Question about Vacuums
How do I adjust the height of the floor brusht for a wood floor.
  • kakima Dec 26, 2016
    Hi Dorothy Fabian, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
    What make and model vacuum?
How to fix wheels that raise and lower the beater bar
Hello! The M085845 has an automatic height adjustment that cannot be manually changed. There is a roller lifter assembly that helps to raise and lower the nozzle depending on whether the vacuum is in the upright or reclined position. You do not have to make any adjustments to the vacuum when going from carpet to hard floors. The brushes will continue to spin at all times when the vacuum is in use. Hope this helps!
Jun 26, 2014 | Dirt Devil Featherlite Bagless Vacuum...
Plainer won't adjust up and down
Wood chips are probably jamming the height adjustment, and need to be cleaned out. Lubricate the machine once it's clean.
Feb 01, 2014 | Dewalt DW735 13-Inch Two Speed Thickness...
My 1 Year Old Sebo X4 was lowering itself to hardwood floor with no air gap. Sebo Support agreed with my repair shop that a new (blue) brush roller would fix the problem by replacing the 'worn" brush (same...
No not quite. For a start, the stiff bristles on the blue roller can last a few years before requiring to be replaced.
The SEBO sensor wheel adjusts to the height required - unless of course the microchip board has been tampered with. If it hasn't been tampered with. If the central wheel is excessively dirty then it could be that the SEBO isn't lowering the height properly. However, the X series is great at cleaning hard floors in general - i it is not designed for the brush roll to fully hit the floor, thus as you suggest crushing the bristles. It is designed, as you recognise quite correctly to skid across a hard floor lightly as there is a squeegee rubber strip built in at the back of the roller bar that scoops all dirt into the central vacuum path. The front plate also lends this job. You are not being conned - however check that the rubber squeegee strip has not worn away - SEBO do sell the strips and they are easy to slide into via the press release door at the side of the brush roll.
If the SEBO has died then its a possibility that there is a microchip function that gone wrong it. Some more information would be good to know here as it could be a number of things such as the cord cables coming away at the handle.
Oct 30, 2013 | Vacuums
Height adjustment plate carpet
There is not a height adjustment plate on the vacuum. There is a bottom plate which is the part that glides across the floor. It has three plastic screws which you turn with a large screwdrive or a coin to remove the bottom plate.
Sep 17, 2013 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Is there a height adjustment for bare floor to thick carpeting?
The XL21 has a 2 speed switch use the lower speed on bare floors.The XL21 does not have an adjustment mechanism.
Jan 28, 2011 | Oreck XL21 Bagged Upright Vacuum
I have a Sharp vacuum EC-12TXT4 upright and I want to adjust the height for various carpets, how is this done? I have lost my owners manual and cannot find such manual on the internet. Could you please...
This model claims to have automatic adjustment. It has two foot pedals at the bottom which gauges the height of the carpet/floor. There's no other way to adjust the height.
Sep 04, 2010 | Sharp Twin Energy EC-12TWT4 Bagged Upright...
How do i adjust the brush height on my dyson dc15 ball
The brushbar pivots, you can't manually set the height of it. It moves along with the contour of the carpet or floor that you are vacuuming.
Jun 26, 2009 | Dyson DC15 All Floors - The Ball Bagless...
Sebo Automatic X1 vacuum 'check brush' light on
I work in a Sebo agency, where we sell and repair Sebos - although they're so reliable we don't get that many to repair.  What's "automatic" about this machine is that it automatically adjusts the brush height so that it's ideal for whatever floor it's on.  It does that by sensing the amount of drag on the brush.  On a wood floor, there's much less drag than on a carpet, so the machine lowers the brush as far as possible to get the optimum drag.  After a while (4 1/2 years in your case) the brush has worn so far that the machine can no longer get it down low enough to brush the floor effectively. That's why the light comes on.  There's still plenty of bristle to do a good job on carpet but, if you want to do the best job on your wood floors too, you need a new brush roller.  Change the brush roller, and you'll probably feel the suction's improved too!
Any questions, just post a comment and I'll help if I can.  I value your feedback so please remember to rate this response.
May 04, 2009 | Sebo Automatic X1 Bagged Upright Vacuum
Wind tunnel not picking up when set on hard setting
Have you tried setting the height to the lowest setting? It should be there for hard floors.
Aug 18, 2008 | Hoover U6437-900 / U6439-900 Windtunnel...
Vacuums Logo
22 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
