Question about Westinghouse Televison & Video
I have a vr-2218 westinghouse tvthat just lost the picture with black screen and I can hear sound . How can I fix
  • Westinghouse Master
  • 6,694 Answers
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis http://electro-medical.blogspot.com/
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
Posted on Dec 26, 2016
SOURCE: No picture on Westinghouse W32701 LCD Model
Screen goes black, sound unaffected. Can be remedied by turning off and immediately back on, but it will do it again and again and again.
Posted on Mar 02, 2008
  • 187 Answers
SOURCE: seems as if LCD screen is not recieving any power, I have no picture or sound right now but can faintly hear speakers power up when I turn the unit on.
Mainboard damaged.
Posted on Jun 02, 2009
  • 458 Answers
SOURCE: 42" LG Plasma tv, no picture - black screen, but have sound.
Most a likely a problem with your Y-Sustain board which will then not drive the screen giving a black picture. The fuse on the board may be open circuit & need replaced but most likely you will need to have the sustain board replaced.
Posted on Oct 28, 2009
SOURCE: I have a Westinghouse TV , when turned on the
I just fixed the same model and with your symptom. What it appears to be is the main module is locking up just after the Logo goes away. All you can do is unplug and try again and all you will get is the logo for 5 seconds and then black screen, no sound and led stays lit. Cannot turn off or on. The power supply is actually working fine, it's the main module that has died. This module is no longer available, the part number was W470PROLX68. What i did to restore operation on this unit was to insert 3 volts into the plug going to the master inverter board and then plugged the tv AC cord in. The set showed the logo and then it started working. I removed the 3 volts and it has worked every time since then.
Here is what you should try to do: First take two AA batteries and solder them in series and attach two short wires so you can use it as a power source. Now you have a 3 volts power supply. Next Remove the stand first before removing the back cover. Looking at the back of the unit you will see the power supply and the main circuit boards in the middle (under metal shields) and two boards on each side. These are partially covered with a metal shield, the one on the left side is the master inverter, the one on the right is the slave inv. They both have a plug and wires going to them from the power supply, but the one to the master will have two extra wires. I believe the colors are purple and blue, and they are separated with an empty hole (unused part of the plug). The wire on the end is where you will hook up the positive lead of your battery pack. The negative lead simply goes to the metal shield. With these hooked up plug the tv into the ac and give it a couple seconds and hopfully you will see the tv come on. If it does then disconnect the battery pack and try it without it. good luck.
Posted on Nov 17, 2009
budmrtn
  • 11361 Answers
SOURCE: Westinghouse SK26H240S - Sound works but no picture?
There are two places to look for the problems, the backlight inverter board and the power supply. Look at the power supply first since it is easier to get to, look for burnt parts, bad capacitors, etc.
http://en.wikipedia.org/wiki/Capacitor_plague
Please post back what you find.
Posted on Nov 28, 2009
Testimonial: "Plug and outlet are ok, well drop it off at best buy to fix. Thank you."
I have a Westinghouse VR-4085DF TV, every now and then it works fine, but most of the time I have NO picture, but we can hear the sound no problem. What is wrong? Can it be fixed?
Hi!
It can be the main board or the t-con board that is defect. This is only if you have a good power supply and the backlight is good too. When you have no image, just tap on the screen ( Not to hard ) with your finger tips, to see if you can see the backlight. If not, the backlight or backlight circuit is defect, if you have light when you tap, it's the rest i told you before. Good luck.
Serge.
Oct 01, 2015 | Westinghouse Televison & Video
The tv turns on then just turns off.I have a receiver that works.
unplug for 5 min. replug and go. if no go then perhaps the remote needs batteries or needs resetting. otherwise you may need a module replacement for the power transformer.
Feb 12, 2015 | Westinghouse Vr-2218
My tv screen has blacked out
i think you may hear the sound please check the power supply and inverter supply is normal
Mar 06, 2014 | Westinghouse VR-3215 LCD TV
Westinghouse user manual
user manual for tv VR 2218
Jan 03, 2014 | Kitchen Appliances - Others
Lost remote for vr-2218. Trying to do auto channel scan--says to hit ENTER, but without remote, can't do ENTER. I have FIOS, but Verizon remote won't program TV. Any idea what code may be?
Codes listed in my manual for White Westinghouse are 0169 or 0003 or 0014 or 0043. Are yousure though there isn't a flip down panel somewhere which gives you the option to access "enter"
Oct 07, 2012 | Westinghouse LTV-27W2 27 in. HD-Ready LCD...
No remote control for VR 2218
If the TV has a 'Menu" button on its front panel, you can enter its menu options, and can programme it. If there is no such button, you must have its remote control to programme it.
May 19, 2012 | Westinghouse 1107H0930 Main Board for...
Power on,but no image westinghouse vr-4625any fix?
If there is sound output to all channels, and oly picture is absent, the backlight inverter board should be suspected.
Apr 17, 2012 | Televison & Video
New purchase. VGA connection. First use, all was fine. Turned off, then back on, and image will not "center." Neither VGA Automatic nor the individual controls will adjust the horizontal enough...
Make sure you have your resolution set to 1680 x 1050 as this is the native supported screen size for this LCD. Also check your graphic card's overscan or manual adjustment settings. They might be manually set to offset the screen picture.
Hope this helps,
Chris
Jun 29, 2011 | Westinghouse 22" Widescreen LCD Flat Panel...
Televison & Video Logo
42 people viewed this question
Top Westinghouse Televison & Video Experts
Jaime Hernandez
Are you a Westinghouse Televison and Video Expert? Answer questions, earn points and help others
