Question about Epson Stylus CX5400 All-In-One InkJet Printer
I havent used it in months i shake the inks and they have some inside but when i try to print i get a blank page
  • jerryromo16 Jul 21, 2009
    I havent used it in months i shake the inks and they have some inside but when i try to print i get a blank page----
    I look at the cartridge and put my finger where it spits out the ink and it seems good. How would i know if they aren't good anymore?
  • Epson Master
  • 365 Answers
It seems that Epsons ink clog up after sitting.
You may need to bring the headd over as you were to change cartridges and remove them.Unplug machine.Now take 5 or 6 drops of ammonia and put them in the ink well hole.Re-install carts and let it sit for 45min to one hour.Plug back in and do a nozzle check.If someyjing comes out but faint repeat process until happy.
If this does not work you may have to get a new head,usually less expensive to invest in a new printer.
Always run a test page weekly on an Epson to prevent this from happening again!!
Posted on Aug 04, 2009
    Master:
    Sergeant:
  • 226 Answers
You may need to replace the cartridges
Posted on Jul 21, 2009
Epson Stylus CX3800 won't print, just prints blank pages?
the fact that U havent used it alot is the problem the printheads are clogged with dried ink, you need to do a printhead cleaning (or Several) There should be an INK button on the printer press that and scroll through the options till you find cleaning or maintenance and do a nozzle check after each cleaning to see if U are making progress. If there is no INK button then look for maintenance in the printer properties
Apr 13, 2014 | Epson Stylus CX3800 Printer
My printer prints blank pages when I want to print files from my computer, but works fine without a computer
If you don't use the printer often (at least once a month) you probably have cartridges drying up on you. If by chance you have an Epson or canon, the print head is inside the printer, so regardless of how many new cartridges you put in there, you will encounter the same problem.
If you are using a generic or third party ink, it may be too dense or of low quality clogging yourprint head.
You can try to run a bunch of print head cleanings. (your manual will tell you how) If by about 8 you are not seeing any improvement start with a new printer. Do a print head cleaning once a month ALWAYS as a preventative measure. This will ensure you get a long life out of your printer, and a top quality print from your cartridges.
Feb 24, 2014 | Canon PIXMA MP240 All-In-One InkJet...
Canon MP970 prints blank pages. How can I FIX that problem?
Some times when you get a new cart. a fine film can be blocking the
exit hole,check that this is clear by shaking the cart. up and down
over a large piece of paper ,if you do not get any ink out ,take a small
pin and gently insert it into the exit hole and move it around in a circle,
don't go to deep,then try shaking it again..? Another idea is to replace
all the carts.(colour ones also) as some printers wont work unless you
do this, after changing carts. disconect your printer from mains supply
and leave for about 15 minuets to reset..Hope this works for you
good luck. T.C.
Mar 31, 2013 | Canon PIXMA MP970 InkJet Printer
Can the ink dry up. installed printer ink a couple of months ago but will not print now. printer prints blank pages.
hi!
yes ink can dry up.. big chance your ink have dried up, since you've installed them couple of months ago.. there's a possibility that the ink may have not dried up but the print head may clogged.. you can try running some maintenance like clean cartridge or print head test using Dell All inOne Solution center..
Hope this helps..
Sep 11, 2010 | Dell V313w AllInOne InkJet Printer
HAVENT USED FOR 6 MONTHS. iNK SHOWS FULL. iNSTRUCTION ON SCREEN SAYS"iNSERT PRINTER HEAD" BUT IT IS ALREADY INSERTED. SHOULD i ATTEMPT TO TAKE IT OUT AND REINSERT OR IS INK DRY?
The ink must be dried up since you haven't used it for several months. Yes you can try uninstalling and reinstalling, but before you reinstall it, please clean the print heads and the contact points on the printer as well. Try shaking the cartridge and let it spill some ink drops.
This will help you fix this problem, and don't forget to restart the printer before you reinstall the cartridges.
Good luck.
Thanks for using FixYa.
Jun 23, 2010 | Kodak ESP 5 Printer
Copier appears to be functioning well, but page comes out blank
You actually answered your own question, you said it started fading and came out with lines missing. Looks like and could possibly be that the ink cartridge you are using wasn't as full as you thought it was, and the computer really has no idea, it's just software and i do not recall seeing sensors on the inside of the ink tank to tell the computer how much ink is in the cartridge. Try refilling the ink again or maybe a better idea is to buy a new cartridge since over time the cartridges can get contaminants in them which will block the ink from the inside of the cartridge.
Hope this helps
May 31, 2010 | Canon PIXMA MX310 All-In-One Printer
Center
Just remove all the removable parts from your printer including trays, toners, etc.
Shake your print toners so that the toner powder inside is mixed well equally throughout the drum inside.
Replace all the parts back and try printing and may be this should work fine for you.
Please provide back your ratings.
Thanks
Apr 05, 2010 | HP LaserJet 4700 Printer
CX5400 Replaced all ink after months in storage
uninstall the printer then reinstall it according to the setup manual.Make sure you are installing the cartridges correctly.Then print a test page form the properties menu
Oct 07, 2009 | Epson Stylus CX5400 All-In-One InkJet...
Horizontal lines (red) on first 1 - 2 pages of initial print-out
Do you refill ink tank? Print blank pages. Is there horizontal lines appear? It might be caused bay ink leakage. Check respiratory hole at ink tank and rubber seal at bottom of ink tank. Print blank pages until no horizontal lines and try to use new ink tank.
Aug 17, 2009 | Epson Stylus Photo 1270 InkJet Printer
Lexmark Z517 wont print black ink
I have a z600 that i use. If not used for about a month the ink does clog the print nozzles and eventually ink cartridge does dry out. To avoid this even if i dont have to print anything I run a diagnostics test that prints out a nozzle aligment test every two weeks.The great thing about this is that it uses very little ink.You can find this test in your software that was provided by Lexmark. This will keep your nozzles cleaned and you will notice this helps extend the life of your cartridge.
Sep 21, 2007 | Lexmark Inkjet Z517 Photo Printer
Epson Stylus CX5400 All-In-One InkJet Printer Logo
116 people viewed this question
Top Epson Office Equipment & Supplies Experts
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
