Question about Camping, Backpacking & Hiking
Schylling headlamp battery. How to take cap off end without breaking?
Replace batteries
Marcia Boal... hello,
If our battery has corroded it may be impossible to get the end (opposite the light) cap to come off. The light is designed to be moisture resistant... Likewise even penetrating oil cannot get in...
To guarantee long reliable service it is best to put a tiny dot of grease on the threads on assembly.
Maglite Solitaire makes a wonderful little flashlight...
(all metal construction... single AAA battery)...
((Mini = 2 AAA batteries... opens the same)).
Basic colors included black, red, silver & blue
but this particular light was also quite popular for commercialization... often displaying many BIG NAME
The initial closure of the end cap can be quite loose to be effective because of it's O-ring design... however some folks put the end cap on too tight...
It might take some serious force to get it open again.
Consider using a piece of leather in a pair of pliers to avoid marring the case. Reassemble without over-tightening.
Hope this helps!
Maglite Solitaire Incandescent 1 Cell AAA Flashlight Black Basic Handheld...
Amazon com Maglite Solitaire Incandescent 1 Cell AAA Flashlight Blue Home...
Maglite Solitaire LED 1 Cell AAA Flashlight Red Basic Handheld Flashlights...
Maglite Solitaire LED 1 Cell AAA Flashlight Silver Basic Handheld...
Aug 19, 2016 | Camping, Backpacking & Hiking
Not sure which bit to unscrew when trying change battery in onyx50
The flashlight uses 1 AA battery. My guess, you should only have to unscrew the end cap. If you finds it very hard to unscrew the end cap off, it could be from the battery has explode and swollen. MAYBE - I see this happen in my daughters MAG flashlight. DO not keep your flashlight in the car with the batteries installed. The amount of heat in the cars can ruin the batteries in the flashlight.
Apr 06, 2016 | Gerber 22-80144 Onyx 50 Flashlight
How do you open a Coleman flashlight
You need to specify the model of the flashlight. However, for most of them you simply unscrew the bulb head or the battery end cap, empty the old batteries and insert the new ones with the positive end of the batteries always pointing toward the bulb end and the negative end of the batteries toward the spring in the end cap.. Be sure to discard the batteries properly. Contact your local trash disposal company to determine where and how to dispose of them.
Jan 02, 2015 | Camping, Backpacking & Hiking
Can you open the switch end of fenix hl21?
the plastic will break and even if you do get access to that, the issue with the corrosion will still cause problems.
Nov 24, 2013 | Fenix Flashlights Black HL21 Fenix HL21...
Remove Battery to replace
Hello. The correct way to the battery would be to unscrew the end cap all the way. The Battery will then fall away allowing for a new battery insertion. Hope this helps.
Jan 24, 2011 | Gerber Blades Gerber Recon LED Flashlight
How do you get the battery case open?
hold the battery pack in you hands with the system facing away from you. Holding the unit firmly, grasp the right hand end and twist it toward you. The batteries should be placed with the two outside positive ends up and the middle one with the negative end up. Place the end back on the battery case with the top of the cap slightly toward you; push in firmly and twist it back into alignment with battery case.
Nov 24, 2010 | Rayovac Sportsman Led Headlight
Hi i have a 1990 jeep cherokee pioneer 4x4 the dash lights are not comin on and neither are the break lights how do i fix this i already replaced the fuses and the headligh switch
i have an 89' cherokee. i had the same problem. first my headlamps didnt work, so i replaced the (pull) headlamp switch on the dash. well, then my dash lamps and break lamps didnt work. i returned the headlamp switch and found out that it was defective. try to get a new headlamp switch and make sure that all the male ends are straight up and down. the defective one i got had one bent male end on the opposite end of where the pull knob goes! watch out for that! i hope this helps.
Aug 23, 2010 | 1990 Jeep Cherokee Limited
Frozen tail cap
Sprayed penetrating oil all the way around the end cap at seal area. Layed flashlight on it's side on a plastic block & tapped on housing just below the end cap with composite mallet while rotating. Then used aluminum jaws in a vise to hold housing while turning end cap with large pliers.
Once cap is off, clean corrosion with automotive battery cleaner & soak inside with more penetrating oil to remove batteries.
Tonka Roy at Rosell Infiniti
Sep 03, 2007 | MagLite - Mag Charger System 110v (M)...
Camping, Backpacking & Hiking Logo
687 people viewed this question
Top Camping, Backpacking & Hiking Experts
Tom Chichester
ray gallant
Are you a Camping, Backpacking and Hiking Expert? Answer questions, earn points and help others
