Where is the air mixing section on la germane f6 - as the bottom burner is not staying lit keeps blowing out
SOURCE: burner will not stay lit
Presuming the flame is touching the thermocouple, try putting slightly more pressure on the knob and hold for a few seconds longer. If this doesn't work try going through the same process with the knob removed - if this works you need to put a small piece of packing in the shaft of the knob ( a small piece paper might do). If this fails you need a new thermocouple.
Posted on Nov 18, 2007
jumptrout51
  • 3361 Answers
SOURCE: burners keep going out
Remove the burners and clean the inside of the burners with compressed air and or a small long bottle brush.
The burner holes have a rust scale buildup in them.
Posted on Mar 21, 2009
SOURCE: all 3 Burmers won't stay lit
I contacted the company. Phone number 800-694-0013. You can order replacement parts thru them but they cannot take credit cards by phone you have to mail in the payment and they will Fed-Ex the part when they receive it. The lady I spoke with was very nice and helpful, she stated these grills are made for Meijer's pretty much exclusively and they are made in China and that if you can locate their website it is all in Chinese. She also stated the distributor has opted not to sell the replacement parts for these in the store.
Posted on May 29, 2009
Maytag317
  • 1136 Answers
SOURCE: Whirlpool Range Stove Top Indicator Light Stays Lit
Hi, You will need to change the burner switch as well. It shorted out when the element went bad.
Please let me know if I can assist you with part # or anything else.
Vic
Posted on May 30, 2009
  • 3 Answers
SOURCE: outdoor patio heater won't stay lit
I have a Charmglow Patio Heater Model SRPH02, it needed a Thermocouple and searching the net was hard to find an ariginal part, but here it is, call 1-866-814-0585 $3.95 +6.00 shipping the original part.
Posted on Jun 17, 2011
I've a Swiss grill with rotisserie burner (infra-red) & it keeps blowing itself out, it stays lit for 5mins then suddenly flames pop out & it goes out, it still sounds as if gas is coming out though.
Almost certainly yes. The infrared grills work by gas and air coming through the surface under pressure. The crack would cause lower pressure and flameout. Does it flame at this area?
Beyond the nozzle (towards the burner) that you cleared is an area called the venturi, this is where the gas is mixed with air before it hits the burner. check that for blockages.
Jul 21, 2016 | Grilling
I HAVE AN INTERTHERM MODEL MG-055AB TURNS ON BUT TURNS OF IN A 4OR 5 SECONDS ANY SUGGESTIONS
light pilot then turn blower on by thermostat. if it blows it out bad heat exchanger. if it stays lit shut down & pull burner assembly clean pilot orifice.
Feb 16, 2015 | Intertherm Heating & Cooling
Rfn30ta gas heater dont stay lid
The most common problem with these types of heaters is dust build up in the pilot. If your pilot light is mostly a yellow flame you need to blow out the pilot of dust.
Turn off the unit. Remove the cover to expose the pilot. You should find two small holes about an inch or two below the tip of the pilot. Those holes are for mixing oxygen into the gas prior to it lighting. Blow those out with a can of compressed air and you may as well blow out the large burner also with the can of air. Wipe down everything with a damp cloth to remove additional dust.
Sometimes the pilot will light and stay lit, but when the burners turn on the flame moves slightly and pulls the flame away from the thermocouple. Either way this is a good idea to do every year or two on your heater.
Nov 11, 2013 | Heating & Cooling
I changed my thermocouple on my fireplace,it still wont stay lit
Thermocouple keeps the pilot lit.
Thermopile keeps the burner lit.
Please specify what won't stay lit...
If it's the burner, you may need to change the thermopile as well.
If the pilot still won't stay lit, you will want to make sure that the pilot flame is large enough to completely engulf the thermocouple and keep it hot. If it's too small, you may need to take some compressed air and blow out the pilot hood to remove any blockage.
Dec 18, 2012 | Napoleon 36" Zero Clearance Top/Rear Vent...
Kenmore 795 continually blowing cold air into frig
If the control will not change and the lock is lit, first try unlocking it. Press and hold the lock tab for 3 seconds. If nothing happens, try unplugging the power cord for 30 seconds and reconnect it. This will reset the board.
Nov 02, 2012 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Pilot light and burning will not stay lit. Basement flooded and after all water was gone tried to lite the burner. Could not keep it lit. Called a service tech and they came out and cleaned the burner...
Manufacturers say to replace water heater after a flood.
Flooded water heater can be repaired by replacing parts but warranty is voided.
And if water heater reached gas control valve, then gas control has to be replaced >> possibly the gas valve eco tripped.
I don't know how effective cleaning burner parts will be, since a small spider wed inside some of those tubes can cause water heater not to function. Small obstructions cause big problems.
I'm sure the plumber cleaned it out real well.
Find manufacturer using label on side of tank, find manual with parts diagram, and order burner parts.
http://waterheatertimer.org/Water-heater-manufacturers.html
It might be cheaper to install a new water heater yourself from box store
http://waterheatertimer.org/How-to-install-gas-water-heater.html
I read one article:
http://www.diychatroom.com/f7/rheem-hot-water-heater-pilot-burner-not-staying-lit-65755/
Guy has water heater that filled with water.
He says: "I decided to feel around. As soon as I put my finger into the hole under the burners I hit water. The air intake passage was filled with rain water, effectively chocking off the fresh air. A few minutes with a siphon tube cured the problem and the water heater works normally again."
Absolutely feel obligated to upvote the help.
Or take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
May 06, 2011 | Rheem 40 Gallon FVR NATGAS Low WATER...
I have bosch pgl985uc burner problem. The center burner will not stay lit.
I have the same problem especially with the center burner, but now am having increasing difficulty with two other burners. Those will eventually stay lit if I depress the knob for 20 - 30 seconds. The center burner will not stay lit, even when keeping the knob depressed for 2 - 3 minutes!
Mar 19, 2011 | Bosch PGL985UC 36 in. Gas Cooktop
La Germania oven won't stay lit. Stove is 10 years old and problem just started. It will light, but goes off after a few seconds.
Use a good air gun to blow off dirt inthe regulator. dirt in the nozzle and the burners.
Use a good brush to assist, or a thin metal wire to push through the gas passage .The air mixing section must be fitting correctly wedged.
Sep 11, 2010 | Ovens
Blower Motor cycles on & off
whats happening is thje heat exchanger is cooling off and cycling the fan off this is a normal occurance whenever the unit is first turned on.
Dec 22, 2008 | Heating & Cooling
Blower won't stay lit
If the fan motor is blowing out the burner then is there a hole in the heat exchanger
Jul 18, 2017 | Honeywell Power Humidifier: Furnace...
Heating & Cooling Logo
24 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
