Question about Apple iPad Tablets & eReaders
My I pad is disabled the grandchildren disabled it
Forgot iPad pasword. After a few try, iPad is disabled. How to get password recovery?
You can't. You will have to connect it to a computer with iTunes, sign in to you Apple account, back up your data and then do a Factory Reset which clears all the data off it. After resetting, go through the wizard to set it up and then restore the data.
If you tried to enter 10 times or more, the SIM card, (if you use it for calls) will be disabled and you will need a new one from you cellphone carrier.
The information I have given you is confirmed in this article. If there were some easy way to bypass or recover a password, it would lack the security it was designed to do. It is only 4 numbers for heavens sake and you are using it multiple times a day! I use the last 4 digits of a memorable phone number. You can also do pattern repeats, left hand side of key pad 1,4,1,4. Right hand side of key pad 3,6,3,6.
Most enquiries here are from people who have actually found an iPad or have a stolen one, so tutoring about passcodes is useless, but I have given the info to you :>)
How to Fix iPad When Passcode Has Disabled It
Jan 24, 2016 | Tablets & eReaders
How do I reset my password?
Be careful that it's not a phishing attempt, and that the message really is from Facebook. If you're sure it's kosher, my best advice in a case like this--ask a knowledgeable friend, or one who knows a tech-type person, to go through the password reset process with you in person. You can have him (her) look away when you enter your new password. If he's brought a pad or tablet along, try logging on to Facebook with both your iPad and his to make sure the new password works.
Aug 11, 2014 | Apple iPad Tablets & eReaders
IPad mini is disabled cant unlock screen.
just says I pad is disabled and off it goes
Oct 14, 2013 | Apple iPad Mini
Demo mode on ipad 3
Disabling store demo mode If you consider installing the configuration file included below make sure you understand how to disable this mode first.
Mobile configuration files are used to configure phones in enterprises. Apple provides an app called the iPhone Configuration Utility (IPCU) to install and remove configurations. To disable store demo mode:
  • Use IPCU to remove the configuration from the phone
  • Reboot your device
Dec 27, 2012 | Apple iPad 16 GB 3G Tablet PC
I no longer have the scroll function on my touch pad for my Toshiba Satellite Laptop
Download the touch pad driver from the manufacturer's website.
Perform a complete power drain
Disable the mouse device from device manager and enable it.
This will work
Aug 12, 2009 | Toshiba Portege M400 PPM40U01000E Tablet...
Shut off touchpad
Most pc's use a program named symnaptics touch pad. Go to the control panel, select the mouse tab then mouse properties and device settings (select disable). Here you can disable the touch pad. I would recommend you have a usb mouse up and running prior to doing this procedure (saves tons of headache).
Aug 07, 2009 | Panasonic Toughbook-19 Tablet PC
I accidentally disabled my scroll bar on my touch pad mouse. How do I enable it again?
I think you are talking about a laptop. What brand and model and what operating system are you using?
Jul 14, 2009 | HP Pavilion tx2120US Tablet PC
Mouse Pad and Right and Left Buttons
Great job, I myself prefer to use a extra mouse rather then the built in one, if you chose to do this it wont work right away but if you give it a moment to recognize the mouse it will then be functionable.
Jan 04, 2008 | Toshiba Portege M400 PPM40U01000E Tablet...
Tablets & eReaders Logo
Top Apple Tablets & eReaders Experts
Virgil Wolter
Level 1 Expert
Aaron Galvan
Level 1 Expert
john smith
Are you an Apple Tablet and eReader Expert? Answer questions, earn points and help others
