Question about Viper Vehicle Parts & Accessories
My viper 4105 starts the engine but the starter wont drop out and no output for the white parking light wire
ltfrc
  • 227 Answers
SOURCE: Parking lights will not come on when I use the remote starter
Most alarm installers use in line connectors or crimp-on connectors. If you can identify these connections looking under the dash, you will have to give it a little twist. Usually this allows it to make contact again.
Posted on Jan 11, 2009
RudolfDiesel
  • 100 Answers
SOURCE: Parking lights will not come on. I check the fuses and its ok.
Hello
Welcome.
I would check the head light switch see if we have power in to the switch
from there see if there is power out. sounds like a bad switch if the park lamp relay is ok
RD
Posted on Jan 12, 2009
  • 26 Answers
SOURCE: viper remote starter-
The start/stop 3x thing could be one of a few main issues. You need a bypass module or it needs to be reset. You need to program the tach if you're using it. Make sure with the new models(5101, 5301) it's programmed for auto transmission. The come default for manual transmissions.
Posted on Jan 16, 2009
  • 127 Answers
SOURCE: Starter energizes, won't turn engine.
your battery is in a weak state also the solenoid is shorting out replace the solenoid
Posted on Jun 26, 2009
Have this problem also. Took new vehicle (5009.2 miles) to dealer. They suggest that something in the control module tends to stick causing the battery to drain and that it is not an uncommon problem that they see. We had single digit temperatures here when the problem occured. It got up to 20 yesterday and everything works well again.
Posted on Jan 04, 2010
I need a wiring diagram for a viper 5701 alarm/ remote start to 2000 celica. I got it used with no instructions
http://www.broadbandreports.com/r0/download/1719726~1dde657f739f4c4af788bc21302e8a8b/Viper-5701-NewStyle-Install.pdf
Constant 12V+ Black/Red and White Ignition Switch Harness Starter Black/White Thin Wire in Ignition Switch Harness Ignition Black/Orange Ignition Switch Harness Ignition 2 Blue/Red Ignition Switch Harness Accessory Gray Ignition Switch Harness Tach Brown/White ECM Brake Switch Green/White Brake Switch Trunk Pin Light Green (-) Switch or Dome Light in Trunk Parking Lights Dark Green (-) Parking Light Switch Head Lamp Red/Blue (-) Right Side of Center Console at ECU Factory Disarm n/a Door Trigger Red/White (-) Driver's Kick Panel Door Lock Purple/White (-) Switch in Center Console Door Unlock Pink/Black (-) Horn Wire Blue/Black(-) Steering Column Windows Up LF=Green, RF=Blue (passenger's switch main) Windows Down LF=Red, RF=White/Blue
Dec 30, 2014 | Vehicle Parts & Accessories
I have DRL on my car and with the factory alarm remote when you press either the lock or unlock the head lights or the parking lights come on. With my Viper 2 way remote no lights come on when pressin
The Viper alarm (and most other alarms) are designed to be connected to the parking lights.The headlights are not meant to be flashed continuously, as when the alarm is triggered. If you want the headlights to activate with the alarm then, the parking light wire from the Viper needs to be connected to the headlight wire instead. NOT RECOMMENDED.
Although the Viper alarm may or may not have a horn output (you didn't mention the model) ,it can be connected and it can be programmed to sound either when the alarm is triggered or all the time(depending on the model).
By the way, the Driving while Running Lights are seperate from the Sentry Illumination Lights. The Sentry Illumination Lights are designed to illuminate the area in front and around of the vehicle before and after entry. They can be programmed for the time that they will illuminated before and after entry.
Aug 25, 2012 | Remote Start System
My viper 5701 transponder gives error code of five blinks even though it does the function
Five blinks of the parking lights during remote starter operation is an error code for the (+) brake shutdown. If your foot is not on the brake then, there is an issue with your brake switch or your parking lights and brake lights wires are making contact, possibly in one of the front or rear light housings. Corrosion maybe.
Mar 15, 2011 | 5701 VIPER 5701 2-WAY ALARM w/REMOTE START
I purchased and programmed a new remote to my 5701 starter.security system. the lock and unlock functions work byt i just get a loud beep, flashing red light on the remote and my headlights blink 7 times
The seven flashes from your parking lights is the remote starter error diagnostic. Seven flashes is the message for neutral safety wire. The toggle switch under the dash is in the off position or, if the small, thin black with white wire is not connected to ground.
