Question about Cuisinart Coffee Makers & Espresso Machines
I got a Cuisinart SS-15 12 cup coffee maker and single serve brewer for Christmas today. When using the single serve side water spits out getting on the carafe and splashing onto the counter.
SOURCE: Waring Pro WC1000: Pour over 12 cup coffee maker
Thanks, I did find 2 in a store in Vancouver's Chinatown, but I think they were the only ones in town. It appears the only difference between the Waring Pro and Cuisinart is the lid and the lid looks to be interchangeable.
Posted on Feb 23, 2008
  • 3037 Answers
SOURCE: grounds overflowing
The coffee needs to be ground less fine as the grounds are clogging the filter. Take it apart, clean it out and then try using less ground coffee grounds. The company also has Great customer service and may even send you a new machine if it isn't working after doing this. So try cleaning it and try it again and if that doesn't work, then give them a call about this at 1-800-422-1230 or 1-800-541-6390.
Let me know how everything works out
Posted on Jun 05, 2008
  • 74 Answers
SOURCE: bunn coffeemaker
If you still have warranty on the machine take it in to the nearest service center.
Its probably a lose pipe in the machine. so if you dont have warranty left just open it up and look for lose pipes and reconnect them.
Posted on Jul 14, 2008
  • 8596 Answers
SOURCE: Cuisinart 14-cup coffee maker won't put out coffee
Clean it out with 1/3 caraffe worht of vinegar and 2/3 caraffe full of water - just brew the solution as if it were regular coffee - you may have to repeat this process up to 3 times.
-Tha Mp3 Doctor
Posted on Mar 20, 2009
  • 343 Answers
SOURCE: I have Krups KT 406
Did you try it this way?
Before descaling, remove the filter holder (f).
• You may use either the Krups descaling solution diluted in 8 ounces of water or
8 ounces of white vinegar.
• Pour the solution or vinegar into the water reservoir and start the coffee machine
(without coffee).
• Allow half the liquid to run into the carafe, then switch off and let stand for 1 hour.
• Restart the coffee machine to complete the cycle.
• Rinse the coffee machine by running it through 2 full cycles with water only
I would make vinegar stronger and leave it in for a few hours or more.
I have attached a copy of the owners manual for you to download. Thanks for using FixYa; if you could please click accept solution
Posted on May 22, 2011
I have a cup o matic and it has recently started leaking from the main unit...???? Can I fix it?
you can if you can find where the leak is, and as long as it is just a worn o-ring and not a crack. You could contact Cuisinart for service? There are some articles on your particular problem in the main link at the bottom.
Pt 1: How To Use: Cuisinart SS-1 Cup-O-Matic Coffee Maker - YouTube
? 10:04
Oct 18, 2007 - Uploaded by Jay Brewer
Learn how to use coffee pods and ground coffee with the Cuisinart SS-1 Cup-O-Matic Coffee Maker.
SS-1 - Coffee Makers - Discontinued - Regular or bold, large or small - your ideal cup should never be compromised. Now with the Cuisinart® Cup-O-Matic™ Coffeemaker, it's easy to brew your cup ...
[PDF]Cup-O-Matic™ Coffeemaker SS-1 - Cuisinart Cup-O-Matic™ Coffeemaker. SS-1. For your safety and continued enjoyment of this product, always read the instruction book carefully before using. Customer reviews: Cuisinart SS-1 Cup-O-Matic Single ... Find helpful customer reviews and review ratings for Cuisinart SS-1 Cup-O-Matic Single Serve Coffeemaker, Black and Brushed Chrome at
Cuisinart® Cup-O-Matic™ Single Serve Coffee Maker - Bed Bath ... Regular or bold, large or small, your ideal cup should never be compromised. Now with the Cuisinart® Cup-O-Matic™ Coffee Maker, it's easy to brew your cup ...
Cuisinart Cup-O-Matic Single Serve Coffeemaker Review Rating: 2 - ‎1 review
Unlike coffeemakers that only make a cup at a time, this model can be used with your favorite ground coffee as well as from coffee pods.
Single Serve Coffee Forums
cup matic leaking water Google Search
Sep 03, 2017 | Coffee Makers & Espresso Machines
Cuisinart coffee center, ss-15, lights are flashing on cup sizes, and won't make single cup coffee.what to do?
We have the Cuisinart combination 12 cup coffee maker with a 6,8,10 K-cup maker. Today 8/06/2017 the K-cup started making a strange sound stopped working and all 3 blue lights 6,8,10 where flashing and wouldn't make a cup of coffee. After some looking around it seemed that the top stainless steel water injector was clogged, I took a long toothpick and slowly pushed it in as I spun the toothpick around slowly as to not break the toothpick off inside, the water injector is sharp so the toothpick will fray as you spin it around inside this is why you must go very slowly. I also did the same to the K-cup holder stainless steel spike tube to make sure everything was clear and clean, I then ran 4 full water containers through the K-cup system starting with the 6, than 8 and 10 oz. size. I was finding little black objects in my 20oz drinking cup as I was doing this, not sure what that was but after running the 4 full containers through it they were gone. Now it works fine. I hope this helps anyone with the same machine having the same problem
Feb 13, 2017 | Cuisinart Coffee Makers & Espresso...
My cuisinart ss-300 compact single serve will not brew
I had the same problem. What worked for me was the paperclip trick. Yes, there is a metal puncture tube in the k-cup, but there is also one on the top of the lid (when you open it up as if you're putting a k-cup in there). I got a flashlight, used the paperclip to clean out all the encrusted grinds, put it thru the cleaning procedure with vinegar as per the manual, and now it works perfectly! Hope this helps.
Jan 22, 2013 | Cuisinart SS-300 Compact Single Serve...
How do I descale a single serve B31 Keurig?
You need to follow the exact directions as stated on page 18 of the manual and all thisngs will come together.
Oct 08, 2012 | Keurig B-70 Single Cup Brewer Coffee...
Leaking underneath
You are not alone having the water leak in your SS-700. For better understanding what caused that leak please read the review on Cuisinart SS-700:
Nov 22, 2011 | Cuisinart SS-700 5-Cup Coffee Maker
Cusinart coffee pot single serve with kuerig cups switch won't turn on
The problem is often that the machine develops a leak in the hose that is right over the transformer...the water drips onto the transformer and kills that... then you have no power to run the machine.
Here is a tip that I wrote about this problem...
Keurig One Cup Coffee Brewer will not turn on
Sep 01, 2011 | Cuisinart Keurig B50 Single Cup Coffee...
The single cup server runs over and grounds go everywhere.
Bottom needle is plugged...
Here is a tip that I wrote that will give you some things to try that will helpyou get your Keurig coffee brewer workingagain.
Keurig CoffeeBrewer not making a full cup of Coffee
Aug 30, 2011 | Cuisinart Keurig B50 Single Cup Coffee...
Is it normal for the Cuisinart Keurig to want water whene it appears to be still about 1/4 full?
Here is a tip that I wrote that will give you some things to try that will help you get your Keurig coffee brewer working again.
Keurig Coffee Brewer not making a full cup of Coffee
Feb 10, 2011 | Cuisinart Keurig B50 Single Cup Coffee...
Coffee Makers & Espresso Machines Logo
235 people viewed this question
Top Cuisinart Coffee Makers & Espresso Machines Experts
Greg Cann
Greg Cann
Level 1 Expert
Michael Galve
Michael Galve
Are you a Cuisinart Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
