. The AGM is a type of deep cycle battery. A gel battery is what was more common before AGM came along. Gel batteries tend to hold up a touch more than AGM.
Oct 12, 2014 | Health & Beauty
What size of Battery do I buy for a 2005 883 Sportster? Mine is 6 years old and DEAD DEAD ! I am a woman &* it looks pretty easy to change out just want to know what size I need to buy & Ain't...
Actually, if you're talking about Harley's AGM battery, it's a very high quality battery and is competitively priced compared to any other AGM Batteries. An AGM battery will last you about five years as long as you keep it charged. You can get a sealed lead acid battery cheaper. However, you really don't need to know the size of the battery. Just take it out of the bike and take it with you. If you're here in the U.S., you usually have to turn in a "core", part of the EPA thing. They'll just match size of your battery and which side the terminals are on and sell it to you.
Good Luck
Steve
Feb 19, 2011 | 2005 Harley Davidson XL 883C Sportster...
I need to replace my bateries. What is the difference between the MK AGM 12 volt brand and the UB AGM 12 volt?
The Mk battery is a maintenance free battery,they are sealed to keep from spilling water or leaking acid.And let me tell you right now if the chair is used inside that's the battery you want. Most major wheelchair/scooter manufactures have went away form the maintaince battery's because of accidents like acid spills .I would recommend the gel sealed maintaince free battery ,last long ,little more money ,but its worth it .
Hope I was of some help good luck to ya.
Jan 18, 2011 | Jet 3 Ultra Power Chair
Typ of battery
Mine has 2 12 volt 12 ah agm batteries model ub12120 if that helps>
Jul 12, 2010 | Pride Mobility Products Go Go Ultra X 3...
Details of batteries ie type of batterie and batterie rating and number of batteries reqired
All scooters (or at least 99% of scooters) will run on 24 volts, therefore there is usually two 12 volt batteries needed to run the scooter. Unless the scooter is very old, these will be in the form of dry batteries (sealed top with no water top up required) usually GEL, SLA or AGM. It Doesn't matter which type you use but GEL tend to last a bit longer and are more expensive. As to which size of battery you require, it should be marked on the battery somewhere in an Ah rating, for example 12v/31Ah. I would need to know which model of scooter you have to be able to help you with the size you require. You should also replace batteries in pairs, not as a single and should use the same rating and type, so dont put 31Ah batteries with 36Ah batteries and not an AGM with an SLA, GEL etc. Hope this helps...
Mar 11, 2010 | Health & Beauty
Battery
maintenance-free battery for my 1976 Benelli 750 SEI but the suppliers I've contacted have no record of what model battery it takes. All the shop manual says is a 12 Volt 14 Amp Hour battery. Anyone know of an equivalent battery of the right size that will fit say from a Honda CB750 or CB500 maybe? Thanks! ,What you need is an AGM 20 Amp Hour battery to fit a BMW Boxer or K series. EG Varta 50814 (standard european size battery, not japanese),,,
Nov 10, 2008 | 1974 Benelli 750 Sei
Charger-Desulfator - 12 Volt, AGM Batteries, Model 2013 Logo
Top BatteryMINDer Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a BatteryMINDer Vehicle Part and Accessory Expert? Answer questions, earn points and help others
