Question about Amana ARS2661BS Side by Side Refrigerator
On an Amana ARS2661BS Unit does not cool on either side
  • Amana Master
  • 4,655 Answers
Pull it away from the wall and remove the cover the covers the compressor. Unplug and tell me if the compressor is too hot to touch or if running or any signs of life. If not running and cool I want plug it back in, and open the fresh food door and and look for a hole in the control panel where you adjust temperatures. The opening is about the size of a pencil eraser. Sometimes this hole is covered by a plastic plug. Stick a small flathead screwdriver slowly clockwise until the compressor restarts. If this works the refrigerator needs a new defrost timer. Sometimes the defrost timer will stick in defrost and stop. Let me know, Thanks Sea Breeze
Posted on Jul 21, 2009
Amana side by side not cooling
What is the complete model number of your unit?
Dec 04, 2012 | Amana Refrigerators
My Black Amana sxs Model SCD25JPW Fridge isn't cooling. Both sides are hot
OK, lets try a couple of things before you run out and buy a new unit. On that unit I believe the defrost thermostat is on the front bottom of the unit. Turn the little dial til it clicks and tell me if the unit kicks on.
Nov 30, 2012 | Amana ABB1921DE Bottom Freezer...
Amana refrigerator ars2365aw refrigerator/freezer works perfectly for a day or two then stops cooling. Compressor and fans are still running. I will unplug it for a days, plug it back in then it will work...
if your freezers back wall has a layer of frost build up on it,that means the defrost heater or thermostat that controls this heater is bad,if theres an ice buildup on the evaporator coils it cant blow cold air into the unityou need to find out whats bad as it can no longer defrost,when you shut it off for a day you are defrosting the unit,then the frost and ice again cover the coil when you plug it back in
May 12, 2011 | Amana ARS2661BS Side by Side Refrigerator
I have an Amana side by side. Freezer and refrigerator gets warm. Took back panel off and coils are frozen. melted the ice off and works great for about 2 weeks and then does the same thing. What can I...
Probably your defrost timer or the defrost element. If you take the leads off of the element and test it with an ohmmeter you'll be able to determine if it's blown.
Mar 27, 2011 | Amana ARS2661BS Side by Side Refrigerator
Freezer won't go below 32 degrees
Need condenser fan for unit to cool properly
Apr 27, 2010 | Amana SXD524VW Side by Side Refrigerator
The Amana refigerator I have stopped cooling. There is power to the unit, the lights work but the unit is not cooling. The unit clicks every few minutes.
Start capacitor,start relay, overload and windings in compressor need checked. When clicking like that the compressor is overheating and could damage the internal overload. Send model number so I may tell you the correct parts. I will be here if you need, Sea Breeze
Jan 20, 2010 | Amana 22.6 cu. ft. Side-By-Side...
Amana Cooling Condensing Unit fan stops spinning after 15 mins
Capacitor, dirty condencer coil causing the motor amps to run too high. But most likely worn bearing on blade side of motor causing it to pull to one side causing it to over heat and shut down. Sleve bearings should have no side play.
Jun 28, 2009 | Amana PTH123B25AJ Heat Pump Air...
Amana side by side refrigerator/freezer Mod.No.SZD27NW
if he added gas then you had a leak and was low on freon it can take 24 hrs to reach temperature and it would be running that whole time to do so
Aug 13, 2017 | Refrigerators
Bottom vegetable/fruit drawer freezing fruit
to the left of the bottom drawer is a veg/meat slide switch.make sure it is all the way on veg.if it is on meat,it opens a small doorway to the freezer and lets the cold air in and will freeze the food in the bottom drawer.in some cases,you will need to remove the drawer and shelf and then take apart the doorway.ball up some putty and jam it it the hole to completely seal it off
Jan 11, 2008 | Amana ARS2661BS Side by Side Refrigerator
Amana ARS2661BS Side by Side Refrigerator Logo
178 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
