Question about Sunbeam Coffee Makers & Espresso Machines
Just got new Sunbeam Cafe Crema II EM4820. The milk doesn't seem to froth and the coffee is not very warm. Any suggestions.
  • 2,290 Answers
If it does not heat properly I would take it back as it should be under warranty
Posted on Dec 26, 2016
Cafe barista not frothing
the frother gradually gets milk buildup and loses suction- an air blast through the milk tube and up the spout (can get an aerosol at hardware store) will help as well as the cleaning cycle. Also I used a q tip to the top of the spout several times but just had the q tip top come off and may have blocked it completely
May 05, 2014 | Sunbeam Mr. Coffee Cafe Barista Espresso...
Steam wand doesn't work on sunbeam cafe series coffee machine
Have you tried cleaning the steam wand nozzle with a paperclip (or the pin tool mounted in the back door of the unit?
Milk deposits can make their way inside the nozzle and block it, describing the symptoms you're getting.
Sep 11, 2012 | Sunbeam Cafe EM6910
Help received the Delonghi Cafe Nabucco machine from a friend .no instructions ,how do I make expresso ,capp steam milk etc?
Go to the above link and download the manual for the BCO 120T
It should provide the basics to get you going
Making a good espresso with steamed milk takes practice
If you don't have the frothing pitchers.. buy a couple in different sizes
Used cold low fat or non fat milk..
It takes practice to get good at it.. a hand on the side of the pitcher to make sure you don't scald the milk.. etc.. you don't want the milk to bubble/boil..
If you have a control valve for the steam pipe.. immerse the pipe about an 1/2 inch or so into the cold milk and slowly open the valve.. until you have it open full. Jostle the pitcher to move the milk around pretty much during most of the process once it begins to warm and foam.. raise the pitcher to heat the milk in the bottom .. then lower it as the foam begins to form...never letting the steam pipe out into the froth. Once done..wipe the pipe clean with a wet cloth.
Grind of the coffee is imporant as well as the roast and when you fill the portafilter don't over tamp.. If you pack it to tightly.. won't brew... too loosely.. brews too fast.. You want to see the coffee shots come out and form what's known as crema... which is a thin layer of tan or light brown foam on top of the shot. If aren't getting this..the coffee is either ground wrong or packed too tight.
It's an art..and nothing beats practice.. there are scores of books and internet threads on how to froth milk and make different coffee drinks..
I love a good Cafe Borgia now and again.. we live in the Portland, Oregon area.. everyone here is addicted to the bean..
Best of Luck
Apr 29, 2011 | DeLonghi Caffe Nabucco BCO70...
I have a new Krups XP 5240 machine. The instructions tell you how to make espresso and froth milk for cafe lattes, but don't mention how to actually MAKE the latte. What is the correct procedure for...
A latte can be made to suit your own taste, but as a starting point I would suggest:
Steam your milk first to 140 f, let it rest for at least 30 seconds( the temp will continue to rise up to around 160-180 f
while the milk is resting make your espresso shots; I like quite a strong coffee so I would make 2 shots using the double measure (once the coffee starts flowing this should take 15 seconds)
pour your shot(s) into a cup/mug first then top up to about 5mm from the rim of the cup with milk, holding the froth back with a spoon.
finally knock out any bubbles by banging the milk jug on the worktop ( this can be messy until you get good at it). using a spoon/ swirling the jug mix the foam and remaining milk until combined then top up your cup. this gives the smooth foam on the top of the latte.
Hope this helps,
Nov 06, 2010 | Krups Cappuccino/Espresso Maker -...
My jura impressa z5 is having trouble foaming the milk...worked fine last season but we can't seem to get it foaming the same as it was before...suggestions??
The common cause is that the frothing connection is faulty. You can look at the Guide to clean the Jura frothing connection, or try this. Take some bicarb or vinegar, dissolve in 400ml luke warm water, select cappuccino maintenance under the options, or press the milk button. Run the complete mixture through then. Run about 600ml of plain water through the spout. Turn the sport from froth to milk and back every 10 seconds.
If this does not work, then there may be a need to decal the machine.
Jan 24, 2010 | Jura Capresso Impressa Z5 Espresso/Coffee...
Aeroccino deosn't make froth
Our aeroccino worked fine for 2 years and suddenly it didn't made foam anymore. We tried the "inverting trick" without much success. We contacted Nespresso and they suggested switching from regular fresh milk (we used 2%) to UHT milk (harder to find in US) and to use it cold and freshly opened. So we tried that and it works.
Hope this solution works for you too
Aug 08, 2009 | Nespresso Aeroccino Automatic Milk Frother
My Krups XP4050 frother heats and makes bubbles but no froth
It doesn't froth because the air hole in the frother has become plugged with dried milk (cream). There are two types of frother - old one was a black rubber nipple with a stainless 2-3inch air tube rising above the milk. The plastic insert has a pin hole (really about the size of a straight pin!) that clogs. Use a sewing needle or straight pin to clear it.
Apr 01, 2009 | Krups XP 4050 Espresso Machine
Seaco Odea Go
You can not adjust the amount of this.
Aug 17, 2008 | Saeco Odea Go
Coffee Makers & Espresso Machines Logo
62 people viewed this question
Top Sunbeam Coffee Makers & Espresso Machines Experts
ray gallant
Gil Shultz
Are you a Sunbeam Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