Feb 08, 2011 | 5701 VIPER 5701 2-WAY ALARM w/REMOTE START
Remotes won't program! Installed Viper 5001 on my 2007 Kia Sorento. Triple checked wiring..all is good. Remotes won't program...no power to main unit. Yet, tested main unit and it has power. Any...
There are two constant 12 volt wires at the ignition on this vehicle: blue and green. The red power (with fuses) wires from the Viper should be connected to either of the two. The ignition wire is yellow. The pink wire from the Viper should be connected there. The accessories are orange and white. The pink with white from the Viper should connected to one and the orange from the Viper should be connected to the other. Please note that the Pink with white should be programmed to act as an accessory (off during crank). The starter wire is red and the purple from the Viper should be connected there. Also check for a good ground connection.
For programming:
Press and hold "f" until LED lights solid (approximately 10 seconds), then press and hold remote starter button(circle w/arrow) until LED blinks three times and the amber transmit LED lights up.
Now you have to enter the remote control learn routine: Turn ignition on, within ten seconds press and release control button on antenna then, press and hold control button while pressing the lock button on remote. System will respond (horn/chirp/flashing parking lights) when holding control button and when pressing lock button on remote.
Jan 17, 2011 | 5101 LE 1 Way Car Remote Starter System
Hi, when I try to use my starter option on my viper 5701 I get an error tone. when i turn off the ignition or try to use the starter option I get seven flashes on the parking lights. what does it mean and...
Seven flashes is the neutral safety switch. Check under the dash for the toggle switch labeled "on/off" and flip the switch to on. If this unit was just installed and you have always received the error tone then, the thin black/white wire must be connected to ground.
Jan 11, 2011 | 5701 VIPER 5701 2-WAY ALARM w/REMOTE START
Cannot get to work with manual transmission please help with any ideas?
There are several steps necessary for the unit to function with manual transmission. Now,the unit comes programmed for manual transmission out of the box. Next, the neutral safety wire (thin black with white stripe) MUST be connected to the parking brake wire. Also, the tachometer wire MUST be connected. Check the neutral safety switch as well. Did you install a clutch bypass? All that is left is the system setup for remote start: Start the vehicle with the key,make sure all doors are closed, put the vehicle in neutral, press on the brake, apply parking brake, release brake, within 15 seconds remote start the vehicle, the parking lights will flash to confirm the remote start activation, turn the ignition off ( the vehicle should stay running.Exit the vehicle. Arm the alarm ( the vehicle should shut off). You are now able to operate the remote start. This process must be done each time you exit for the remote starter to function on a manual transmission vehicle. Don't worry ,you'll get used to it.
Oct 12, 2010 | 5701 VIPER 5701 2-WAY ALARM w/REMOTE START
Viper alarm, lights dont flash
Sounds to me like the parking light output wire. They usually have a seperate fuse or the connection is bad. The connection on your vehicle should be behind the pass side kick panel and look for a wire to the white/purple wire and check that with a meter or light to see if it's kick out power. There is a possibility they used the negative trigger through a resister and that would be located behind the headlight switch. That will at least let you know and trace down the problem. Here is a link with that parking light info for yours. Hope this helps and let me know if you have more questions.
http://64.85.6.121/diagrams/printpage.asp?ModelID=17258&MakeID=16
Feb 25, 2009 | Vehicle Parts & Accessories
Jan 11, 2009 | Viper Security and Remote Start System...
I had a viper 5701 responder LE 2 way system installed on my 2006 dodge Dakota, everything works fine but my headlights and parks lights stay on constant while in remote operation and my park lights do...
If your vehicle has daytime running lights they will be on when remote started no real way around that try leaving your parking brake on.
The new vipers default setting is constant rather than flashing.
Dec 17, 2008 | 5701 VIPER 5701 2-WAY ALARM w/REMOTE START
Vehicle Parts & Accessories Logo
Top Viper Vehicle Parts & Accessories Experts
Kevin Daniels
oneStan
oneStan
jason
Are you a Viper Vehicle Part and Accessory Expert? Answer questions, earn points and help others
